root/radiance/ray/doc/man/man1/genBSDF.1
Revision: 1.24
Committed: Wed Apr 2 00:55:27 2025 UTC (6 weeks, 4 days ago) by greg
Changes since 1.23: +9 -3 lines
feat(genBSDF): Added support for -r "-cs M" to employ M spectral samples
# User Rev Content
1 greg 1.24 .\" RCSid $Id: genBSDF.1,v 1.23 2023/12/12 16:31:45 greg Exp $
2 greg 1.1 .TH GENBSDF 1 9/3/2010 RADIANCE
3     .SH NAME
4     genBSDF - generate BSDF description from Radiance or MGF input
5     .SH SYNOPSIS
6     .B genBSDF
7     [
8     .B "\-c Nsamp"
9     ][
10     .B "\-n Nproc"
11     ][
12 greg 1.10 .B "\-r 'rcontrib opts...'"
13 greg 1.4 ][
14 greg 1.14 .B "\-W"
15     ][
16 greg 1.15 .B "\-s 'x=string;y=string'"
17 greg 1.14 ][
18 greg 1.6 .B "\-t{3|4} Nlog2"
19     ][
20 greg 1.17 .B "{+|-}C"
21     ][
22 greg 1.20 .B "{+|-}a"
23     ][
24 greg 1.3 .B "{+|-}forward"
25     ][
26     .B "{+|-}backward"
27     ][
28 greg 1.1 .B "{+|-}mgf"
29     ][
30 greg 1.7 .B "{+|-}geom unit"
31 greg 1.1 ][
32     .B "\-dim Xmin Xmax Ymin Ymax Zmin Zmax"
33     ]
34     [
35     .B "geom .."
36     ]
37 greg 1.19 .br
38     or
39     .br
40     .B genBSDF
41     .B "\-recover tempdir"
42 greg 1.1 .SH DESCRIPTION
43     .I GenBSDF
44 greg 1.3 computes a bidirectional scattering distribution function from
45 greg 1.1 a Radiance or MGF scene description given on the input.
46     The program assumes the input is in Radiance format unless the
47     .I \+mgf
48     option is specified.
49     The output conforms to the LBNL Window 6 XML standard for BSDF data,
50     and will include an MGF representation of the input geometry if the
51     .I \+geom
52 greg 1.7 option is given, followed by one of "meter," "foot," "inch,"
53     "centimeter," or "millimeter," depending on the scene units.
54     The default is to include the provided geometry,
55     which is assumed to be in meters.
56     Geometry output can be supressed with the
57     .I \-geom
58     option, which must also be followed by one of the above length units.
59 greg 1.1 .PP
60 greg 1.3 Normally,
61     .I genBSDF
62     computes components needed by a backwards ray-tracing process,
63     .I \+backward.
64     If both forward and backward (front and back) distributions are needed, the
65     .I \+forward
66     option may be given.
67     To turn off backward components, use the
68     .I \-backward
69     option.
70 greg 1.12 Computing both components takes about twice as long as one component, but
71     is recommended when rays will be impinging from either side.
72 greg 1.3 .PP
73 greg 1.17 The
74     .I \+C
75 greg 1.24 option specifies that the output XML should include tristimulus
76     color information, which is interpreted by the rendering programs.
77 greg 1.18 The default option
78     .I \-C
79 greg 1.17 reduces all BSDF data to grayscale.
80 greg 1.24 If the input is spectral and a
81     .I \-cs
82     parameter of 9 or more is specified as part of the rendering
83     .I \-r
84     option list, then full spectral result will be
85     reduced to an XYZ-equivalent CIE color space in the XML output.
86 greg 1.17 .PP
87 greg 1.20 The
88     .I \-a
89     option turns off reciprocity averaging for tensor tree output.
90 greg 1.21 Normally on (+a), this ensures that each tensor-tree hemisphere follows symmetry
91     implied by Helmholtz reciprocity, and is designed to reduce ray sampling noise.
92     However, for some systems, reciprocity averaging can actually make the output worse.
93 greg 1.20 .PP
94 greg 1.1 The geometry must fit a rectangular profile, whose width is along the X-axis,
95     height is in the Y-axis, and depth is in the Z-axis.
96     The positive Z-axis points into the room, and the input geometry should
97     not extend into the room.
98     (I.e., it should not contain any positive Z values, since the putative
99     emitting surface is assumed to lie at Z=0.)\0
100     The entire window system should be modeled, including sills and
101     edge geometry anticipated in the final installation, otherwise
102     accuracy will be impaired.
103     Similarly, materials in the description should be carefully measured.
104     .PP
105     Normally, the input geometry will be positioned according to its actual
106     bounding box, but this may be overridden with the
107     .I \-dim
108     option.
109     Use this in cases where the fenestration system is designed to fit a
110     smaller (or larger) opening or is offset somehow.
111     .PP
112     The variance in the results may be reduced by increasing the number of
113     samples per incident direction using the
114     .I \-c
115     option.
116 greg 1.9 This value defaults to 2000 samples distributed over the incoming plane
117 greg 1.1 for each of the 145 Klems hemisphere directions.
118     .PP
119 greg 1.11 On multi-core machines, processing time may be reduced by the
120 greg 1.1 .I \-n
121     option, which specifies the number of simultaneous
122     processes to run in
123 greg 1.10 .I rcontrib(1).
124 greg 1.4 The
125     .I \-r
126     option may be used to specify a set of quoted arguments to be
127     included on the
128 greg 1.10 .I rcontrib
129 greg 1.4 command line.
130 greg 1.6 .PP
131     The
132 greg 1.14 .I \-W
133 greg 1.15 option is passed to
134     .I wrapBSDF(1)
135     to prepare the XML file for WINDOW6.
136     Any
137     .I \-s
138     parameters are passed to the
139 greg 1.14 .I \-f
140 greg 1.15 option of
141     .I wrapBSDF,
142     controlling XML fields such as
143     the Manufacturer (e.g., -s m=MF) and device Name (e.g, -s n=NM).
144 greg 1.14 .PP
145     The
146 greg 1.6 .I \-t4
147     mode computes a non-uniform BSDF represented as a rank 4 tensor tree,
148     suitable for use in the Radiance rendering tools.
149     The parameter given to this option is the log to the base 2 of the
150     sampling resolution in each dimension, and must be an integer.
151     The
152     .I \-c
153     setting should be adjusted so that an appropriate number of samples
154     lands in each region.
155     A
156     .I \-t4
157     parameter of 5 corresponds to 32x32 or 1024 output regions, so a
158     .I \-c
159 greg 1.9 setting of 10240 would provide 10 samples per region on average.
160 greg 1.6 Increasing the resolution to 6 corresponds to 64x64 or 4096
161     regions, so the
162     .I \-c
163     setting would need to be increased by a factor of 4 to provide
164     the same accuracy in each region.
165     .PP
166     The
167     .I \-t3
168     mode is similar to
169     .I \-t4
170     but computes a rank 3 tensor tree rather than rank 4.
171     This provides a much faster computation, but only works
172     in special circumstances.
173     Specifically, do NOT use this option if the system is not in fact isotropic.
174     I.e., only use
175     .I \-t3
176     when you are certain that the system has a high degree of radial symmetry.
177     Again, the parameter to this option sets the maximum resolution as
178     a power of 2 in each dimension, but in this case there is one less
179     dimension being sampled.
180 greg 1.19 .PP
181     The
182     .I \-recover
183     option is available for continuing calculations that were killed by
184     the system or the user.
185     Unfortunately, genBSDF puts its temporary files in a directory
186     that is often cleaned up after reboot, so this may not always work.
187 greg 1.1 .SH EXAMPLE
188     To create a BSDF description including geometry from a set of venetian blinds:
189     .IP "" .2i
190 greg 1.2 genblinds blind_white blind1 .07 3 1.5 30 40 | xform -rz -90 -rx 90 > blind1.rad
191 greg 1.1 .br
192 greg 1.4 genBSDF -r @rtc.opt blind_white.mat glazing.rad blind1.rad > blind1.xml
193 greg 1.6 .PP
194     To create a non-uniform, anisotropic BSDF distribution with a maximum
195     resolution of 128x128 from the same description:
196     .IP "" .2i
197     genBSDF -r @rtc.opt -t4 7 -c 160000 blind_white.mat glazing.rad blind1.rad > blind12.xml
198     .SH NOTES
199     The variable resolution (tensor tree) BSDF representation is not supported
200     by all software and applicatons, and should be used with caution.
201     It provides practical, high-resolution data for use in the
202     Radiance rendering programs, but does not work in the matrix formulation
203     of the daylight coefficient method for example.
204     Also, third party tools generally expect or require a fixed number of sample
205     directions using the Klems directions or similar.
206 greg 1.1 .SH AUTHOR
207     Greg Ward
208     .SH "SEE ALSO"
209 greg 1.13 dctimestep(1), gendaymtx(1), genklemsamp(1), genskyvec(1), mkillum(1),
210 greg 1.23 pkgBSDF(1), rcomb(1), rcontrib(1), rfluxmtx(1), rmtxop(1), rtrace(1) wrapBSDF(1)
