1 |
.\" RCSid "$Id: dgraph.1,v 1.2 2003/12/09 15:59:06 greg Exp $" |
2 |
.TH DGRAPH 1 6/24/98 RADIANCE |
3 |
.SH NAME |
4 |
dgraph - do a set of graphs to a dumb terminal |
5 |
.SH SYNOPSIS |
6 |
.B dgraph |
7 |
8 |
.B -w width |
9 |
10 |
.B -l length |
11 |
12 |
.B +variable value .. |
13 |
14 |
.B file .. |
15 |
16 |
.SH DESCRIPTION |
17 |
.I Dgraph |
18 |
reads each graph |
19 |
.I file |
20 |
in sequence and converts it to a character plot |
21 |
displayable on any ascii device. |
22 |
If no files are given, the standard input is read. |
23 |
.PP |
24 |
Across the top of the plot, the extrema are printed. |
25 |
This is the only indication of the axis size. |
26 |
Curves are represented with their respective letter ('A' for |
27 |
curve A, etc.) at each point. |
28 |
Where two or more curves cross, a number is shown instead. |
29 |
.PP |
30 |
The size of the output array can be specified as a |
31 |
certain |
32 |
.I width |
33 |
and |
34 |
.I length. |
35 |
The default size is 79 by 22. |
36 |
.PP |
37 |
Variables can be set explicitly with |
38 |
.I +variable value |
39 |
options. |
40 |
See bgraph(1) for details. |
41 |
.SH EXAMPLE |
42 |
To get a quick glimpse of the sine function from 0 to 4. |
43 |
.nf |
44 |
dgraph |
45 |
A(x)=sin(x) |
46 |
Anpoints=100 |
47 |
xmin=0 |
48 |
xmax=4 |
49 |
^D |
50 |
.fi |
51 |
.SH AUTHOR |
52 |
Greg Ward |
53 |
.SH BUGS |
54 |
There is no mechanism provided for undefining a variable. |
55 |
.SH "SEE ALSO" |
56 |
bgraph(1), gcomp(1), icalc(1), igraph(1) |
