root/radiance/ray/doc/man/man1/falsecolor.1
Revision: 1.3
Committed: Mon Mar 8 21:39:31 2004 UTC (20 years, 1 month ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1, rad3R8
Changes since 1.2: +12 -1 lines
1 .\" RCSid "$Id: falsecolor.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 .TH FALSECOLOR 1 11/15/93 RADIANCE
3 .SH NAME
4 falsecolor - make a false color RADIANCE picture
5 .SH SYNOPSIS
6 .B falsecolor
7 [
8 .B "\-i input"
9 ][
10 .B "\-p picture"
11 ][
12 .B "\-cb | \-cl"
13 ][
14 .B \-e
15 ][
16 .B "\-s scale"
17 ][
18 .B "\-l label"
19 ][
20 .B "\-n ndivs"
21 ][
22 .B "\-lw lwidth"
23 ][
24 .B "\-lh lheight"
25 ][
26 .B "\-log decades"
27 ][
28 .B "\-m mult"
29 ][
30 .B "\-r redv"
31 ][
32 .B "\-g grnv"
33 ][
34 .B "\-b bluv"
35 ]
36 .SH DESCRIPTION
37 .I Falsecolor
38 produces a false color picture for lighting analysis.
39 Input is a rendered Radiance picture.
40 .PP
41 By default, luminance is displayed on a linear scale from 0 to 1000 nits, where
42 dark areas are blue and brighter areas move through the spectrum to red.
43 A different scale can be given with the
44 .I \-s
45 option.
46 The default multiplier is 179, which converts from radiance or irradiance
47 to luminance or illuminance, respectively.
48 A different multiplier can be given with
49 .I \-m
50 to get daylight factors or whatever.
51 For a logarithmic rather than a linear mapping, the
52 .I \-log
53 option can be used, where
54 .I decades
55 is the number of decades below the maximum scale desired.
56 .PP
57 A legend is produced for the new image with a label given by the
58 .I \-l
59 option.
60 The default label is "Nits", which is appropriate for standard Radiance
61 images.
62 If the
63 .I -i
64 option of
65 .I rpict(1)
66 was used to produce the image, then the appropriate label would be "Lux".
67 .PP
68 If contour lines are desired rather than just false color, the
69 .I \-cl
70 option can be used.
71 These lines can be placed over another Radiance picture using the
72 .I -p
73 option.
74 If the input picture is given with
75 .I \-ip
76 instead of
77 .I \-i,
78 then it will be used both as the source of values and as the picture
79 to overlay with contours.
80 The
81 .I \-cb
82 option produces contour bands instead of lines, where the thickness of
83 the bands is related to the rate of change in the image.
84 The
85 .I \-n
86 option can be used to change the number of contours (and corresponding
87 legend entries) from the default value of 8.
88 The
89 .I \-lw
90 and
91 .I \-lh
92 options may be used to change the legend dimensions from the default width
93 and height of 100x200.
94 A value of zero in either eliminates the legend in the output.
95 .PP
96 The
97 .I \-e
98 option causes extrema points to be printed on the brightest and
99 darkest pixels of the input picture.
100 .PP
101 The remaining options,
102 .I "\-r, \-g,"
103 and
104 .I \-b
105 are for changing the mapping of values to colors.
106 These are expressions of the variable
107 .I v,
108 where
109 .I v
110 varies from 0 to 1.
111 These options are not recommended for the casual user.
112 .PP
113 If no
114 .I \-i
115 or
116 .I \-ip
117 option is used, input is taken from the standard input.
118 The output image is always written to standard output, which should
119 be redirected.
120 .SH EXAMPLES
121 To create a false color image directly from
122 .I rpict(1):
123 .IP "" .2i
124 rpict -vf default.vp scene.oct | falsecolor > scene.pic
125 .PP
126 To create a logarithmic contour plot of illuminance values on a
127 Radiance image:
128 .IP "" .2i
129 rpict -i -vf default.vp scene.oct > irrad.pic
130 .br
131 rpict -vf default.vp scene.oct > rad.pic
132 .br
133 falsecolor -i irrad.pic -p rad.pic -cl -log 2 -l Lux > lux.pic
134 .SH AUTHOR
135 Greg Ward
136 .SH ACKNOWLEDGEMENT
137 Work on this program was initiated and sponsored by the LESO
138 group at EPFL in Switzerland.
139 .SH "SEE ALSO"
140 getinfo(1), pcomb(1), pcompos(1), pextrem(1), pfilt(1), pflip(1), protate(1),
141 psign(1), rpict(1), ximage(1)
