root/radiance/ray/doc/man/man1/dctimestep.1
Revision: 1.23
Committed: Thu Mar 27 01:26:55 2025 UTC (5 weeks, 6 days ago) by greg
Changes since 1.22: +17 -10 lines
Error occurred while calculating annotation data.
feat(pvsum): Added new pvsum tool for spectral data, similar to dctimestep
1 .\" RCSid $Id: dctimestep.1,v 1.22 2025/03/24 17:20:36 greg Exp $"
2 .TH DCTIMESTEP 1 12/09/09 RADIANCE
3 .SH NAME
4 dctimestep - compute annual simulation time-step(s) via matrix multiplication
5 .SH SYNOPSIS
6 .B dctimestep
7 [
8 .B "\-n nsteps"
9 ][
10 .B "\-h"
11 ][
12 .B "\-o ospec"
13 ][
14 .B "\-x xres"
15 ][
16 .B "\-y yres"
17 ][
18 .B "\-i{a|f|d}
19 ][
20 .B "\-o{a|f|d|c}
21 ]
22 .B DCspec
23 [
24 .B skyf
25 ]
26 .br
27 .B dctimestep
28 [
29 .B "\-n nsteps"
30 ][
31 .B "\-h"
32 ][
33 .B "\-o ospec"
34 ][
35 .B "\-i{f|d}
36 ][
37 .B "\-o{f|d|c}
38 ]
39 .B Vspec
40 .B Tbsdf
41 .B Dmat.dat
42 [
43 .B skyf
44 ]
45 .SH DESCRIPTION
46 .I Dctimestep
47 has two invocation forms.
48 In the first form,
49 .I dctimestep
50 is given a daylight coefficient specification and an optional sky
51 vector or matrix, which may be read from the standard input if unspecified.
52 The daylight coefficients are multiplied against these sky values
53 and the results are written to the standard output.
54 This may be a list of color values or a combined Radiance picture,
55 as explained below.
56 .PP
57 In the second form,
58 .I dctimestep
59 takes four input files, forming a matrix expression.
60 The first argument is the View matrix that specifies how window output
61 directions are related to some set of measured values, such as an array of
62 illuminance points or pictures.
63 This matrix is usually computed by
64 .I rfluxmtx(1)
65 or
66 .I rcontrib(1)
67 for a particular set of windows or skylight openings.
68 The second argument is the window transmission matrix, or BSDF, given as
69 a matrix or a standard XML description.
70 The third argument is the Daylight matrix file that defines how sky patches
71 relate to input directions on the same opening.
72 This is usually computed using
73 .I rfluxmtx
74 with separate runs for each window or skylight orientation.
75 The last file is the sky contribution vector or matrix,
76 typically computed by
77 .I genskyvec(1)
78 or
79 .I gendaymtx(1),
80 and may be passed on the standard input.
81 .PP
82 If the input sky data lacks a header, the
83 .I \-n
84 option may be used to indicate the number of time steps, which
85 will be 1 for a sky vector.
86 The sky input file must otherwise contain the number of
87 columns (time steps) specified in each sky patch row,
88 whether it is read from the standard input or from a file.
89 Input starts from the first patch at the first time step, then the
90 first patch at the second time step, and so on.
91 Note that all matrix elements are RGB triplets, so the actual size
92 of the sky vector or matrix is three times the number of steps times
93 the number of sky patches.
94 The
95 .I \-if
96 or
97 .I \-id
98 option may be used to specify that sky data is in float or double
99 format, respectively, which is more efficient for large matrices.
100 These options are unnecessary when the sky input includes a header.
101 .PP
102 Any of the matrix or vector files may be read from a command
103 instead of a file by
104 using quotes and a beginning exclamation point ('!').
105 .PP
106 The standard output of
107 .I dctimestep
108 is either a color vector with as many RGB triplets
109 as there are rows in the View matrix, or a combined Radiance
110 picture.
111 Which output is produced depends on the first argument.
112 A regular file name will be loaded and interpreted as a matrix to
113 generate a color results vector.
114 A file specification containing a '%d' format string will be
115 interpreted as a list of Radiance
116 component pictures, which will be summed according to the computed
117 vector.
118 .PP
119 The
120 .I \-o
121 option may be used to specify a file or a set of output files
122 to use rather than the standard output.
123 If the given specification contains a '%d' format string, this
124 will be replaced by the time step index, starting from 0.
125 In this way, multiple output pictures may be produced,
126 or separate result vectors (one per time step).
127 If input is a matrix rather than a set of pictures, the
128 .I \-x
129 and/or
130 .I \-y
131 options may be necessary to set the output picture size.
132 If only one dimension is specified, the other is computed based
133 on the number of rows in the result vectors.
134 .PP
135 A header will normally be produced on the output, unless the
136 .I \-h
137 option is specified.
138 Default output format is ASCII text.
139 The
140 .I \-of,
141 .I \-od,
142 or
143 .I \-oc
144 option may be used to specify IEEE float, double, or RGBE (picture) output
145 data, respectively.
146 The
147 .I \-oc
148 option is set automatically if input is a collection of RGBE or XYZE pictures.
149 .SH EXAMPLES
150 To compute workplane illuminances at 3:30pm on Feb 10th:
151 .IP "" .2i
152 gensky 2 10 15:30 | genskyvec | dctimestep workplaneDC.dmx > Ill_02-10-1530.dat
153 .PP
154 To compute a picture at 10am on the equinox from a set of component pictures:
155 .IP "" .2i
156 gensky 3 21 10 | genskyvec | dctimestep dcomp%03d.hdr > view_03-21-10.hdr
157 .PP
158 To compute a set of illuminance contributions for Window 1 on
159 the Winter solstice at 2pm:
160 .IP "" .2i
161 gensky 12 21 14 | genskyvec | dctimestep IllPts.vmx Blinds20.xml Window1.dmx > Ill_12-21-14.dat
162 .PP
163 To compute Window2's contribution to an interior view at 12 noon on the summer solstice:
164 .IP "" .2i
165 gensky 6 21 12 | genskyvec | dctimestep view%03d.hdr Blinds30.xml
166 Window2.dmx > view_6-21-12.hdr
167 .PP
168 To generate an hourly matrix of sensor value contributions from Skylight3
169 using a 3-phase calculation, where output columns are time steps:
170 .IP "" .2i
171 gendaymtx -of Tampa.wea | dctimestep WPpts.vmx
172 shade3.xml Skylight3.dmx > wp_win3.dat
173 .PP
174 Generate a series of pictures corresponding to timesteps
175 in an annual simulation:
176 .IP "" .2i
177 gendaymtx NYCity.wea | dctimestep -o tstep%04d.hdr dcomp%03d.hdr
178 .PP
179 To multiply an irradiance view matrix through a pair of XML window layers using
180 a given exterior daylight matrix and sky vector:
181 .IP "" .2i
182 dctimestep Illum.vmx "!rmtxop -ff Blinds1.xml Windo1.xml" Exter.dmx Jan20.sky
183 .PP
184 To multiply two matrices into a IEEE-float result with header:
185 .IP "" .2i
186 dctimestep -of Inp1.fmx Inp2.fmx > Inp1xInp2.fmx
187 .SH NOTES
188 .I Dctimestep
189 optimizes its matrix concatenation by checking for all-zero rows
190 or columns, thus avoiding unnecessary vector multiplications.
191 This can improve performance when a daylight matrix contains
192 zero-filled column vectors corresponding to hours of darkness.
193 .PP
194 It rarely makes sense to specify the
195 .I \-od
196 output option with
197 .I dctimestep,
198 since matrix operations are carried out using 32-bit "float" values.
199 This take less memory, but can also be less accurate than an
200 equivalent invocation of
201 .I rmtxop(1)
202 or
203 .I rcomb(1),
204 which perform all operations on 64-bit "double" values.
205 .PP
206 .I Dctimestep
207 does not accept on input or produce on output Radiance
208 spectral pictures.
209 This is a limitation of the implementation and its underlying
210 data representation.
211 Use instead the similar
212 .I pvsum(1)
213 tool for spectral input and output.
214 .SH AUTHOR
215 Greg Ward
216 .SH "SEE ALSO"
217 dcglare(1), gendaymtx(1), genskyvec(1), getinfo(1), mkillum(1),
218 pvsum(1), ra_rgbe(1), rcollate(1), rcomb(1), rcontrib(1), rcrop(1),
219 rfluxmtx(1), rmtxop(1), rtrace(1), vwrays(1)
