root/radiance/ray/doc/man/man1/gcomp.1
Revision: 1.4
Committed: Tue Sep 4 17:36:40 2007 UTC (17 years, 8 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad3R9, rad4R2P1, rad5R3, HEAD
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
1 .\" RCSid "$Id: gcomp.1,v 1.3 2004/01/01 19:31:44 greg Exp $"
2 .TH GCOMP 1 6/24/98 RADIANCE
3 .SH NAME
4 gcomp - do computations on a graph file.
5 .SH SYNOPSIS
6 .B gcomp
7 [
8 .B -amilh
9 ][
10 .B +variable value ..
11 ][
12 .B file ..
13 ]
14 .SH DESCRIPTION
15 .I Gcomp
16 reads each graph
17 .I file
18 in sequence and computes the specified calculations.
19 The type options are as follows:
20 .TP 10n
21 .BR \-n
22 Print the name of each curve.
23 .TP
24 .BR \-a
25 Print average and standard deviation of each curve.
26 .TP
27 .BR \-m
28 Print minimum and maximum for each curve.
29 .TP
30 .BR \-i
31 Print Romberg's approximation to the integral of each curve.
32 .TP
33 .BR \-l
34 Print the slope, intercept, and correlation coefficient using
35 the least squares method of linear regression.
36 .TP
37 .BR \-h
38 Do not print a header in the output.
39 .PP
40 The calculations will be displayed as columns in the order
41 they are specified on the command line.
42 If no files are given, the standard input is read.
43 .PP
44 Variables can be set explicitly with
45 .I +variable value
46 options.
47 The only truely useful variables for this program
48 are xmin and xmax.
49 They determine boundaries for the calculations.
50 .SH EXAMPLE
51 To compute the approximate integral of sin(x)/log(x) from 2 to 4:
52 .nf
53 gcomp \-i
54 A(x)=sin(x)/log(x);
55 Anpoints=100;
56 xmin=2;
57 xmax=4;
58 ^D
59 .fi
60 .SH AUTHOR
61 Greg Ward
62 .SH BUGS
63 Only the y values can be used for computation.
64 .SH "SEE ALSO"
65 bgraph(1), dgraph(1), icalc(1), igraph(1)
