root/Development/ray/doc/man/man1/genBSDF.1
Revision: 1.3
Committed: Mon Feb 21 22:48:50 2011 UTC (14 years, 10 months ago) by greg
Changes since 1.2: +19 -3 lines
1 .\" RCSid $Id: genBSDF.1,v 1.2 2010/09/04 15:19:28 greg Exp $
2 .TH GENBSDF 1 9/3/2010 RADIANCE
3 .SH NAME
4 genBSDF - generate BSDF description from Radiance or MGF input
5 .SH SYNOPSIS
6 .B genBSDF
7 [
8 .B "\-c Nsamp"
9 ][
10 .B "\-n Nproc"
11 ][
12 .B "{+|-}forward"
13 ][
14 .B "{+|-}backward"
15 ][
16 .B "{+|-}mgf"
17 ][
18 .B "{+|-}geom
19 ][
20 .B "\-dim Xmin Xmax Ymin Ymax Zmin Zmax"
21 ]
22 [
23 .B "geom .."
24 ]
25 .SH DESCRIPTION
26 .I GenBSDF
27 computes a bidirectional scattering distribution function from
28 a Radiance or MGF scene description given on the input.
29 The program assumes the input is in Radiance format unless the
30 .I \+mgf
31 option is specified.
32 The output conforms to the LBNL Window 6 XML standard for BSDF data,
33 and will include an MGF representation of the input geometry if the
34 .I \+geom
35 option is given.
36 (This is the default, and may be switched off using
37 .I \-geom.)\0
38 .PP
39 Normally,
40 .I genBSDF
41 computes components needed by a backwards ray-tracing process,
42 .I \+backward.
43 If both forward and backward (front and back) distributions are needed, the
44 .I \+forward
45 option may be given.
46 To turn off backward components, use the
47 .I \-backward
48 option.
49 Computing both components takes about twice as long as one component.
50 .PP
51 The geometry must fit a rectangular profile, whose width is along the X-axis,
52 height is in the Y-axis, and depth is in the Z-axis.
53 The positive Z-axis points into the room, and the input geometry should
54 not extend into the room.
55 (I.e., it should not contain any positive Z values, since the putative
56 emitting surface is assumed to lie at Z=0.)\0
57 The entire window system should be modeled, including sills and
58 edge geometry anticipated in the final installation, otherwise
59 accuracy will be impaired.
60 Similarly, materials in the description should be carefully measured.
61 .PP
62 Normally, the input geometry will be positioned according to its actual
63 bounding box, but this may be overridden with the
64 .I \-dim
65 option.
66 Use this in cases where the fenestration system is designed to fit a
67 smaller (or larger) opening or is offset somehow.
68 .PP
69 The variance in the results may be reduced by increasing the number of
70 samples per incident direction using the
71 .I \-c
72 option.
73 This value defaults to 1000 samples distributed over the incoming plane
74 for each of the 145 Klems hemisphere directions.
75 .PP
76 In some cases, the processing time may be reduced by the
77 .I \-n
78 option, which specifies the number of simultaneous
79 .I rtrace(1)
80 processes to run in
81 .I rtcontrib(1).
82 .SH EXAMPLE
83 To create a BSDF description including geometry from a set of venetian blinds:
84 .IP "" .2i
85 genblinds blind_white blind1 .07 3 1.5 30 40 | xform -rz -90 -rx 90 > blind1.rad
86 .br
87 genBSDF blind_white.mat glazing.rad blind1.rad > blind1.xml
88 .SH NOTES
89 Currently,
90 .I genBSDF
91 computes only the forward visible transmitted component,
92 though the XML specification provides for front and back
93 transmission and reflection as well.
94 .SH AUTHOR
95 Greg Ward
96 .SH "SEE ALSO"
97 dctimestep(1), genklemsamp(1), genskyvec(1), mkillum(1), rtcontrib(1), rtrace(1)
