root/radiance/ray/doc/man/man1/dctimestep.1
Wed Mar 23 01:52:51 2022 UTC (3 years, 1 month ago) by greg
Changes since 1.17: +24 -8 lines
Diff to previous 1.17 , to selected 1.3
docs(dctimestep): Changed some wording and added a NOTES section
Fri Mar 11 02:27:02 2022 UTC (3 years, 1 month ago) by greg
Changes since 1.16: +12 -1 lines
Diff to previous 1.16 , to selected 1.3
feat(dctimestep): Added -x and -y options to specify picture output dimensions
Wed Oct 23 17:00:14 2019 UTC (5 years, 6 months ago) by greg
Changes since 1.15: +6 -5 lines
Diff to previous 1.15 , to selected 1.3
Fri Mar 1 01:00:03 2019 UTC (6 years, 2 months ago) by greg
Changes since 1.14: +2 -2 lines
Diff to previous 1.14 , to selected 1.3
Changed output numbering to start from 0 for consistency with input
Tue Aug 30 14:47:20 2016 UTC (8 years, 8 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 1.13: +2 -3 lines
Diff to previous 1.13 , to selected 1.3
Fixed missing word
Fri May 6 18:02:40 2016 UTC (9 years ago) by greg
Diff to previous 1.12 , to selected 1.3
Minor wording correction
Tue Jul 14 16:08:28 2015 UTC (9 years, 9 months ago) by greg
Changes since 1.11: +20 -15 lines
Diff to previous 1.11 , to selected 1.3
Added ability for dctimestep to accept matrix files in place of XML for T
Mon May 4 20:53:21 2015 UTC (10 years ago) by greg
Changes since 1.10: +5 -1 lines
Diff to previous 1.10 , to selected 1.3
Wed Sep 17 22:40:49 2014 UTC (10 years, 7 months ago) by greg
CVS Tags: rad4R2P2
Changes since 1.9: +27 -39 lines
Diff to previous 1.9 , to selected 1.3
Fri May 30 00:00:54 2014 UTC (10 years, 11 months ago) by greg
CVS Tags: rad4R2, rad4R2P1
Changes since 1.8: +11 -5 lines
Diff to previous 1.8 , to selected 1.3
Sat Feb 8 01:28:05 2014 UTC (11 years, 3 months ago) by greg
Changes since 1.7: +30 -3 lines
Diff to previous 1.7 , to selected 1.3
Thu Sep 5 17:53:22 2013 UTC (11 years, 8 months ago) by greg
Diff to previous 1.6 , to selected 1.3
Sun Jan 20 02:07:16 2013 UTC (12 years, 3 months ago) by greg
Changes since 1.5: +30 -15 lines
Diff to previous 1.5 , to selected 1.3
Added documentation for new gendaymtx tool
Fri Jan 11 17:21:39 2013 UTC (12 years, 3 months ago) by greg
Changes since 1.4: +14 -2 lines
Diff to previous 1.4 , to selected 1.3
Fri Jan 11 05:07:47 2013 UTC (12 years, 3 months ago) by greg
Changes since 1.3: +39 -8 lines
Diff to previous 1.3
Revision 1.3 - (view) (download) (annotate) - [selected]
Thu Jun 14 22:42:21 2012 UTC (12 years, 10 months ago) by greg
Changes since 1.2: +4 -4 lines
Diff to previous 1.2
Thu Jul 1 21:54:55 2010 UTC (14 years, 10 months ago) by greg
Changes since 1.1: +29 -5 lines
Diff to previous 1.1 , to selected 1.3
Thu Dec 10 00:17:19 2009 UTC (15 years, 5 months ago) by greg
Diff to selected 1.3
New man pages for dctimestep and genskyvec
