root/radiance/ray/doc/man/man1/genBSDF.1
Sun Jan 20 02:07:16 2013 UTC (12 years, 3 months ago) by greg
Diff to previous 1.12
Added documentation for new gendaymtx tool
Sun Sep 2 15:33:14 2012 UTC (12 years, 8 months ago) by greg
Diff to previous 1.11
Wed Jun 20 00:48:54 2012 UTC (12 years, 10 months ago) by greg
Changes since 1.10: +2 -3 lines
Diff to previous 1.10
Fixed reference to -n option
Thu Jun 14 22:42:21 2012 UTC (12 years, 10 months ago) by greg
Changes since 1.9: +5 -5 lines
Diff to previous 1.9
Wed Aug 24 04:14:58 2011 UTC (13 years, 8 months ago) by greg
Diff to previous 1.8
Tue Aug 23 14:02:41 2011 UTC (13 years, 8 months ago) by greg
Diff to previous 1.7
Fri Jun 24 00:41:51 2011 UTC (13 years, 10 months ago) by greg
Changes since 1.6: +11 -6 lines
Diff to previous 1.6
Fri Jun 3 19:41:14 2011 UTC (13 years, 11 months ago) by greg
Changes since 1.5: +52 -1 lines
Diff to previous 1.5
Fri May 6 23:58:09 2011 UTC (14 years ago) by greg
Changes since 1.4: +1 -7 lines
Diff to previous 1.4
Removed outdated note
Tue Feb 22 22:51:23 2011 UTC (14 years, 2 months ago) by greg
Changes since 1.3: +10 -2 lines
Diff to previous 1.3
Mon Feb 21 22:48:50 2011 UTC (14 years, 2 months ago) by greg
Changes since 1.2: +19 -3 lines
Diff to previous 1.2
Sat Sep 4 15:19:28 2010 UTC (14 years, 8 months ago) by greg
Fixed example
Sat Sep 4 15:17:43 2010 UTC (14 years, 8 months ago) by greg
Created genBSDF program
