1 |
.\" RCSid "$Id$" |
2 |
.TH GCOMP 1 6/24/98 RADIANCE |
3 |
.SH NAME |
4 |
gcomp - do computations on a graph file. |
5 |
.SH SYNOPSIS |
6 |
.B gcomp |
7 |
8 |
.B -amilh |
9 |
10 |
.B +variable value .. |
11 |
12 |
.B file .. |
13 |
14 |
.SH DESCRIPTION |
15 |
.I Gcomp |
16 |
reads each graph |
17 |
.I file |
18 |
in sequence and computes the specified calculations. |
19 |
The type options are as follows: |
20 |
.TP 10n |
21 |
.BR \-n |
22 |
Print the name of each curve. |
23 |
.TP |
24 |
.BR \-a |
25 |
Print average and standard deviation of each curve. |
26 |
.TP |
27 |
.BR \-m |
28 |
Print minimum and maximum for each curve. |
29 |
.TP |
30 |
.BR \-i |
31 |
Print Romberg's approximation to the integral of each curve. |
32 |
.TP |
33 |
.BR \-l |
34 |
Print the slope, intercept, and correlation coefficient using |
35 |
the least squares method of linear regression. |
36 |
.TP |
37 |
.BR \-h |
38 |
Do not print a header in the output. |
39 |
.PP |
40 |
The calculations will be displayed as columns in the order |
41 |
they are specified on the command line. |
42 |
If no files are given, the standard input is read. |
43 |
.PP |
44 |
Variables can be set explicitly with |
45 |
.I +variable value |
46 |
options. |
47 |
The only truely useful variables for this program |
48 |
are xmin and xmax. |
49 |
They determine boundaries for the calculations. |
50 |
.SH EXAMPLE |
51 |
To compute the approximate integral of sin(x)/log(x) from 2 to 4: |
52 |
.nf |
53 |
gcomp -i |
54 |
A(x)=sin(x)/log(x); |
55 |
Anpoints=100; |
56 |
xmin=2; |
57 |
xmax=4; |
58 |
^D |
59 |
.fi |
60 |
.SH AUTHOR |
61 |
Greg Ward |
62 |
.SH BUGS |
63 |
Only the y values can be used for computation. |
64 |
.SH "SEE ALSO" |
65 |
bgraph(1), calc(1), dgraph(1), igraph(1) |
