1 |
.\" RCSid "$Id" |
2 |
.TH GENBLINDS 1 10/10/94 RADIANCE |
3 |
.SH NAME |
4 |
genblinds - generate a RADIANCE description of venetian blinds |
5 |
.SH SYNOPSIS |
6 |
.B "genblinds mat name depth width height nslats angle" |
7 |
8 |
.B "\-r|+r rcurv" |
9 |
10 |
.SH DESCRIPTION |
11 |
.I Genblinds |
12 |
produces a RADIANCE scene description of a set of venetian blinds. |
13 |
The |
14 |
.I depth |
15 |
of the blinds (X dimension) is given first, followed by the |
16 |
.I width |
17 |
(Y dimension), followed by the |
18 |
.I height |
19 |
(Z dimension). |
20 |
The number of slats to place evenly within this height is given as |
21 |
.I nslats. |
22 |
The |
23 |
.I angle |
24 |
of the blind, where zero is perfectly horizontal and a |
25 |
positive angle tilts the positive X edge upwards, is |
26 |
given in degrees. |
27 |
The blinds are initially situated so that the corner of the bottom blind is |
28 |
.I "height/nslats/2" |
29 |
above the XY plane, and all coordinates are positive. |
30 |
Each new slat is placed |
31 |
.I "height/nslats" |
32 |
above the previous one, until the top slat is at |
33 |
.I "height - height/nslats/2". |
34 |
The blinds may of course be moved from this starting point with the |
35 |
.I "xform(1)" |
36 |
command. |
37 |
.PP |
38 |
If curved blinds are desired, a radius of curvature may be given |
39 |
with the |
40 |
.I "+/-r" |
41 |
option. |
42 |
If given as |
43 |
.I -r, |
44 |
The curvature is downward (which is the usual configuration). |
45 |
If the option is given as |
46 |
.I +r, |
47 |
then the curvature is upward. |
48 |
The radius indicates how far from each slat its effective |
49 |
cylindrical center resides. |
50 |
Each slat will be broken into as many polygons as is necessary to |
51 |
keep the delta changes in angle less than 10 degrees. |
52 |
(Note that this may result in a rather large number of polygons.)\0 |
53 |
.SH EXAMPLE |
54 |
To produce a curved set of blinds with 15 slats: |
55 |
.IP "" .2i |
56 |
genblinds white blind 1 46 88 118 15 -r 1 > blinds.rad |
57 |
.SH AUTHOR |
58 |
Jean-Louis Scartezzini and Greg Ward |
59 |
.SH "SEE ALSO" |
60 |
genbox(1), genrev(1), gensurf(1), genworm(1), rpict(1), rview(1), xform(1) |
