--- ray/doc/man/man1/findglare.1 2003/12/09 15:59:06 1.2 +++ ray/doc/man/man1/findglare.1 2004/01/01 19:31:44 1.3 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: findglare.1,v 1.2 2003/12/09 15:59:06 greg Exp $" +.\" RCSid "$Id: findglare.1,v 1.3 2004/01/01 19:31:44 greg Exp $" .TH FINDGLARE 1 11/15/93 RADIANCE .SH NAME findglare - locate glare sources in a RADIANCE scene @@ -54,7 +54,7 @@ option is used -- see below). Note that the picture file must contain correct view specifications, as maintained by .I rpict(1), -.I rview(1), +.I rvu(1), .I pfilt(1) and .I pinterp(1). @@ -112,7 +112,7 @@ It usually works best to use the 'l' command within .I ximage(1) to decide what this value should be. Alternatively, one can use the 't' command within -.I rview(1). +.I rvu(1). The idea is to pick a threshold that is well above the average level but smaller than the source areas. .PP @@ -157,4 +157,4 @@ Work on this program was initiated and sponsored by th group at EPFL in Switzerland. .SH "SEE ALSO" getinfo(1), glare(1), glarendx(1), pfilt(1), rpict(1), rtrace(1), -rview(1), xglaresrc(1), ximage(1) +rvu(1), xglaresrc(1), ximage(1)
