root/Development/ray/doc/man/man1/findglare.1
Revision: 1.1
Committed: Tue Mar 11 19:20:21 2003 UTC (22 years, 7 months ago) by greg
Added documentation to repository
1 .\" RCSid "$Id"
2 .TH FINDGLARE 1 11/15/93 RADIANCE
3 .SH NAME
4 findglare - locate glare sources in a RADIANCE scene
5 .SH SYNOPSIS
6 .B findglare
7 [
8 .B \-v
9 ][
10 .B "\-ga angles"
11 ][
12 .B "\-t threshold"
13 ][
14 .B "\-r resolution"
15 ][
16 .B \-c
17 ][
18 .B "\-p picture"
19 ][
20 view options
21 ] [[
22 rtrace options
23 ]
24 .B octree
25 ]
26 .SH DESCRIPTION
27 .I Findglare
28 locates sources of glare in a specific set of horizontal directions
29 by computing luminance samples from a RADIANCE picture and/or octree.
30 .I Findglare
31 is intended primarily as a preprocessor for glare calculation
32 programs such as
33 .I glarendx(1),
34 and is usually accessed through the executive script
35 .I glare(1).
36 .PP
37 If only an octree is given,
38 .I findglare
39 calls rtrace to compute the samples it needs.
40 If both an octree and a picture are specified,
41 .I findglare
42 calls rtrace only for samples that are outside the frame of
43 the picture.
44 If
45 .I findglare
46 does not have an octree and the picture does not completely cover
47 the area of interest, a warning will be issued and everything
48 outside the picture will be treated as if it were black.
49 It is preferable to use a picture with a fisheye view
50 and a horizontal and vertical size of at least 180 degrees (more
51 horizontally if the
52 .I \-ga
53 option is used -- see below).
54 Note that the picture file must contain correct view specifications,
55 as maintained by
56 .I rpict(1),
57 .I rview(1),
58 .I pfilt(1)
59 and
60 .I pinterp(1).
61 Specifically,
62 .I findglare
63 will not work on pictures processed by
64 .I pcompos(1)
65 or
66 .I pcomb(1).
67 It is also essential to give the proper rtrace options when an
68 octree is used so that the calculated luminance values are correct.
69 .PP
70 The output of
71 .I findglare
72 is a list of glare source directions, solid angles and average
73 luminances, plus a list of indirect vertical illuminance values
74 as a function of angle.
75 Angles are measured in degrees from the view center,
76 with positive angles to the left and negative angles to the right.
77 .PP
78 By default,
79 .I findglare
80 only computes glare sources and indirect vertical illuminance
81 for the given view (taken from the picture if none is specified).
82 If the view direction is not horizontal to begin with
83 (ie. perpendicular to the view up vector),
84 .I findglare
85 will substitute the closest horizontal direction as its view
86 center.
87 The
88 .I \-ga
89 option can be used to specify a set of directions to consider
90 about the center of view.
91 This specification is given by a starting angle, ending angle, and
92 step angle like so:
93 .nf
94 start-end:step
95 .fi
96 All angles must be whole degrees within the range 1 to 180.
97 Multiple angle ranges may be separated by commas, and individual
98 angles may be given without the ending and step angles.
99 Note that
100 .I findglare
101 will complain if the same angle is given twice either explicitly
102 or implicitly by two ranges.
103 .PP
104 .I Findglare
105 normally identifies glare sources as directions that are
106 brighter than 7 times the average luminance level.
107 It is possible to override this determination by giving an
108 explicit luminance threshold with the
109 .I \-t
110 option.
111 It usually works best to use the 'l' command within
112 .I ximage(1)
113 to decide what this value should be.
114 Alternatively, one can use the 't' command within
115 .I rview(1).
116 The idea is to pick a threshold that is well above the average level
117 but smaller than the source areas.
118 .PP
119 If the sources in the scene are small, it may be necessary to
120 increase the default sample resolution of
121 .I findglare(1)
122 using the
123 .I \-r
124 option.
125 The default resolution is 150 vertical samples and a proportional number
126 of horizontal samples.
127 If besides being small, the sources are not much brighter than the
128 threshold, the
129 .I \-c
130 flag should be used to override
131 .I findglare's
132 default action of absorbing small sources it deems to be
133 insignificant.
134 .PP
135 The
136 .I \-v
137 flag switches on verbose mode, where
138 .I findglare
139 reports its progress during the calculation.
140 .SH EXAMPLE
141 To calculate the glare sources in the image "scene.pic":
142 .IP "" .2i
143 findglare -p scene.pic > scene.glr
144 .PP
145 To compute the Guth visual comfort probability from this result:
146 .IP "" .2i
147 glarendx -t guth_vcp scene.glr
148 .PP
149 To compute the glare for a set of angles around the view "good.vp"
150 from the octree "scene.oct" using an ambient level of .1:
151 .IP "" .2i
152 findglare -vf good.vp -ga 10-60:10 -av .1 .1 .1 scene.oct > scene.glr
153 .SH AUTHOR
154 Greg Ward
155 .SH ACKNOWLEDGEMENT
156 Work on this program was initiated and sponsored by the LESO
157 group at EPFL in Switzerland.
158 .SH "SEE ALSO"
159 getinfo(1), glare(1), glarendx(1), pfilt(1), rpict(1), rtrace(1),
160 rview(1), xglaresrc(1), ximage(1)
