root/radiance/ray/doc/man/man1/gendaylit.1
Revision: 1.1
Committed: Sat Jun 6 20:20:04 2009 UTC (16 years ago) by greg
1 .\" RCSid "$Id: gendaylit.1,v 1.6 2007/09/04 17:36:40 greg Exp $"
2 .SH NAME
3 gendaylit - generates a RADIANCE description of the daylit sources using Perez models for diffuse and direct components
4 .SH SYNOPSIS
5 .B "gendaylit month day hour [-P|-W|-L] direct_value diffuse_value "
6 [
7 .B options
8 ]
9 .br
10 .B "gendaylit -ang altitude azimuth [-P|-W|-L] direct_value diffuse_value "
11 [
12 .B options
13 ]
14 .SH DESCRIPTION
15 .I Gendaylit
16 produces a RADIANCE scene description based on an angular distribution of the
17 daylight sources (direct+diffuse) for the given atmospheric conditions
18 (direct and diffuse component of the solar radiation), date and
19 local standard time. The default output is the radiance of the sun (direct) and the sky (diffus)
20 integrated over the visible spectral range (380-780 nm). We have used the
21 calculation of the sun's position and the ground brightness models which
22 were programmed in
23 .I gensky.
24
25 The diffuse angular distribution is calculated using the Perez et al.
26 sky luminance distribution model (see Solar Energy Vol. 50, No. 3, pp. 235-245, 1993) which, quoting Perez,
27 describes "the mean instantaneous sky luminance angular distribution patterns for all sky
28 conditions from overcast to clear, through partly cloudy, skies". The correctness of the
29 resulting sky radiance/luminance values in this simulation is ensured through the normalization of the modelled
30 sky diffuse to the measured sky diffuse irradiances/illuminances.
31
32 The direct radiation is understood here as the radiant flux coming from the sun
33 and an area of approximately 3 degrees around the sun (World Meteorological Organisation specifications
34 for measuring the direct radiation. The aperture angle of a pyrheliometer is approximately 6 degrees).
35 To simplify the calculations for the direct radiation, the sun is represented as a disk and no
36 circumsolar radiation is modelled in the 3 degrees around the sun. This means that
37 all the measured/evaluated direct radiation is added to the 0.5 degree sun source.
38
39 .I The direct and diffuse
40 .I solar irradiances/illuminances
41 .I are the inputs needed
42 .I for the calculation.
43 These quantities are the commonly accessible data from radiometric measurement centres, conversion models
44 (e.g. global irradiance to direct irradiance), or from the Test Reference Year. The use of such
45 data is the recommended method for achieving the most accurate simulation results.
46
47
48 The atmospheric conditions are modelled with the Perez et al. parametrization
49 (see Solar Energy Vol. 44, No 5, pp. 271-289, 1990), which is dependent on the values for
50 the direct and the diffuse irradiances. The three parameters
51 are epsilon, delta and the solar zenith angle. "Epsilon variations express the transition from
52 a totally overcast sky (epsilon=1) to a low turbidity clear sky (epsilon>6); delta
53 variations reflect the opacity/thickness of the clouds". Delta can vary from 0.05
54 representing a dark sky to 0.5 for a very bright sky. Not every combination of
55 epsilon, delta and solar zenith angle is possible. For a clear day, if
56 epsilon and the solar zenith angle are known, then delta can be determined. For intermediate or overcast
57 days, the sky can be dark or bright, giving a range of possible values for delta
58 when epsilon and the solar zenith are fixed. The relation between epsilon and delta
59 is represented in a figure on page 393 in Solar Energy Vol.42, No 5, 1989,
60 or can be obtained from the author of this RADIANCE extension upon request. Note that the
61 epsilon parameter is a function of the solar zenith angle. It means that a clear day
62 will not be defined by fixed values of epsilon and delta. Consequently the input
63 parameters, epsilon, delta and the solar zenith angle, have to be determined on a graph.
64 It might be easier to work with the measured direct and diffuse components (direct normal irradiance/illuminance
65 and diffuse horizontal irradiance/illuminance) than with the epsilon and delta parameters.
66
67
68 The conversion of irradiance into illuminance for the direct and the diffuse
69 components is determined by the luminous efficacy models of Perez et al. (see
70 Solar Energy Vol. 44, No 5, pp. 271-289, 1990). To convert the luminance values
71 into radiance integrated over the visible range of the spectrum,
72 we devide the luminance by the white light efficacy factor of
73 179 lm/W. This is consistent with the RADIANCE calculation because the luminance
74 will be recalculated from the radiance integrated over the visible range by :
75
76 luminance = radiance_integrated_over_visible_range * 179 or
77
78 luminance = (RED*.263 + GREEN*.655 + BLUE*.082) * 179 with the capability
79 to model colour (where radiance_integrated_over_visible_range == (RED + GREEN + BLUE)/3).
80
81 From
82 .I gensky
83 , if the hour is preceded by a plus sign ('+'), then it is interpreted
84 as local solar time instead of standard time.
85 The second form gives the solar angles explicitly.
86 The altitude is measured in degrees above the horizon, and the
87 azimuth is measured in degrees west of South.
88 .PP
89 The x axis points east,
90 the y axis points north, and the z axis corresponds to the zenith.
91 The actual material and surface(s) used for the sky is left
92 up to the user.
93 .PP
94 In addition to the specification of
95 a sky distribution function,
96 .I gendaylit
97 suggests an ambient value in a comment at the beginning of the
98 description to use with the
99 .I \-av
100 option of the RADIANCE rendering programs.
101 (See rview(1) and rpict(1).)
102 This value is the cosine-weighted radiance of the sky in
103 W/sr/m^2.
104 .PP
105 .I Gendaylit
106 can be used with the following input parameters. They offer three possibilities
107 to run it: with the Perez parametrization, with the irradiance values
108 and with the illuminance values.
109 .TP 10n
110 .BR \-P
111 .I epsilon
112 .I delta
113 (these are the Perez parameters)
114 .TP
115 .BR \-W
116 .I direct-normal-irradiance
117 (W/m^2),
118 .I diffuse-horizontal-irradiance
119 (W/m^2)
120 .TP
121 .BR \-L
122 .I direct-normal-illuminance
123 (lm/m^2),
124 .I diffuse-horizontal-illuminance
125 (lm/m^2)
126 .PP
127 The output can be set to either the radiance of the visible radiation (default), the solar radiance (full spectrum) or the luminance.
128 .TP 10n
129 .BR \-O [0|1|2]
130 (0=output in W/m^2/sr visible radiation, 0=output in W/m^2/sr solar radiation, 2=output in lm/m^2/sr luminance)
131 .PP
132 .I Gendaylit
133 supports the following options.
134 .TP 10n
135 .BR \-s
136 The source description of the sun is not generated.
137 .TP
138 .BI -g \ rfl
139 Average ground reflectance is
140 .I rfl.
141 This value is used to compute
142 .I skyfunc
143 when Dz is negative.
144 .PP
145 The following options do not apply when the solar
146 altitude and azimuth are given explicitly.
147 .TP
148 .BI -a \ lat
149 The site latitude is
150 .I lat
151 degrees north.
152 (Use negative angle for south latitude.)
153 This is used in the calculation of sun angle.
154 .TP
155 .BI -o \ lon
156 The site longitude is
157 .I lon
158 degrees west.
159 (Use negative angle for east longitude.)
160 This is used in the calculation of solar time and sun angle.
161 Be sure to give the corresponding standard meridian also!
162 If solar time is given directly, then this option has no effect.
163 .TP
164 .BI -m \ mer
165 The site standard meridian is
166 .I mer
167 degrees west of Greenwich.
168 (Use negative angle for east.)
169 This is used in the calculation of solar time.
170 Be sure to give the correct longitude also!
171 If solar time is given directly, then this option has no effect.
172 .SH EXAMPLES
173 A clear non-turbid sky for a solar altitude of 60 degrees and an azimut of 0 degree might be defined by:
174 .IP "" .2i
175 gendaylit -ang 60 0 -P 6.3 0.12 or gendaylit -ang 60 0 -W 840 135
176 This sky description corresponds to the clear sky standard of the CIE.
177 .PP
178 The corresponding sky with a high turbidity is:
179 .IP "" .2i
180 gendaylit -ang 60 0 -P 3.2 0.24 or gendaylit -ang 60 0 -W 720 280
181 .PP
182 The dark overcast sky (corresponding to the CIE overcast standard, see CIE draft standard,
183 Pub. No. CIE DS 003, 1st Edition, 1994) is obtained by:
184 .IP "" .2i
185 gendaylit -ang 60 0 -P 1 0.08
186 .PP
187 A bright overcast sky is modelled with a larger value of delta, for example:
188 .IP "" .2i
189 gendaylit -ang 60 0 -P 1 0.35
190 .PP
191 To generate the same bright overcast sky for March 2th at 3:15pm standard time at a site
192 latitude of 42 degrees, 108 degrees west longitude, and a 110 degrees standard meridian:
193 .IP "" .2i
194 gendaylit 3 2 15.25 -a 42 -o 108 -m 110 -P 1 0.35
195 .PP
196 .SH FILES
197 /usr/local/lib/ray/perezlum.cal
198 .SH AUTHOR
199 Jean-Jacques Delaunay, FhG-ISE Freiburg, ([email protected])
200 .SH ACKNOWLEDGEMENTS
201 The work on this program was supported by the German Federal Ministry for Research
202 and Technology (BMFT) under contract No. 0329294A, and a scholarship from
203 the French Environment and Energy Agency (ADEME) which was co-funded by Bouygues.
204 Many thanks to Peter Apian-Bennewitz, Arndt Berger, Ann Kovach, R. Perez, C. Gueymard and G. Ward for their help.
205 .SH "SEE ALSO"
206 gensky(1), rpict(1), rview(1), xform(1)
