root/radiance/ray/doc/man/man1/genbox.1
Revision: 1.7
Committed: Thu Mar 9 23:48:45 2023 UTC (2 years, 3 months ago) by greg
CVS Tags: rad5R4, HEAD
docs: corrected typo
# User Rev Content
1 greg 1.7 .\" RCSid "$Id: genbox.1,v 1.6 2021/04/15 23:51:04 greg Exp $"
2 greg 1.1 .TH GENBOX 1 11/15/93 RADIANCE
3     .SH NAME
4 greg 1.5 genbox - generate a RADIANCE or Wavefront description of a box
5 greg 1.1 .SH SYNOPSIS
6     .B "genbox mat name xsiz ysiz zsiz"
7     [
8     .B \-i
9     ][
10 greg 1.5 .B "\-b bev"
11     |
12 greg 1.1 .B "\-r rad"
13 greg 1.5 [
14     .B "\-n nseg
15 greg 1.6 ][
16     .B \-s
17 greg 1.5 ]
18     ][
19     .B \-o
20 greg 1.1 ]
21     .SH DESCRIPTION
22     .I Genbox
23     produces a RADIANCE scene description of a parallelepiped
24     with one corner at the origin and the opposite corner at
25     .I "(xsiz, ysiz, zsiz)."
26     The sides of the box will be parallel to the three coordinate
27     planes.
28     The surfaces that make up the box will be modified by
29     .I mat
30     and their identifiers will begin with
31     .I name.
32 greg 1.5 .PP
33 greg 1.1 The
34     .I \-i
35     option can be used to produce a box with inward directed surface
36     normals.
37 greg 1.5 .PP
38     The
39     .I \-b
40     option can be used to specify the indentation for beveled edges.
41     .PP
42 greg 1.1 The
43     .I \-r
44 greg 1.5 option can be used to specify the radius for rounded edges, which
45 greg 1.6 are normally
46     modeled as cylinders and spheres for non-inverted RADIANCE output.
47 greg 1.5 However, this type of model only makes sense for external views of
48     an opaque object.
49     If a rounded box is inverted using
50     .I \-i,
51     then the corners and edges are modeled with polygons, instead.
52 greg 1.7 This option can also be forced by specifying a minimum number of
53 greg 1.5 segments with the
54     .I \-n
55     option.
56 greg 1.6 The
57     .I \-s
58     option controls whether surface normal smoothing is applied as well.
59 greg 1.5 .PP
60 greg 1.1 The
61 greg 1.5 .I \-o
62     option specifies Wavefront .OBJ output, and
63     also forces polygons to be used with the
64     .I \-r
65     option.
66 greg 1.6 If the
67     .I \-s
68     option is present, vertex normals are also produced for smooth rendering.
69 greg 1.1 .SH EXAMPLE
70 greg 1.5 To produce a rectangular box made of wood with rounded edges:
71     .IP "" .2i
72     genbox wood box1 5 8 3 \-r .5 > box1.rad
73     .PP
74     To produce a box made of crystal with beveled edges:
75 greg 1.1 .IP "" .2i
76 greg 1.5 genbox crystal box2 3 7 1 \-b .1 > box2.rad
77 greg 1.6 .PP
78     To produce a transparent box with smoothed, rounded edges:
79     .IP "" .2i
80     genbox glassy box3 2 4 3 -r .25 -n 16 -s > box3.rad
81 greg 1.1 .SH AUTHOR
82     Greg Ward
83     .SH "SEE ALSO"
84 greg 1.5 genrev(1), gensurf(1), genworm(1), obj2mesh(1), obj2rad(1),
85     robjutil(1), rpict(1), rvu(1), xform(1)
