| 1 |
.\" RCSid "$Id: gendaylit.1,v 1.2 2009/06/06 20:22:49 greg Exp $"
| 2 |
.TH GENDAYLIT 1 4/12/94 "RADIANCE ISE/ADEME EXTENSIONS"
| 3 |
.SH NAME
| 4 |
gendaylit - generates a RADIANCE description of the daylight sources using Perez models for direct and diffuse components
| 5 |
.SH SYNOPSIS
| 6 |
.B "gendaylit month day hour [-P|-W|-L|-G|-E] input_value(s) "
| 7 |
| 8 |
.B options
| 9 |
| 10 |
.br
| 11 |
.B "gendaylit -ang altitude azimuth [-P|-W|-L|-G|-E] input_value(s) "
| 12 |
| 13 |
.B options
| 14 |
| 15 |
.SH DESCRIPTION
| 16 |
.I Gendaylit
| 17 |
produces a RADIANCE scene description based on an angular distribution of the
| 18 |
daylight sources (direct+diffuse) for the given atmospheric conditions
| 19 |
(direct and diffuse component of the solar radiation), date and
| 20 |
local standard time. The default output is the radiance of the sun (direct) and the sky (diffuse)
| 21 |
integrated over the visible spectral range (380-780 nm). We have used the
| 22 |
calculation of the sun's position and the ground brightness models which
| 23 |
were programmed in
| 24 |
.I gensky.
| 25 |
| 26 |
The diffuse angular distribution is calculated using the Perez et al.
| 27 |
sky luminance distribution model (see Solar Energy Vol. 50, No. 3, pp. 235-245, 1993) which, quoting Perez,
| 28 |
describes "the mean instantaneous sky luminance angular distribution patterns for all sky
| 29 |
conditions from overcast to clear, through partly cloudy, skies". The correctness of the
| 30 |
resulting sky radiance/luminance values in this simulation is ensured through the normalization of the modelled
| 31 |
sky diffuse to the measured sky diffuse irradiances/illuminances.
| 32 |
| 33 |
As described below, the radiation can be defined with the pairs direct-normal and diffuse-horizontal irradiance
| 34 |
(-W option), direct-horizontal and diffuse-horizontal irradiance (-G option), direct-normal and diffuse-horizontal
| 35 |
illuminance (-L option) or global-horizontal irradiation alone (-E option). The direct-normal radiation
| 36 |
is understood here as the radiant flux coming from the sun and an area of approximately 3 degrees around the sun
| 37 |
(World Meteorological Organisation specifications for measuring the direct radiation.
| 38 |
The aperture angle of a pyrheliometer is approximately 6 degrees).
| 39 |
To simplify the calculations for the direct radiation, the sun is represented as a disk and no
| 40 |
circumsolar radiation is modelled in the 3 degrees around the sun. This means that
| 41 |
all the measured/evaluated direct radiation is added to the 0.5 degree sun source.
| 42 |
| 43 |
The direct and diffuse solar irradiances/illuminances are the inputs needed for the calculation.
| 44 |
These quantities are the commonly accessible data from radiometric measurement centres or from the
| 45 |
Test Reference Year. The use of such data is the recommended method for achieving the most accurate
| 46 |
simulation results.
| 47 |
| 48 |
The atmospheric conditions are modelled with the Perez et al. parametrization
| 49 |
(see Solar Energy Vol. 44, No 5, pp. 271-289, 1990), which is dependent on the values for
| 50 |
the direct-normal and the diffuse-horizontal irradiances. The three parameters
| 51 |
are epsilon, delta and the solar zenith angle. "Epsilon variations express the transition from
| 52 |
a totally overcast sky (epsilon=1) to a low turbidity clear sky (epsilon>6); delta
| 53 |
variations reflect the opacity/thickness of the clouds". Delta can vary from 0.05
| 54 |
representing a dark sky to 0.5 for a very bright sky. Not every combination of
| 55 |
epsilon, delta and solar zenith angle is possible. For a clear day, if
| 56 |
epsilon and the solar zenith angle are known, then delta can be determined. For intermediate or overcast
| 57 |
days, the sky can be dark or bright, giving a range of possible values for delta
| 58 |
when epsilon and the solar zenith are fixed. The relation between epsilon and delta
| 59 |
is represented in a figure on page 393 in Solar Energy Vol.42, No 5, 1989. Note that the
| 60 |
epsilon parameter is a function of the solar zenith angle. It means that a clear day
| 61 |
will not be defined by fixed values of epsilon and delta. Consequently the input
| 62 |
parameters, epsilon, delta and the solar zenith angle, have to be determined on a graph.
| 63 |
It might be easier to work with the measured direct and diffuse components (direct normal irradiance/illuminance
| 64 |
and diffuse horizontal irradiance/illuminance) than with the epsilon and delta parameters.
| 65 |
| 66 |
The conversion of irradiance into illuminance for the direct and the diffuse
| 67 |
components is determined by the luminous efficacy models of Perez et al. (see
| 68 |
Solar Energy Vol. 44, No 5, pp. 271-289, 1990). To convert the luminance values
| 69 |
into radiance integrated over the visible range of the spectrum,
| 70 |
we devide the luminance by the white light efficacy factor of
| 71 |
179 lm/W. This is consistent with the RADIANCE calculation because the luminance
| 72 |
will be recalculated from the radiance integrated over the visible range by:
| 73 |
| 74 |
luminance = radiance_integrated_over_visible_range * 179 or
| 75 |
luminance = (RED*.263 + GREEN*.655 + BLUE*.082) * 179 with the capability
| 76 |
to model colour (where radiance_integrated_over_visible_range == (RED + GREEN + BLUE)/3).
| 77 |
| 78 |
From
| 79 |
.I gensky, if the hour is preceded by a plus sign ('+'), then it is interpreted as local solar time instead of standard time.
| 80 |
The second form gives the solar angles explicitly. The altitude is measured in degrees above the horizon, and the
| 81 |
azimuth is measured in degrees west of South. The x axis points east, the y axis points north, and the z axis
| 82 |
corresponds to the zenith. The actual material and surface(s) used for the sky is left up to the user.
| 83 |
In addition to the specification of a sky distribution function,
| 84 |
.I gendaylit
| 85 |
suggests an ambient value in a comment at the beginning of the description to use with the
| 86 |
.I \-av
| 87 |
option of the RADIANCE rendering programs. (See rview(1) and rpict(1).) This value is the cosine-weighted
| 88 |
radiance of the sky in W/sr/m^2.
| 89 |
.PP
| 90 |
.I Gendaylit
| 91 |
can be used with the following input parameters. They offer three possibilities
| 92 |
to run it: with the Perez parametrization, with irradiance values and with illuminance values.
| 93 |
.TP 10n
| 94 |
.BR \-P
| 95 |
.I epsilon
| 96 |
.I delta
| 97 |
(these are the Perez parameters)
| 98 |
.TP
| 99 |
.BR \-W
| 100 |
.I direct-normal-irradiance
| 101 |
(W/m^2),
| 102 |
.I diffuse-horizontal-irradiance
| 103 |
(W/m^2)
| 104 |
.TP
| 105 |
.BR \-G
| 106 |
.I direct-horizontal-irradiance
| 107 |
(W/m^2),
| 108 |
| 109 |
(W/m^2)
| 110 |
.TP
| 111 |
.BR \-L
| 112 |
.I direct-normal-illuminance
| 113 |
(lm/m^2),
| 114 |
.I diffuse-horizontal-illuminance
| 115 |
(lm/m^2)
| 116 |
.TP
| 117 |
.BR \-E
| 118 |
.I global-horizontal-irradiance
| 119 |
(W/m^2)
| 120 |
.PP
| 121 |
The -E option calculates the diffuse irradiance fraction with the model of Erbs, Klein and Duffie (Solar Energy 28/4, 1982),
| 122 |
being followed by the calculation of the -G option. Due to the high uncertainty of the model, the results have to be handled
| 123 |
with care. A second irradiance value, if available, is definitely recommended.
| 124 |
.PP
| 125 |
The output can be set to either the radiance of the visible radiation, the solar radiance (full spectrum) or the luminance.
| 126 |
.TP 10n
| 127 |
.BR \-O [0|1|2]
| 128 |
(0=output in W/m^2/sr visible radiation (default), 1=output in W/m^2/sr solar radiation, 2=output in lm/m^2/sr luminance).
| 129 |
.PP
| 130 |
.I Gendaylit
| 131 |
supports the following options.
| 132 |
.TP 10n
| 133 |
.BR \-s
| 134 |
The source description of the sun is not generated.
| 135 |
.TP
| 136 |
.BR \-w
| 137 |
Suppress warning messages
| 138 |
.TP
| 139 |
.BI -g \ rfl
| 140 |
Average ground reflectance is
| 141 |
.I rfl.
| 142 |
This value is used to compute
| 143 |
.I skyfunc
| 144 |
when Dz is negative.
| 145 |
.PP
| 146 |
The following options do not apply when the solar
| 147 |
altitude and azimuth are given explicitly.
| 148 |
.TP
| 149 |
.BI -a \ lat
| 150 |
The site latitude is
| 151 |
.I lat
| 152 |
degrees north.
| 153 |
(Use negative angle for south latitude.)
| 154 |
This is used in the calculation of sun angle.
| 155 |
.TP
| 156 |
.BI -o \ lon
| 157 |
The site longitude is
| 158 |
.I lon
| 159 |
degrees west.
| 160 |
(Use negative angle for east longitude.)
| 161 |
This is used in the calculation of solar time and sun angle.
| 162 |
Be sure to give the corresponding standard meridian also!
| 163 |
If solar time is given directly, then this option has no effect.
| 164 |
.TP
| 165 |
.BI -m \ mer
| 166 |
The site standard meridian is
| 167 |
.I mer
| 168 |
degrees west of Greenwich.
| 169 |
(Use negative angle for east.)
| 170 |
This is used in the calculation of solar time.
| 171 |
Be sure to give the correct longitude also!
| 172 |
| 173 |
.TP
| 174 |
.BI -i \ time_interval [min]
| 175 |
If gendaylit is used with weather files, the specified instantaneous points of time may be incorrect. This error occurs
| 176 |
due to the fact that measurement results are frequently defined for time intervals, not for specific points of time.
| 177 |
Although gendaylit is working correctly, this may lead to wrong outputs especially at low sun altitudes.
| 178 |
The -i option allows to specify the time interval of the measurements in minutes, causing the solar position to be corrected for low sun
| 179 |
altitudes. A warning message is returned if a correction has been performed.
| 180 |
| 181 |
.SH EXAMPLES
| 182 |
A clear non-turbid sky for a solar altitude of 60 degrees and an azimut of 0 degree might be defined by:
| 183 |
.IP "" .2i
| 184 |
gendaylit -ang 60 0 -P 6.3 0.12 or gendaylit -ang 60 0 -W 840 135
| 185 |
This sky description corresponds to the clear sky standard of the CIE.
| 186 |
.PP
| 187 |
The corresponding sky with a high turbidity is:
| 188 |
.IP "" .2i
| 189 |
gendaylit -ang 60 0 -P 3.2 0.24 or gendaylit -ang 60 0 -W 720 280
| 190 |
.PP
| 191 |
The dark overcast sky (corresponding to the CIE overcast standard, see CIE draft standard,
| 192 |
Pub. No. CIE DS 003, 1st Edition, 1994) is obtained by:
| 193 |
.IP "" .2i
| 194 |
gendaylit -ang 60 0 -P 1 0.08
| 195 |
.PP
| 196 |
A bright overcast sky is modelled with a larger value of delta, for example:
| 197 |
.IP "" .2i
| 198 |
gendaylit -ang 60 0 -P 1 0.35
| 199 |
.PP
| 200 |
To generate the same bright overcast sky for March 2th at 3:15pm standard time at a site
| 201 |
latitude of 42 degrees, 108 degrees west longitude, and a 110 degrees standard meridian:
| 202 |
.IP "" .2i
| 203 |
gendaylit 3 2 15.25 -a 42 -o 108 -m 110 -P 1 0.35
| 204 |
.PP
| 205 |
.SH FILES
| 206 |
/usr/local/lib/ray/perezlum.cal
| 207 |
.SH AUTHOR
| 208 |
Jean-Jacques Delaunay, Jan Wienold, Wendelin Sprenger, Fraunhofer ISE (Freiburg i.B., Germany) ([email protected])
| 209 |
.SH ACKNOWLEDGEMENTS
| 210 |
The first work on this program was supported by the German Federal Ministry for Research
| 211 |
and Technology (BMFT) under contract No. 0329294A, and a scholarship from
| 212 |
the French Environment and Energy Agency (ADEME) which was co-funded by Bouygues.
| 213 |
Many thanks to Peter Apian-Bennewitz, Arndt Berger, Christian Reetz, Ann Kovach, R. Perez, C. Gueymard and G. Ward for their help.
| 214 |
.SH "SEE ALSO"
| 215 |
gensky(1), rpict(1), rview(1), xform(1)
