root/radiance/ray/doc/man/man1/evalglare.1
Revision: 1.1
Committed: Wed Aug 12 23:07:59 2015 UTC (9 years, 8 months ago) by greg
1 .\" RCSid $Id$
2 .TH EVALGLARE 1 7/30/15 RADIANCE
3 .SH NAME
4 .PP
5 evalglare \- determines and evaluates glare sources within a 180 degree
6 fish\-eye\-image, given in the RADIANCE RGBE (.hdr) image format.
7 .SH SYNOPSIS
8 .PP
9 evalglare [\-s] [\-y] [\-Y value] [\-B angle] [\-b factor] [\-c checkfile]
10 [\-t xpos ypos angle] [\-T xpos ypos angle] [\-d] [\-r angle] [\[en]i
11 Ev] [\[en]I Ev yfill_max y_fill_min ] [\-v] [\-V] [\[en]g type] [\-G
12 type] [\-u r g b ] [\-vf viewfile] [\-vtt ] [\-vv vertangle] [\-vh horzangle] hdrfile
13 .PP
14 or
15 .PP
16 hdr|evalglare [\-s] [\-y] [\-Y value] [\-B angle] [\-b factor] [\-c
17 checkfile] [\-t xpos ypos angle][\-T xpos ypos angle] [\-d] [\-r angle]
18 [\[en]i Ev] [\[en]I Ev yfill_max y_fill_min ] [\-v] [\-V] ] [\[en]g
19 type] [\-G type] [\-u r g b ] [\-vf viewfile][\-vtt ] [\-vv vertangle] [\-vh
20 horzangle]
21 .SH DESCRIPTION
22 .PP
23 evalglare determines and evaluates glare sources within a 180 degree
24 fish\-eye\-image, given in the RADIANCE image format (.pic or .hdr).
25 The image should be rendered as fish eye (e.g.
26 using the \-vta or \[en]vth option) using 180 degree for the horizontal and
27 vertical view angle (\-vv =180, \-vh=180).
28 Due to performance reasons of the evalglare code, the image should be
29 smaller than 1200x1200 pixels. The recommended size is 800x800 pixels.
30 In the first step, the program uses a given threshold to determine all
31 glare sources.
32 Three different threshold methods are implemented.
33 The recommended method is to define a task area by \-t or \-T option.
34 In this (task) area the average luminance is calculated Each pixel,
35 exceeding this value multiplied by the \-b factor [default=5] is treated
36 as a potential glare source.
37 The other two methods are described below [see \-b].
38 In the second step the program tries to merge glare source pixels to one
39 glare source, when they are placed nearby each other.
40 This merging is performed in\-between a search area, given by an opening
41 angle (\-r, default =0.2 in radiant).
42 If a check file is written (\-c fname), the detected glare sources will
43 be colored to different colors where the rest of the image is set to
44 gray.
45 The luminance values of all pixels are kept to the initial value.
46 The color is chosen by chance, no significance is given by the color.
47 To enable a unform coloring for all glare sources, the \-u option can be used.
48 Luminance peaks can be extracted to separate glare sources by using the
49 \-y or \-Y value option (default since version v0.9c).
50 Default value (\-y) is 50000 cd/m2, can be changed by using \-Y value.
51 A smoothing option (\-s) counts initial non\-glare source pixels to
52 glare sources, when they are surrounded by a glare source.
53 .PP
54 The program calculates the daylight glare probability (DGP) as well as
55 other glare indexes (dgi,ugr,vcp,cgi) to the standard output.
56 The DGP describes the fraction of persons disturbed, caused by glare from
57 daylight (range 0...1).
58 Values lower than 0.2 are out of the range of the user assessment tests,
59 where the program is based on and should be interpreted carefully.
60 A low light correction is applied to the DGP when the vertical illumiance is lower than 500 lux.
61 By the use of \-g or \-G the field of view is cut according the the definition of Guth.
62 The option \-B angle (in rad) calculates the average luminance of a horizontal band.
63 In the case of non\-180 degree images, an external measured illuminance value
64 can be provided by using the \[en]i or \[en]I option.
65 The use of the \[en]I option enables the filling up of images, which are
66 horizontally cut.
67 The age correction is not supported any more and disabled.
68 If the option \-d is used, all found glare sources and their position,
69 size, and luminance values are printed to the standard output, too.
70 The last line gives following values: 1.
71 dgp, 2.
72 average luminance of image,3.
73 vertical eye illuminance, 4.
74 background luminance, 5.
75 direct vertical eye illuminance, 6.
76 dgi, 7.
77 ugr, 8.
78 vcp, 9.
79 cgi, 10.
80 average luminance of all glare sources, 11.
81 sum of solid angles of all glare sources 12.
82 Veiling luminance (disability glare) 13.
83 x\-direction of glare source 14.
84 y\-direction of glare source 15.
85 z\-direction of glare source 16.
86 band luminance
87 .PP
88 The program is based on the studies from J.
89 Christoffersen and J.
90 Wienold (see \“Evaluation methods and development of a new glare
91 prediction model for daylight environments with the use of CCD cameras
92 and RADIANCE\“ , Energy and Buildings, 2006.
93 More details can be also found in following issertation: J.
94 Wienold, \“Daylight glare in offices\”, Fraunhofer IRB, 2010.
95 URL for download:
96 http://publica.fraunhofer.de/eprints/urn:nbn:de:0011\-n\-1414579.pdf
97 .TP
98 .B \-B \f[I]angle\f[],
99 Calculate average luminance of a horizontal band. The angle is in rad. Output only when using the \-d option.
100 .RS
101 .RE
102 .TP
103 .B \-b \f[I]factor\f[],
104 Threshold factor; if factor >100, it is used as constant threshold in
105 cd/m2, regardless if a task position is given or not if factor is <= 100
106 and a task position is given, this factor multiplied by the average task
107 luminance will be used as threshold for detecting the glare sources if
108 factor is <= 100 and no task position is given, this factor multiplied
109 by the average luminance in the entire picture will be used as threshold
110 for detecting the glare sources, default value=5.
111 .RS
112 .RE
113 .TP
114 .B \-c \f[I]fname\f[]
115 writes a checkfile in the RADIANCE picture format
116 .RS
117 .RE
118 .TP
119 .B \-d
120 enables detailed output (default: disabled)
121 .RS
122 .RE
123 .TP
124 .B \-g \f[I]type\f[]
125 cut field of view according to Guth, write checkfile specified by \[en]c
126 and exit without any glare evaluation.
127 type=1: total field of view type=2: field of view seen by both eyes
128 .RS
129 .RE
130 .TP
131 .B \-G \f[I]type\f[]
132 cut field of view according to Guth, perform glare evaluation.
133 type=1: total field of view type=2: field of view seen by both eyes
134 .RS
135 .RE
136 .TP
137 .B \-i \f[I]Ev\f[]
138 The vertical illuminance is measured externally.
139 This value will be used for calculating the dgp.
140 .RS
141 .RE
142 .TP
143 .B \-I \f[I]Ev y_max y_min\f[]
144 The vertical illuminance is measured externally.
145 This value will be used for calculating the dgp.
146 Below y_min and above y_max, the picture is filled up by the last known
147 value.
148 This option should be used, when the provided picture is cut
149 horizontally.
150 .RS
151 .RE
152 .TP
153 .B \-r \f[I]angle\f[]
154 search radius (angle in radiant) between pixels, where evalglare tries
155 to merge glare source pixels to the same glare source (default value:
156 0.2 radiant)
157 .RS
158 .RE
159 .TP
160 .B \-s
161 enables smoothing function (default: disabled)
162 .RS
163 .RE
164 .TP
165 .B \-t \f[I]xpos ypos angle\f[]
166 definition of task position in x and y coordinates, and its opening
167 angle in radiant
168 .RS
169 .RE
170 .TP
171 .B \-T \f[I]xpos ypos angle\f[]
172 same as \-t, except that the task area is colored bluish in the
173 checkfile
174 .RS
175 .RE
176 .TP
177 .B \-u \f[I]r g b\f[]
178 color glare sources unfiformly when writing check file (implies \-c option). Color given in r g b.
179 .RS
180 .RE
181 .TP
182 .B \-v
183 show version of evalglare and exit
184 .RS
185 .RE
186 .TP
187 .B \-V
188 Just calculate the vertical illuminance and exit
189 .RS
190 .RE
191 .TP
192 .B \-x
193 disable peak extraction
194 .RS
195 .RE
196 .TP
197 .B \-y
198 enables peak extraction (default: enabled)
199 .RS
200 .RE
201 .TP
202 .B \-Y \f[I]value\f[]
203 enables peak extraction with value as threshold for extracted peaks
204 .RS
205 .RE
206 .PP
207 In case, the view settings within the image are missing or are not valid
208 (e.g.
210 command line options.
211 As soon as view options are set within the command line, view options
212 within the image are ignored.
213 The view options are implemented according to the RADIANCE definition
214 (please read man page of rpict for details):
215 .TP
216 .B \-vtt
217 Set view type to t (for fish\-eye views, please use \[en]vta or \[en]vth
218 preferably)
219 .RS
220 .RE
221 .TP
222 .B \-vf \f[I]viewfile\f[]
223 Get view parameters from file
224 .RS
225 .RE
226 .TP
227 .B \-vv \f[I]val\f[]
228 Set the view vertical size to val
229 .RS
230 .RE
231 .TP
232 .B \-vh \f[I]val\f[]
233 Set the view horizontal size to \f[I]val\f[]
234 .RS
235 .RE
236 .SH ACKNOWLEDGEMENTS
237 .PP
238 The evalglare program was developped by Jan Wienold originally at the Fraunhofer
239 Institute for Solar Energy Systems in Freiburg, Germany. It is further developped
240 and maintained by the same author at EPFL, Lausanne, Switzerland.
241 .PP
242 The author would like to thank C.
243 Reetz for his generous help and his support of providing libraries for
244 the program.
245 The EU Commission supported this work as part of the EU project “Energy
246 and Comfort Control for Building management systems” (ECCO\-Build,
247 Contract N°: ENK6\-CT\-2002\-00656).
248 .PP
249 The dfg\-foundation (contract WI 1304/7\-2 ) supported the research for
250 the extension of evalglare for low\-light scenes.
251 .SH AUTHORS
252 Jan Wienold.
