root/Development/ray/doc/man/man1/genblinds.1
Revision: 1.1
Committed: Tue Mar 11 19:20:21 2003 UTC (22 years, 9 months ago) by greg
Added documentation to repository
# User Rev Content
1 greg 1.1 .\" RCSid "$Id"
2     .TH GENBLINDS 1 10/10/94 RADIANCE
3     .SH NAME
4     genblinds - generate a RADIANCE description of venetian blinds
5     .SH SYNOPSIS
6     .B "genblinds mat name depth width height nslats angle"
7     [
8     .B "\-r|+r rcurv"
9     ]
10     .SH DESCRIPTION
11     .I Genblinds
12     produces a RADIANCE scene description of a set of venetian blinds.
13     The
14     .I depth
15     of the blinds (X dimension) is given first, followed by the
16     .I width
17     (Y dimension), followed by the
18     .I height
19     (Z dimension).
20     The number of slats to place evenly within this height is given as
21     .I nslats.
22     The
23     .I angle
24     of the blind, where zero is perfectly horizontal and a
25     positive angle tilts the positive X edge upwards, is
26     given in degrees.
27     The blinds are initially situated so that the corner of the bottom blind is
28     .I "height/nslats/2"
29     above the XY plane, and all coordinates are positive.
30     Each new slat is placed
31     .I "height/nslats"
32     above the previous one, until the top slat is at
33     .I "height - height/nslats/2".
34     The blinds may of course be moved from this starting point with the
35     .I "xform(1)"
36     command.
37     .PP
38     If curved blinds are desired, a radius of curvature may be given
39     with the
40     .I "+/-r"
41     option.
42     If given as
43     .I -r,
44     The curvature is downward (which is the usual configuration).
45     If the option is given as
46     .I +r,
47     then the curvature is upward.
48     The radius indicates how far from each slat its effective
49     cylindrical center resides.
50     Each slat will be broken into as many polygons as is necessary to
51     keep the delta changes in angle less than 10 degrees.
52     (Note that this may result in a rather large number of polygons.)\0
53     .SH EXAMPLE
54     To produce a curved set of blinds with 15 slats:
55     .IP "" .2i
56     genblinds white blind 1 46 88 118 15 -r 1 > blinds.rad
57     .SH AUTHOR
58     Jean-Louis Scartezzini and Greg Ward
59     .SH "SEE ALSO"
60     genbox(1), genrev(1), gensurf(1), genworm(1), rpict(1), rview(1), xform(1)
