| 1 |
greg |
1.3 |
.\" RCSid "$Id: ev.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
| 2 |
greg |
1.1 |
.TH EV 1 10/28/96 RADIANCE
| 3 |
.SH NAME
| 4 |
ev - evaluate expressions
| 5 |
.SH SYNOPSIS
| 6 |
.B ev 'expr' ..
| 7 |
.SH DESCRIPTION
| 8 |
.I Ev
| 9 |
evaluates expressions given on the command line, and sends the
| 10 |
results to the standard output, one per line.
| 11 |
An expression contains real numbers, function calls,
| 12 |
and the following operators:
| 13 |
.PP
| 14 |
| 15 |
.PP
| 16 |
Operators are evaluated left to right, except '^',
| 17 |
which is right associative.
| 18 |
Powers have the highest precedence; multiplication and
| 19 |
division are evaluated before addition and subtraction.
| 20 |
Expressions can be grouped with parentheses.
| 21 |
All values are double precision real.
| 22 |
.PP
| 23 |
The following library of functions is available:
| 24 |
.TP 10n
| 25 |
.BR "if(cond, then, else)"
| 26 |
if cond is greater than zero,
| 27 |
then is evaluated, otherwise else is evaluated.
| 28 |
.TP
| 29 |
.BR "select(N, a1, a2, ..)"
| 30 |
return aN (N is rounded to the nearest integer).
| 31 |
If
| 32 |
.I N
| 33 |
is zero, the number of available arguments is returned.
| 34 |
.TP
| 35 |
.BR "rand(x)"
| 36 |
compute a random number between 0 and 1 based on x.
| 37 |
.TP
| 38 |
.BR "floor(x)"
| 39 |
return largest integer not greater than x.
| 40 |
.TP
| 41 |
.BR "ceil(x)"
| 42 |
return smallest integer not less than x.
| 43 |
.TP
| 44 |
.BR "sqrt(x)"
| 45 |
return square root of x.
| 46 |
.TP
| 47 |
.BR "exp(x)"
| 48 |
compute e to the power of x (e approx = 2.718281828).
| 49 |
.TP
| 50 |
.BR "log(x)"
| 51 |
compute the logarithm of x to the base e.
| 52 |
.TP
| 53 |
.BR "log10(x)"
| 54 |
compute the logarithm of x to the base 10.
| 55 |
.TP
| 56 |
.BR "sin(x), cos(x), tan(x)"
| 57 |
trigonometric functions.
| 58 |
.TP
| 59 |
.BR "asin(x), acos(x), atan(x)"
| 60 |
inverse trigonometric functions.
| 61 |
.TP
| 62 |
.BR "atan2(y, x)"
| 63 |
inverse tangent of y/x (range -pi to pi).
| 64 |
.SH EXAMPLE
| 65 |
To pass the square root of two and the sine of .5 to a program:
| 66 |
.IP "" .2i
| 67 |
program `ev 'sqrt(2)' 'sin(.5)'`
| 68 |
.SH AUTHOR
| 69 |
Greg Ward
| 70 |
.SH "SEE ALSO"
| 71 |
greg |
1.3 |
icalc(1), rcalc(1)
