--- ray/doc/man/man1/dctimestep.1 2014/02/08 01:28:05 1.8 +++ ray/doc/man/man1/dctimestep.1 2014/05/30 00:00:54 1.9 @@ -1,4 +1,4 @@ -.\" RCSid $Id: dctimestep.1,v 1.8 2014/02/08 01:28:05 greg Exp $" +.\" RCSid $Id: dctimestep.1,v 1.9 2014/05/30 00:00:54 greg Exp $" .TH DCTIMESTEP 1 12/09/09 RADIANCE .SH NAME dctimestep - compute annual simulation time-step(s) via matrix multiplication @@ -9,7 +9,7 @@ dctimestep - compute annual simulation time-step(s) vi ][ .B "\-o ospec" ][ -.B "\-i{f|d} +.B "\-i{f|d|h} ][ .B "\-o{f|d} ] @@ -24,7 +24,7 @@ dctimestep - compute annual simulation time-step(s) vi ][ .B "\-o ospec" ][ -.B "\-i{f|d} +.B "\-i{f|d|h} ][ .B "\-o{f|d} ] @@ -79,9 +79,12 @@ or .I \-id option may be used to specify that sky data is in float or double format, respectively, which is more efficient for large matrices. -(Note that binary double data may not be read from stdin.)\0 +The +.I \-ih +option says to check the header to determine the data type. +(Note that binary double data may not be read from stdin without a header.)\0 .PP -Sent to the standard output of +The standard output of .I dctimestep is either a color vector with as many RGB triplets as there are rows in the View matrix, or a combined @@ -107,6 +110,9 @@ The columns do not need to be given on the same line, so long as the number of values totals 3*Nsteps*Npatches. Input starts from the first patch at the first time step, then the first patch at the second time step, and so on. +If the input matrix has a header, then you may use +.I \-n 0 +to get the number of columns from the header rather than specifying it. .PP The .I \-o
