| 1 |
.\" RCSid "$Id: gcomp.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
| 2 |
.TH GCOMP 1 6/24/98 RADIANCE
| 3 |
.SH NAME
| 4 |
gcomp - do computations on a graph file.
| 5 |
.SH SYNOPSIS
| 6 |
.B gcomp
| 7 |
| 8 |
.B -amilh
| 9 |
| 10 |
.B +variable value ..
| 11 |
| 12 |
.B file ..
| 13 |
| 14 |
.SH DESCRIPTION
| 15 |
.I Gcomp
| 16 |
reads each graph
| 17 |
.I file
| 18 |
in sequence and computes the specified calculations.
| 19 |
The type options are as follows:
| 20 |
.TP 10n
| 21 |
.BR \-n
| 22 |
Print the name of each curve.
| 23 |
.TP
| 24 |
.BR \-a
| 25 |
Print average and standard deviation of each curve.
| 26 |
.TP
| 27 |
.BR \-m
| 28 |
Print minimum and maximum for each curve.
| 29 |
.TP
| 30 |
.BR \-i
| 31 |
Print Romberg's approximation to the integral of each curve.
| 32 |
.TP
| 33 |
.BR \-l
| 34 |
Print the slope, intercept, and correlation coefficient using
| 35 |
the least squares method of linear regression.
| 36 |
.TP
| 37 |
.BR \-h
| 38 |
Do not print a header in the output.
| 39 |
.PP
| 40 |
The calculations will be displayed as columns in the order
| 41 |
they are specified on the command line.
| 42 |
If no files are given, the standard input is read.
| 43 |
.PP
| 44 |
Variables can be set explicitly with
| 45 |
.I +variable value
| 46 |
options.
| 47 |
The only truely useful variables for this program
| 48 |
are xmin and xmax.
| 49 |
They determine boundaries for the calculations.
| 50 |
.SH EXAMPLE
| 51 |
To compute the approximate integral of sin(x)/log(x) from 2 to 4:
| 52 |
.nf
| 53 |
gcomp -i
| 54 |
A(x)=sin(x)/log(x);
| 55 |
Anpoints=100;
| 56 |
xmin=2;
| 57 |
xmax=4;
| 58 |
^D
| 59 |
.fi
| 60 |
.SH AUTHOR
| 61 |
Greg Ward
| 62 |
.SH BUGS
| 63 |
Only the y values can be used for computation.
| 64 |
.SH "SEE ALSO"
| 65 |
bgraph(1), dgraph(1), icalc(1), igraph(1)
