| 1 |
.\" RCSid $Id: genBSDF.1,v 1.5 2011/05/06 23:58:09 greg Exp $
| 2 |
.TH GENBSDF 1 9/3/2010 RADIANCE
| 3 |
.SH NAME
| 4 |
genBSDF - generate BSDF description from Radiance or MGF input
| 5 |
.SH SYNOPSIS
| 6 |
.B genBSDF
| 7 |
| 8 |
.B "\-c Nsamp"
| 9 |
| 10 |
.B "\-n Nproc"
| 11 |
| 12 |
.B "\-r 'rtcontrib opts...'"
| 13 |
| 14 |
.B "\-t{3|4} Nlog2"
| 15 |
| 16 |
.B "{+|-}forward"
| 17 |
| 18 |
.B "{+|-}backward"
| 19 |
| 20 |
.B "{+|-}mgf"
| 21 |
| 22 |
.B "{+|-}geom
| 23 |
| 24 |
.B "\-dim Xmin Xmax Ymin Ymax Zmin Zmax"
| 25 |
| 26 |
| 27 |
.B "geom .."
| 28 |
| 29 |
.SH DESCRIPTION
| 30 |
.I GenBSDF
| 31 |
computes a bidirectional scattering distribution function from
| 32 |
a Radiance or MGF scene description given on the input.
| 33 |
The program assumes the input is in Radiance format unless the
| 34 |
.I \+mgf
| 35 |
option is specified.
| 36 |
The output conforms to the LBNL Window 6 XML standard for BSDF data,
| 37 |
and will include an MGF representation of the input geometry if the
| 38 |
.I \+geom
| 39 |
option is given.
| 40 |
(This is the default, and may be switched off using
| 41 |
.I \-geom.)\0
| 42 |
.PP
| 43 |
Normally,
| 44 |
.I genBSDF
| 45 |
computes components needed by a backwards ray-tracing process,
| 46 |
.I \+backward.
| 47 |
If both forward and backward (front and back) distributions are needed, the
| 48 |
.I \+forward
| 49 |
option may be given.
| 50 |
To turn off backward components, use the
| 51 |
.I \-backward
| 52 |
option.
| 53 |
Computing both components takes about twice as long as one component.
| 54 |
.PP
| 55 |
The geometry must fit a rectangular profile, whose width is along the X-axis,
| 56 |
height is in the Y-axis, and depth is in the Z-axis.
| 57 |
The positive Z-axis points into the room, and the input geometry should
| 58 |
not extend into the room.
| 59 |
(I.e., it should not contain any positive Z values, since the putative
| 60 |
emitting surface is assumed to lie at Z=0.)\0
| 61 |
The entire window system should be modeled, including sills and
| 62 |
edge geometry anticipated in the final installation, otherwise
| 63 |
accuracy will be impaired.
| 64 |
Similarly, materials in the description should be carefully measured.
| 65 |
.PP
| 66 |
Normally, the input geometry will be positioned according to its actual
| 67 |
bounding box, but this may be overridden with the
| 68 |
.I \-dim
| 69 |
option.
| 70 |
Use this in cases where the fenestration system is designed to fit a
| 71 |
smaller (or larger) opening or is offset somehow.
| 72 |
.PP
| 73 |
The variance in the results may be reduced by increasing the number of
| 74 |
samples per incident direction using the
| 75 |
.I \-c
| 76 |
option.
| 77 |
This value defaults to 1000 samples distributed over the incoming plane
| 78 |
for each of the 145 Klems hemisphere directions.
| 79 |
.PP
| 80 |
In some cases, the processing time may be reduced by the
| 81 |
.I \-n
| 82 |
option, which specifies the number of simultaneous
| 83 |
.I rtrace(1)
| 84 |
processes to run in
| 85 |
.I rtcontrib(1).
| 86 |
The
| 87 |
.I \-r
| 88 |
option may be used to specify a set of quoted arguments to be
| 89 |
included on the
| 90 |
.I rtcontrib
| 91 |
command line.
| 92 |
.PP
| 93 |
The
| 94 |
.I \-t4
| 95 |
mode computes a non-uniform BSDF represented as a rank 4 tensor tree,
| 96 |
suitable for use in the Radiance rendering tools.
| 97 |
The parameter given to this option is the log to the base 2 of the
| 98 |
sampling resolution in each dimension, and must be an integer.
| 99 |
The
| 100 |
.I \-c
| 101 |
setting should be adjusted so that an appropriate number of samples
| 102 |
lands in each region.
| 103 |
A
| 104 |
.I \-t4
| 105 |
parameter of 5 corresponds to 32x32 or 1024 output regions, so a
| 106 |
.I \-c
| 107 |
setting of 102400 would provide 100 samples per region on average.
| 108 |
Increasing the resolution to 6 corresponds to 64x64 or 4096
| 109 |
regions, so the
| 110 |
.I \-c
| 111 |
setting would need to be increased by a factor of 4 to provide
| 112 |
the same accuracy in each region.
| 113 |
.PP
| 114 |
The
| 115 |
.I \-t3
| 116 |
mode is similar to
| 117 |
.I \-t4
| 118 |
but computes a rank 3 tensor tree rather than rank 4.
| 119 |
This provides a much faster computation, but only works
| 120 |
in special circumstances.
| 121 |
Specifically, do NOT use this option if the system is not in fact isotropic.
| 122 |
I.e., only use
| 123 |
.I \-t3
| 124 |
when you are certain that the system has a high degree of radial symmetry.
| 125 |
Again, the parameter to this option sets the maximum resolution as
| 126 |
a power of 2 in each dimension, but in this case there is one less
| 127 |
dimension being sampled.
| 128 |
.SH EXAMPLE
| 129 |
To create a BSDF description including geometry from a set of venetian blinds:
| 130 |
.IP "" .2i
| 131 |
genblinds blind_white blind1 .07 3 1.5 30 40 | xform -rz -90 -rx 90 > blind1.rad
| 132 |
.br
| 133 |
genBSDF -r @rtc.opt blind_white.mat glazing.rad blind1.rad > blind1.xml
| 134 |
.PP
| 135 |
To create a non-uniform, anisotropic BSDF distribution with a maximum
| 136 |
resolution of 128x128 from the same description:
| 137 |
.IP "" .2i
| 138 |
genBSDF -r @rtc.opt -t4 7 -c 160000 blind_white.mat glazing.rad blind1.rad > blind12.xml
| 139 |
.SH NOTES
| 140 |
The variable resolution (tensor tree) BSDF representation is not supported
| 141 |
by all software and applicatons, and should be used with caution.
| 142 |
It provides practical, high-resolution data for use in the
| 143 |
Radiance rendering programs, but does not work in the matrix formulation
| 144 |
of the daylight coefficient method for example.
| 145 |
Also, third party tools generally expect or require a fixed number of sample
| 146 |
directions using the Klems directions or similar.
| 147 |
.SH AUTHOR
| 148 |
Greg Ward
| 149 |
.SH "SEE ALSO"
| 150 |
dctimestep(1), genklemsamp(1), genskyvec(1), mkillum(1), rtcontrib(1), rtrace(1)
