root/radiance/ray/doc/man/man1/genbox.1
Revision: 1.3
Committed: Thu Jan 1 19:31:44 2004 UTC (20 years, 5 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1, rad3R8
# User Rev Content
1 greg 1.3 .\" RCSid "$Id: genbox.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 greg 1.1 .TH GENBOX 1 11/15/93 RADIANCE
3     .SH NAME
4     genbox - generate a RADIANCE description of a box
5     .SH SYNOPSIS
6     .B "genbox mat name xsiz ysiz zsiz"
7     [
8     .B \-i
9     ][
10     .B "\-r rad"
11     |
12     .B "\-b bev"
13     ]
14     .SH DESCRIPTION
15     .I Genbox
16     produces a RADIANCE scene description of a parallelepiped
17     with one corner at the origin and the opposite corner at
18     .I "(xsiz, ysiz, zsiz)."
19     The sides of the box will be parallel to the three coordinate
20     planes.
21     The surfaces that make up the box will be modified by
22     .I mat
23     and their identifiers will begin with
24     .I name.
25     The
26     .I \-i
27     option can be used to produce a box with inward directed surface
28     normals.
29     The
30     .I \-r
31     option can be used to specify the radius for rounded edges.
32     The
33     .I \-b
34     option can be used to specify the indentation for beveled edges.
35     .SH EXAMPLE
36     To produce a rectangular box made of wood with beveled edges:
37     .IP "" .2i
38     genbox wood box1 5 8 3 -b .5 > box1
39     .SH AUTHOR
40     Greg Ward
41     .SH BUGS
42     Because spheres and cylinders are used to construct boxes with
43     rounded edges, a transparent box of this type appears quite messy.
44     .SH "SEE ALSO"
45 greg 1.3 genrev(1), gensurf(1), genworm(1), rpict(1), rvu(1), xform(1)
