1 |
greg |
1.18 |
.\" RCSid $Id: dctimestep.1,v 1.17 2022/03/11 02:27:02 greg Exp $" |
2 |
greg |
1.1 |
.TH DCTIMESTEP 1 12/09/09 RADIANCE |
3 |
.SH NAME |
4 |
greg |
1.4 |
dctimestep - compute annual simulation time-step(s) via matrix multiplication |
5 |
greg |
1.1 |
.SH SYNOPSIS |
6 |
.B dctimestep |
7 |
greg |
1.4 |
8 |
.B "\-n nsteps" |
9 |
10 |
greg |
1.10 |
.B "\-h" |
11 |
12 |
greg |
1.4 |
.B "\-o ospec" |
13 |
greg |
1.5 |
14 |
greg |
1.17 |
.B "\-x xres" |
15 |
16 |
.B "\-y yres" |
17 |
18 |
greg |
1.10 |
.B "\-i{f|d} |
19 |
greg |
1.8 |
20 |
greg |
1.16 |
.B "\-o{f|d|c} |
21 |
greg |
1.4 |
22 |
greg |
1.2 |
.B DCspec |
23 |
24 |
greg |
1.4 |
.B skyf |
25 |
greg |
1.2 |
26 |
.br |
27 |
.B dctimestep |
28 |
greg |
1.4 |
29 |
.B "\-n nsteps" |
30 |
31 |
greg |
1.10 |
.B "\-h" |
32 |
33 |
greg |
1.4 |
.B "\-o ospec" |
34 |
greg |
1.5 |
35 |
greg |
1.10 |
.B "\-i{f|d} |
36 |
greg |
1.8 |
37 |
.B "\-o{f|d} |
38 |
greg |
1.4 |
39 |
greg |
1.1 |
.B Vspec |
40 |
greg |
1.12 |
.B Tbsdf |
41 |
greg |
1.1 |
.B Dmat.dat |
42 |
43 |
greg |
1.4 |
.B skyf |
44 |
greg |
1.1 |
45 |
.SH DESCRIPTION |
46 |
.I Dctimestep |
47 |
greg |
1.2 |
has two invocation forms. |
48 |
In the first form, |
49 |
.I dctimestep |
50 |
is given a daylight coefficient specification and an optional sky |
51 |
greg |
1.4 |
vector or matrix, which may be read from the standard input if unspecified. |
52 |
The daylight coefficients are multiplied against these sky values |
53 |
and the results are written to the standard output. |
54 |
greg |
1.18 |
This may be a list of color values or a combined Radiance picture, |
55 |
greg |
1.2 |
as explained below. |
56 |
.PP |
57 |
In the second form, |
58 |
.I dctimestep |
59 |
greg |
1.1 |
takes four input files, forming a matrix expression. |
60 |
greg |
1.18 |
The first argument is the View matrix that specifies how window output |
61 |
greg |
1.1 |
directions are related to some set of measured values, such as an array of |
62 |
greg |
1.18 |
illuminance points or pictures. |
63 |
greg |
1.1 |
This matrix is usually computed by |
64 |
greg |
1.12 |
.I rfluxmtx(1) |
65 |
or |
66 |
greg |
1.3 |
.I rcontrib(1) |
67 |
greg |
1.1 |
for a particular set of windows or skylight openings. |
68 |
The second argument is the window transmission matrix, or BSDF, given as |
69 |
greg |
1.12 |
a matrix or a standard XML description. |
70 |
greg |
1.1 |
The third argument is the Daylight matrix file that defines how sky patches |
71 |
relate to input directions on the same opening. |
72 |
This is usually computed using |
73 |
greg |
1.12 |
.I rfluxmtx |
74 |
with separate runs for each window or skylight orientation. |
75 |
greg |
1.6 |
The last file is the sky contribution vector or matrix, |
76 |
typically computed by |
77 |
.I genskyvec(1) |
78 |
or |
79 |
.I gendaymtx(1), |
80 |
and may be passed on the standard input. |
81 |
greg |
1.10 |
.PP |
82 |
If the input sky data lacks a header, the |
83 |
.I \-n |
84 |
option may be used to indicate the number of time steps, which |
85 |
will be 1 for a sky vector. |
86 |
greg |
1.13 |
The sky input file must otherwise contain the number of |
87 |
greg |
1.12 |
columns (time steps) specified in each sky patch row, |
88 |
whether it is read from the standard input or from a file. |
89 |
greg |
1.10 |
Input starts from the first patch at the first time step, then the |
90 |
first patch at the second time step, and so on. |
91 |
greg |
1.12 |
Note that all matrix elements are RGB triplets, so the actual size |
92 |
of the sky vector or matrix is three times the number of steps times |
93 |
the number of sky patches. |
94 |
greg |
1.5 |
The |
95 |
.I \-if |
96 |
or |
97 |
.I \-id |
98 |
option may be used to specify that sky data is in float or double |
99 |
greg |
1.6 |
format, respectively, which is more efficient for large matrices. |
100 |
greg |
1.14 |
These options are unnecessary when the sky input includes a header. |
101 |
greg |
1.1 |
.PP |
102 |
greg |
1.11 |
Any of the matrix or vector files may be read from a command |
103 |
instead of a file by |
104 |
using quotes and a beginning exclamation point ('!'). |
105 |
.PP |
106 |
greg |
1.9 |
The standard output of |
107 |
greg |
1.1 |
.I dctimestep |
108 |
greg |
1.8 |
is either a color vector with as many RGB triplets |
109 |
greg |
1.1 |
as there are rows in the View matrix, or a combined |
110 |
.I Radiance |
111 |
picture. |
112 |
greg |
1.2 |
Which output is produced depends on the first argument. |
113 |
greg |
1.1 |
A regular file name will be loaded and interpreted as a matrix to |
114 |
generate a color results vector. |
115 |
A file specification containing a '%d' format string will be |
116 |
interpreted as a list of |
117 |
.I Radiance |
118 |
component pictures, which will be summed according to the computed |
119 |
vector. |
120 |
greg |
1.4 |
.PP |
121 |
The |
122 |
.I \-o |
123 |
option may be used to specify a file or a set of output files |
124 |
to use rather than the standard output. |
125 |
If the given specification contains a '%d' format string, this |
126 |
greg |
1.15 |
will be replaced by the time step index, starting from 0. |
127 |
greg |
1.4 |
In this way, multiple output pictures may be produced, |
128 |
greg |
1.6 |
or separate result vectors (one per time step). |
129 |
greg |
1.18 |
If input is a matrix rather than a set of pictures, the |
130 |
greg |
1.17 |
.I \-x |
131 |
and/or |
132 |
.I \-y |
133 |
greg |
1.18 |
options may be necessary to set the output picture size. |
134 |
greg |
1.17 |
If only one dimension is specified, the other is computed based |
135 |
on the number of rows in the result vectors. |
136 |
greg |
1.8 |
.PP |
137 |
greg |
1.10 |
A header will normally be produced on the output, unless the |
138 |
.I \-h |
139 |
option is specified. |
140 |
greg |
1.8 |
The |
141 |
greg |
1.16 |
.I \-of, |
142 |
.I \-od, |
143 |
greg |
1.8 |
or |
144 |
greg |
1.16 |
.I \-oc |
145 |
option may be used to specify IEEE float, double, or RGBE (picture) output |
146 |
greg |
1.8 |
data, respectively. |
147 |
greg |
1.1 |
.SH EXAMPLES |
148 |
greg |
1.2 |
To compute workplane illuminances at 3:30pm on Feb 10th: |
149 |
.IP "" .2i |
150 |
gensky 2 10 15:30 | genskyvec | dctimestep workplaneDC.dmx > Ill_02-10-1530.dat |
151 |
.PP |
152 |
greg |
1.18 |
To compute a picture at 10am on the equinox from a set of component pictures: |
153 |
greg |
1.2 |
.IP "" .2i |
154 |
greg |
1.6 |
gensky 3 21 10 | genskyvec | dctimestep dcomp%03d.hdr > view_03-21-10.hdr |
155 |
greg |
1.2 |
.PP |
156 |
greg |
1.1 |
To compute a set of illuminance contributions for Window 1 on |
157 |
the Winter solstice at 2pm: |
158 |
.IP "" .2i |
159 |
gensky 12 21 14 | genskyvec | dctimestep IllPts.vmx Blinds20.xml Window1.dmx > Ill_12-21-14.dat |
160 |
.PP |
161 |
To compute Window2's contribution to an interior view at 12 noon on the Summer solstice: |
162 |
.IP "" .2i |
163 |
greg |
1.6 |
gensky 6 21 12 | genskyvec | dctimestep view%03d.hdr Blinds30.xml |
164 |
Window2.dmx > view_6-21-12.hdr |
165 |
.PP |
166 |
To generate an hourly matrix of sensor value contributions from Skylight3 |
167 |
using a 3-phase calculation, where output columns are time steps: |
168 |
.IP "" .2i |
169 |
greg |
1.10 |
gendaymtx -of Tampa.wea | dctimestep WPpts.vmx |
170 |
greg |
1.6 |
shade3.xml Skylight3.dmx > wp_win3.dat |
171 |
.PP |
172 |
Generate a series of pictures corresponding to timesteps |
173 |
in an annual simulation: |
174 |
.IP "" .2i |
175 |
greg |
1.10 |
gendaymtx NYCity.wea | dctimestep -o tstep%04d.hdr dcomp%03d.hdr |
176 |
greg |
1.8 |
.PP |
177 |
greg |
1.12 |
To multiply an irradiance view matrix through a pair of XML window layers using |
178 |
a given exterior daylight matrix and sky vector: |
179 |
.IP "" .2i |
180 |
dctimestep Illum.vmx "!rmtxop -ff Blinds1.xml Windo1.xml" Exter.dmx Jan20.sky |
181 |
.PP |
182 |
greg |
1.10 |
To multiply two matrices into a IEEE-float result with header: |
183 |
greg |
1.8 |
.IP "" .2i |
184 |
greg |
1.10 |
dctimestep -of Inp1.fmx Inp2.fmx > Inp1xInp2.fmx |
185 |
greg |
1.18 |
.SH NOTES |
186 |
.I Dctimestep |
187 |
optimizes its matrix concatenation by checking for all-zero rows |
188 |
or columns, thus avoiding unnecessary vector multiplications. |
189 |
This can improve performance when a daylight matrix contains |
190 |
zero-filled column vectors corresponding to hours of darkness. |
191 |
.PP |
192 |
It rarely makes sense to specify the |
193 |
.I \-od |
194 |
output option with |
195 |
.I dctimestep, |
196 |
since matrix operations are carried out using 32-bit "float" values. |
197 |
This take less memory, but can also be less accurate than an |
198 |
equivalent invocation of |
199 |
.I rmtxop(1), |
200 |
which performs all operations on 64-bit "double" values. |
201 |
greg |
1.1 |
.SH AUTHOR |
202 |
Greg Ward |
203 |
.SH "SEE ALSO" |
204 |
greg |
1.12 |
gendaymtx(1), genskyvec(1), getinfo(1), |
205 |
greg |
1.18 |
mkillum(1), rcollate(1), rcontrib(1), rcrop(1), |
206 |
greg |
1.12 |
rfluxmtx(1), rmtxop(1), rtrace(1), vwrays(1) |
