1 |
.\" RCSid $Id: genBSDF.1,v 1.9 2011/08/24 04:14:58 greg Exp $ |
2 |
.TH GENBSDF 1 9/3/2010 RADIANCE |
3 |
.SH NAME |
4 |
genBSDF - generate BSDF description from Radiance or MGF input |
5 |
.SH SYNOPSIS |
6 |
.B genBSDF |
7 |
8 |
.B "\-c Nsamp" |
9 |
10 |
.B "\-n Nproc" |
11 |
12 |
.B "\-r 'rcontrib opts...'" |
13 |
14 |
.B "\-t{3|4} Nlog2" |
15 |
16 |
.B "{+|-}forward" |
17 |
18 |
.B "{+|-}backward" |
19 |
20 |
.B "{+|-}mgf" |
21 |
22 |
.B "{+|-}geom unit" |
23 |
24 |
.B "\-dim Xmin Xmax Ymin Ymax Zmin Zmax" |
25 |
26 |
27 |
.B "geom .." |
28 |
29 |
.SH DESCRIPTION |
30 |
.I GenBSDF |
31 |
computes a bidirectional scattering distribution function from |
32 |
a Radiance or MGF scene description given on the input. |
33 |
The program assumes the input is in Radiance format unless the |
34 |
.I \+mgf |
35 |
option is specified. |
36 |
The output conforms to the LBNL Window 6 XML standard for BSDF data, |
37 |
and will include an MGF representation of the input geometry if the |
38 |
.I \+geom |
39 |
option is given, followed by one of "meter," "foot," "inch," |
40 |
"centimeter," or "millimeter," depending on the scene units. |
41 |
The default is to include the provided geometry, |
42 |
which is assumed to be in meters. |
43 |
Geometry output can be supressed with the |
44 |
.I \-geom |
45 |
option, which must also be followed by one of the above length units. |
46 |
.PP |
47 |
Normally, |
48 |
.I genBSDF |
49 |
computes components needed by a backwards ray-tracing process, |
50 |
.I \+backward. |
51 |
If both forward and backward (front and back) distributions are needed, the |
52 |
.I \+forward |
53 |
option may be given. |
54 |
To turn off backward components, use the |
55 |
.I \-backward |
56 |
option. |
57 |
Computing both components takes about twice as long as one component. |
58 |
.PP |
59 |
The geometry must fit a rectangular profile, whose width is along the X-axis, |
60 |
height is in the Y-axis, and depth is in the Z-axis. |
61 |
The positive Z-axis points into the room, and the input geometry should |
62 |
not extend into the room. |
63 |
(I.e., it should not contain any positive Z values, since the putative |
64 |
emitting surface is assumed to lie at Z=0.)\0 |
65 |
The entire window system should be modeled, including sills and |
66 |
edge geometry anticipated in the final installation, otherwise |
67 |
accuracy will be impaired. |
68 |
Similarly, materials in the description should be carefully measured. |
69 |
.PP |
70 |
Normally, the input geometry will be positioned according to its actual |
71 |
bounding box, but this may be overridden with the |
72 |
.I \-dim |
73 |
option. |
74 |
Use this in cases where the fenestration system is designed to fit a |
75 |
smaller (or larger) opening or is offset somehow. |
76 |
.PP |
77 |
The variance in the results may be reduced by increasing the number of |
78 |
samples per incident direction using the |
79 |
.I \-c |
80 |
option. |
81 |
This value defaults to 2000 samples distributed over the incoming plane |
82 |
for each of the 145 Klems hemisphere directions. |
83 |
.PP |
84 |
In some cases, the processing time may be reduced by the |
85 |
.I \-n |
86 |
option, which specifies the number of simultaneous |
87 |
.I rtrace(1) |
88 |
processes to run in |
89 |
.I rcontrib(1). |
90 |
The |
91 |
.I \-r |
92 |
option may be used to specify a set of quoted arguments to be |
93 |
included on the |
94 |
.I rcontrib |
95 |
command line. |
96 |
.PP |
97 |
The |
98 |
.I \-t4 |
99 |
mode computes a non-uniform BSDF represented as a rank 4 tensor tree, |
100 |
suitable for use in the Radiance rendering tools. |
101 |
The parameter given to this option is the log to the base 2 of the |
102 |
sampling resolution in each dimension, and must be an integer. |
103 |
The |
104 |
.I \-c |
105 |
setting should be adjusted so that an appropriate number of samples |
106 |
lands in each region. |
107 |
A |
108 |
.I \-t4 |
109 |
parameter of 5 corresponds to 32x32 or 1024 output regions, so a |
110 |
.I \-c |
111 |
setting of 10240 would provide 10 samples per region on average. |
112 |
Increasing the resolution to 6 corresponds to 64x64 or 4096 |
113 |
regions, so the |
114 |
.I \-c |
115 |
setting would need to be increased by a factor of 4 to provide |
116 |
the same accuracy in each region. |
117 |
.PP |
118 |
The |
119 |
.I \-t3 |
120 |
mode is similar to |
121 |
.I \-t4 |
122 |
but computes a rank 3 tensor tree rather than rank 4. |
123 |
This provides a much faster computation, but only works |
124 |
in special circumstances. |
125 |
Specifically, do NOT use this option if the system is not in fact isotropic. |
126 |
I.e., only use |
127 |
.I \-t3 |
128 |
when you are certain that the system has a high degree of radial symmetry. |
129 |
Again, the parameter to this option sets the maximum resolution as |
130 |
a power of 2 in each dimension, but in this case there is one less |
131 |
dimension being sampled. |
132 |
.SH EXAMPLE |
133 |
To create a BSDF description including geometry from a set of venetian blinds: |
134 |
.IP "" .2i |
135 |
genblinds blind_white blind1 .07 3 1.5 30 40 | xform -rz -90 -rx 90 > blind1.rad |
136 |
.br |
137 |
genBSDF -r @rtc.opt blind_white.mat glazing.rad blind1.rad > blind1.xml |
138 |
.PP |
139 |
To create a non-uniform, anisotropic BSDF distribution with a maximum |
140 |
resolution of 128x128 from the same description: |
141 |
.IP "" .2i |
142 |
genBSDF -r @rtc.opt -t4 7 -c 160000 blind_white.mat glazing.rad blind1.rad > blind12.xml |
143 |
.SH NOTES |
144 |
The variable resolution (tensor tree) BSDF representation is not supported |
145 |
by all software and applicatons, and should be used with caution. |
146 |
It provides practical, high-resolution data for use in the |
147 |
Radiance rendering programs, but does not work in the matrix formulation |
148 |
of the daylight coefficient method for example. |
149 |
Also, third party tools generally expect or require a fixed number of sample |
150 |
directions using the Klems directions or similar. |
151 |
.SH AUTHOR |
152 |
Greg Ward |
153 |
.SH "SEE ALSO" |
154 |
dctimestep(1), genklemsamp(1), genskyvec(1), mkillum(1), |
155 |
pkgBSDF(1), rcontrib(1), rtrace(1) |
