--- ray/doc/man/man1/dctimestep.1 2023/12/12 16:31:45 1.20 +++ ray/doc/man/man1/dctimestep.1 2025/03/21 17:33:49 1.21 @@ -1,4 +1,4 @@ -.\" RCSid $Id: dctimestep.1,v 1.20 2023/12/12 16:31:45 greg Exp $" +.\" RCSid $Id: dctimestep.1,v 1.21 2025/03/21 17:33:49 greg Exp $" .TH DCTIMESTEP 1 12/09/09 RADIANCE .SH NAME dctimestep - compute annual simulation time-step(s) via matrix multiplication @@ -137,6 +137,7 @@ on the number of rows in the result vectors. A header will normally be produced on the output, unless the .I \-h option is specified. +Default output format is ASCII text. The .I \-of, .I \-od, @@ -144,6 +145,9 @@ or .I \-oc option may be used to specify IEEE float, double, or RGBE (picture) output data, respectively. +The +.I \-oc +option is set automatically if input is a collection of RGBE or XYZE pictures. .SH EXAMPLES To compute workplane illuminances at 3:30pm on Feb 10th: .IP "" .2i @@ -196,8 +200,10 @@ output option with since matrix operations are carried out using 32-bit "float" values. This take less memory, but can also be less accurate than an equivalent invocation of -.I rmtxop(1), -which performs all operations on 64-bit "double" values. +.I rmtxop(1) +or +.I rcomb(1), +which perform all operations on 64-bit "double" values. .SH AUTHOR Greg Ward .SH "SEE ALSO"
