root/Development/ray/doc/man/man1/genBSDF.1
Sun Apr 5 01:32:01 2015 UTC (10 years, 8 months ago) by greg
Changes since 1.17: +3 -3 lines
Diff to previous 1.17 , to selected 1.10
Added color rendering to tensor tree and minor fixes to Klems color rendering
Thu Apr 2 16:40:31 2015 UTC (10 years, 8 months ago) by greg
Changes since 1.16: +11 -1 lines
Diff to previous 1.16 , to selected 1.10
Support for color BSDF rendering using Klems representation
Fri Mar 27 00:10:07 2015 UTC (10 years, 9 months ago) by greg
Changes since 1.15: +2 -2 lines
Diff to previous 1.15 , to selected 1.10
Forgot reference to wrapBSDF in "SEE ALSO" section
Fri Mar 27 00:08:49 2015 UTC (10 years, 9 months ago) by greg
Changes since 1.14: +12 -7 lines
Diff to previous 1.14 , to selected 1.10
Fixed overloaded -f option, renaming to -s
Fri Feb 20 18:26:08 2015 UTC (10 years, 10 months ago) by greg
Changes since 1.13: +15 -2 lines
Diff to previous 1.13 , to selected 1.10
Sun Jan 20 02:07:16 2013 UTC (12 years, 11 months ago) by greg
Diff to previous 1.12 , to selected 1.10
Added documentation for new gendaymtx tool
Sun Sep 2 15:33:14 2012 UTC (13 years, 3 months ago) by greg
Diff to previous 1.11 , to selected 1.10
Wed Jun 20 00:48:54 2012 UTC (13 years, 6 months ago) by greg
Changes since 1.10: +2 -3 lines
Diff to previous 1.10
Fixed reference to -n option
Revision 1.10 - (view) (download) (annotate) - [selected]
Thu Jun 14 22:42:21 2012 UTC (13 years, 6 months ago) by greg
Changes since 1.9: +5 -5 lines
Diff to previous 1.9
Wed Aug 24 04:14:58 2011 UTC (14 years, 4 months ago) by greg
Diff to previous 1.8 , to selected 1.10
Tue Aug 23 14:02:41 2011 UTC (14 years, 4 months ago) by greg
Diff to previous 1.7 , to selected 1.10
Fri Jun 24 00:41:51 2011 UTC (14 years, 6 months ago) by greg
Changes since 1.6: +11 -6 lines
Diff to previous 1.6 , to selected 1.10
Fri Jun 3 19:41:14 2011 UTC (14 years, 6 months ago) by greg
Changes since 1.5: +52 -1 lines
Diff to previous 1.5 , to selected 1.10
Fri May 6 23:58:09 2011 UTC (14 years, 7 months ago) by greg
Changes since 1.4: +1 -7 lines
Diff to previous 1.4 , to selected 1.10
Removed outdated note
Tue Feb 22 22:51:23 2011 UTC (14 years, 10 months ago) by greg
Changes since 1.3: +10 -2 lines
Diff to previous 1.3 , to selected 1.10
Mon Feb 21 22:48:50 2011 UTC (14 years, 10 months ago) by greg
Changes since 1.2: +19 -3 lines
Diff to previous 1.2 , to selected 1.10
Sat Sep 4 15:19:28 2010 UTC (15 years, 3 months ago) by greg
Diff to previous 1.1 , to selected 1.10
Fixed example
Sat Sep 4 15:17:43 2010 UTC (15 years, 3 months ago) by greg
Diff to selected 1.10
Created genBSDF program
