root/radiance/ray/doc/man/man1/genclock.1
Revision: 1.4
Committed: Tue Sep 4 17:36:40 2007 UTC (16 years, 9 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad3R9, rad4R2P1, rad5R3, HEAD
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
1 .\" RCSid "$Id: genclock.1,v 1.3 2004/01/01 19:31:44 greg Exp $"
2 .TH GENCLOCK 1 4/9/97 RADIANCE
3 .SH NAME
4 genclock - generate a RADIANCE description of a clock
5 .SH SYNOPSIS
6 .B genclock
7 [
8 .B "\-f face_mat"
9 ][
10 .B "\-c case_mat"
11 ][
12 .B "\-n name"
13 ]
14 {
15 .B HH:MM
16 |
17 .B hours
18 }
19 .SH DESCRIPTION
20 .I Genclock
21 produces a RADIANCE scene description of an analog clock showing the
22 given hour.
23 The hour may either be given as
24 .I HH:MM
25 or decimal
26 .I hours.
27 .PP
28 The face of the clock will have a radius of 1.0 units, with the
29 surrounding case 1.1 (2.2 diameter).
30 The origin is at the center of the back, and the face looks in the
31 positive X-direction.
32 The 12 o'clock direction corresponds to the positive Z-axis.
33 (The Y-axis direction is 3 o'clock.)\0
34 The
35 .I xform(1)
36 command may be used to resize and relocate the clock as desired.
37 .PP
38 Normally,
39 .I genclock
40 produces all of the materials necessary for its own description, but
41 options are provided to specify alternate materials for the face and
42 case.
43 The numbers on the face are in dark lettering, so the face material
44 must be relatively light for them to show up well.
45 By default, the clock is given the name "clock," but this may be
46 changed with the
47 .I \-n
48 option.
49 .SH EXAMPLE
50 To produce a 12 inch diameter clock showing 10:35
51 and hang it at 60 on a wall facing the Y-direction at Y=10:
52 .IP "" .2i
53 genclock 10:35 | xform \-s 6 \-rz 90 \-t 20 10 60
54 .SH AUTHOR
55 Greg Ward
56 .SH "SEE ALSO"
57 genbox(1), genrev(1), gensurf(1), genworm(1), rpict(1), rvu(1), xform(1)
