| 1 |
.\" RCSid $Id: genBSDF.1,v 1.1 2010/09/04 15:17:43 greg Exp $
| 2 |
.TH GENBSDF 1 9/3/2010 RADIANCE
| 3 |
.SH NAME
| 4 |
genBSDF - generate BSDF description from Radiance or MGF input
| 5 |
.SH SYNOPSIS
| 6 |
.B genBSDF
| 7 |
| 8 |
.B "\-c Nsamp"
| 9 |
| 10 |
.B "\-n Nproc"
| 11 |
| 12 |
.B "{+|-}mgf"
| 13 |
| 14 |
.B "{+|-}geom
| 15 |
| 16 |
.B "\-dim Xmin Xmax Ymin Ymax Zmin Zmax"
| 17 |
| 18 |
| 19 |
.B "geom .."
| 20 |
| 21 |
.SH DESCRIPTION
| 22 |
.I GenBSDF
| 23 |
computes a bidirectional transmittance distribution function from
| 24 |
a Radiance or MGF scene description given on the input.
| 25 |
The program assumes the input is in Radiance format unless the
| 26 |
.I \+mgf
| 27 |
option is specified.
| 28 |
The output conforms to the LBNL Window 6 XML standard for BSDF data,
| 29 |
and will include an MGF representation of the input geometry if the
| 30 |
.I \+geom
| 31 |
option is given.
| 32 |
(This is currently the default, and may be switche off using
| 33 |
.I \-geom.)\0
| 34 |
.PP
| 35 |
The geometry must fit a rectangular profile, whose width is along the X-axis,
| 36 |
height is in the Y-axis, and depth is in the Z-axis.
| 37 |
The positive Z-axis points into the room, and the input geometry should
| 38 |
not extend into the room.
| 39 |
(I.e., it should not contain any positive Z values, since the putative
| 40 |
emitting surface is assumed to lie at Z=0.)\0
| 41 |
The entire window system should be modeled, including sills and
| 42 |
edge geometry anticipated in the final installation, otherwise
| 43 |
accuracy will be impaired.
| 44 |
Similarly, materials in the description should be carefully measured.
| 45 |
.PP
| 46 |
Normally, the input geometry will be positioned according to its actual
| 47 |
bounding box, but this may be overridden with the
| 48 |
.I \-dim
| 49 |
option.
| 50 |
Use this in cases where the fenestration system is designed to fit a
| 51 |
smaller (or larger) opening or is offset somehow.
| 52 |
.PP
| 53 |
The variance in the results may be reduced by increasing the number of
| 54 |
samples per incident direction using the
| 55 |
.I \-c
| 56 |
option.
| 57 |
This value defaults to 1000 samples distributed over the incoming plane
| 58 |
for each of the 145 Klems hemisphere directions.
| 59 |
.PP
| 60 |
In some cases, the processing time may be reduced by the
| 61 |
.I \-n
| 62 |
option, which specifies the number of simultaneous
| 63 |
.I rtrace(1)
| 64 |
processes to run in
| 65 |
.I rtcontrib(1).
| 66 |
.SH EXAMPLE
| 67 |
To create a BSDF description including geometry from a set of venetian blinds:
| 68 |
.IP "" .2i
| 69 |
genblinds blind_white blind1 .07 3 1.5 30 40 | xform -rz -90 -rx 90 > blind1.rad
| 70 |
.br
| 71 |
genBSDF blind_white.mat glazing.rad blind1.rad > blind1.xml
| 72 |
.SH NOTES
| 73 |
Currently,
| 74 |
.I genBSDF
| 75 |
computes only the forward visible transmitted component,
| 76 |
though the XML specification provides for front and back
| 77 |
transmission and reflection as well.
| 78 |
.SH AUTHOR
| 79 |
Greg Ward
| 80 |
.SH "SEE ALSO"
| 81 |
dctimestep(1), genklemsamp(1), genskyvec(1), mkillum(1), rtcontrib(1), rtrace(1)
