1 |
.\" RCSid $Id: genklemsamp.1,v 1.3 2009/12/10 00:17:19 greg Exp $ |
2 |
.TH GENBSDF 1 9/3/2010 RADIANCE |
3 |
.SH NAME |
4 |
genBSDF - generate BSDF description from Radiance or MGF input |
5 |
.SH SYNOPSIS |
6 |
.B genBSDF |
7 |
8 |
.B "\-c Nsamp" |
9 |
10 |
.B "\-n Nproc" |
11 |
12 |
.B "{+|-}mgf" |
13 |
14 |
.B "{+|-}geom |
15 |
16 |
.B "\-dim Xmin Xmax Ymin Ymax Zmin Zmax" |
17 |
18 |
19 |
.B "geom .." |
20 |
21 |
.SH DESCRIPTION |
22 |
.I GenBSDF |
23 |
computes a bidirectional transmittance distribution function from |
24 |
a Radiance or MGF scene description given on the input. |
25 |
The program assumes the input is in Radiance format unless the |
26 |
.I \+mgf |
27 |
option is specified. |
28 |
The output conforms to the LBNL Window 6 XML standard for BSDF data, |
29 |
and will include an MGF representation of the input geometry if the |
30 |
.I \+geom |
31 |
option is given. |
32 |
(This is currently the default, and may be switche off using |
33 |
.I \-geom.)\0 |
34 |
.PP |
35 |
The geometry must fit a rectangular profile, whose width is along the X-axis, |
36 |
height is in the Y-axis, and depth is in the Z-axis. |
37 |
The positive Z-axis points into the room, and the input geometry should |
38 |
not extend into the room. |
39 |
(I.e., it should not contain any positive Z values, since the putative |
40 |
emitting surface is assumed to lie at Z=0.)\0 |
41 |
The entire window system should be modeled, including sills and |
42 |
edge geometry anticipated in the final installation, otherwise |
43 |
accuracy will be impaired. |
44 |
Similarly, materials in the description should be carefully measured. |
45 |
.PP |
46 |
Normally, the input geometry will be positioned according to its actual |
47 |
bounding box, but this may be overridden with the |
48 |
.I \-dim |
49 |
option. |
50 |
Use this in cases where the fenestration system is designed to fit a |
51 |
smaller (or larger) opening or is offset somehow. |
52 |
.PP |
53 |
The variance in the results may be reduced by increasing the number of |
54 |
samples per incident direction using the |
55 |
.I \-c |
56 |
option. |
57 |
This value defaults to 1000 samples distributed over the incoming plane |
58 |
for each of the 145 Klems hemisphere directions. |
59 |
.PP |
60 |
In some cases, the processing time may be reduced by the |
61 |
.I \-n |
62 |
option, which specifies the number of simultaneous |
63 |
.I rtrace(1) |
64 |
processes to run in |
65 |
.I rtcontrib(1). |
66 |
.SH EXAMPLE |
67 |
To create a BSDF description including geometry from a set of venetian blinds: |
68 |
.IP "" .2i |
69 |
genblinds blind_white blind1 .07 3 1.5 30 40 > blind1.rad |
70 |
.br |
71 |
genBSDF blind_white.mat blind1.rad > blind1.xml |
72 |
.SH NOTES |
73 |
Currently, |
74 |
.I genBSDF |
75 |
computes only the forward visible transmitted component, |
76 |
though the XML specification provides for front and back |
77 |
transmission and reflection as well. |
78 |
.SH AUTHOR |
79 |
Greg Ward |
80 |
.SH "SEE ALSO" |
81 |
dctimestep(1), genklemsamp(1), genskyvec(1), mkillum(1), rtcontrib(1), rtrace(1) |
