| 1 |
.\" RCSid "$Id: genblinds.1,v 1.3 2004/01/01 19:31:44 greg Exp $"
| 2 |
.TH GENBLINDS 1 10/10/94 RADIANCE
| 3 |
.SH NAME
| 4 |
genblinds - generate a RADIANCE description of venetian blinds
| 5 |
.SH SYNOPSIS
| 6 |
.B "genblinds mat name depth width height nslats angle"
| 7 |
| 8 |
.B "\-r|+r rcurv"
| 9 |
| 10 |
.SH DESCRIPTION
| 11 |
.I Genblinds
| 12 |
produces a RADIANCE scene description of a set of venetian blinds.
| 13 |
The
| 14 |
.I depth
| 15 |
of the blinds (X dimension) is given first, followed by the
| 16 |
.I width
| 17 |
(Y dimension), followed by the
| 18 |
.I height
| 19 |
(Z dimension).
| 20 |
The number of slats to place evenly within this height is given as
| 21 |
.I nslats.
| 22 |
The
| 23 |
.I angle
| 24 |
of the blind, where zero is perfectly horizontal and a
| 25 |
positive angle tilts the positive X edge upwards, is
| 26 |
given in degrees.
| 27 |
The blinds are initially situated so that the corner of the bottom blind is
| 28 |
.I "height/nslats/2"
| 29 |
above the XY plane, and all coordinates are positive.
| 30 |
Each new slat is placed
| 31 |
.I "height/nslats"
| 32 |
above the previous one, until the top slat is at
| 33 |
.I "height - height/nslats/2".
| 34 |
The blinds may of course be moved from this starting point with the
| 35 |
.I "xform(1)"
| 36 |
command.
| 37 |
.PP
| 38 |
If curved blinds are desired, a radius of curvature may be given
| 39 |
with the
| 40 |
.I "+/-r"
| 41 |
option.
| 42 |
If given as
| 43 |
.I +r,
| 44 |
The curvature is upward (which is the usual configuration).
| 45 |
If the option is given as
| 46 |
.I -r,
| 47 |
then the curvature is downward.
| 48 |
The radius indicates how far from each slat its effective
| 49 |
cylindrical center resides.
| 50 |
Each slat will be broken into as many polygons as is necessary to
| 51 |
keep the delta changes in angle less than 10 degrees.
| 52 |
(Note that this may result in a rather large number of polygons.)\0
| 53 |
.SH EXAMPLE
| 54 |
To produce a curved set of blinds with 15 slats:
| 55 |
.IP "" .2i
| 56 |
genblinds white blind 1 46 88 118 15 -r 1 > blinds.rad
| 57 |
.SH AUTHOR
| 58 |
Jean-Louis Scartezzini and Greg Ward
| 59 |
.SH "SEE ALSO"
| 60 |
genbox(1), genrev(1), gensurf(1), genworm(1), rpict(1), rvu(1), xform(1)
