root/radiance/ray/doc/man/man1/dctimestep.1
Revision: 1.6
Committed: Sun Jan 20 02:07:16 2013 UTC (12 years, 5 months ago) by greg
Changes since 1.5: +30 -15 lines
Added documentation for new gendaymtx tool
1 .\" RCSid $Id: dctimestep.1,v 1.5 2013/01/11 17:21:39 greg Exp $"
2 .TH DCTIMESTEP 1 12/09/09 RADIANCE
3 .SH NAME
4 dctimestep - compute annual simulation time-step(s) via matrix multiplication
5 .SH SYNOPSIS
6 .B dctimestep
7 [
8 .B "\-n nsteps"
9 ][
10 .B "\-o ospec"
11 ][
12 .B "\-i{f|d}
13 ]
14 .B DCspec
15 [
16 .B skyf
17 ]
18 .br
19 .B dctimestep
20 [
21 .B "\-n nsteps"
22 ][
23 .B "\-o ospec"
24 ][
25 .B "\-i{f|d}
26 ]
27 .B Vspec
28 .B Tbsdf.xml
29 .B Dmat.dat
30 [
31 .B skyf
32 ]
33 .SH DESCRIPTION
34 .I Dctimestep
35 has two invocation forms.
36 In the first form,
37 .I dctimestep
38 is given a daylight coefficient specification and an optional sky
39 vector or matrix, which may be read from the standard input if unspecified.
40 The daylight coefficients are multiplied against these sky values
41 and the results are written to the standard output.
42 This may be a list of color values or a combined Radiance image,
43 as explained below.
44 .PP
45 In the second form,
46 .I dctimestep
47 takes four input files, forming a matrix expression.
48 The first argument is the View matrix file that specifies how window output
49 directions are related to some set of measured values, such as an array of
50 illuminance points or images.
51 This matrix is usually computed by
52 .I rcontrib(1)
53 for a particular set of windows or skylight openings.
54 The second argument is the window transmission matrix, or BSDF, given as
55 a standard XML description.
56 The third argument is the Daylight matrix file that defines how sky patches
57 relate to input directions on the same opening.
58 This is usually computed using
59 .I genklemsamp(1)
60 with
61 .I rcontrib
62 in a separate run for each window or skylight orientation.
63 The last file is the sky contribution vector or matrix,
64 typically computed by
65 .I genskyvec(1)
66 or
67 .I gendaymtx(1),
68 and may be passed on the standard input.
69 This data is assumed by default to be in ASCII format, whereas the
70 formats of the View and Daylight matrices
71 are detected automatically if given as binary data.
72 The
73 .I \-if
74 or
75 .I \-id
76 option may be used to specify that sky data is in float or double
77 format, respectively, which is more efficient for large matrices.
78 (Note that binary double data may not be read from stdin.)\0
79 .PP
80 Sent to the standard output of
81 .I dctimestep
82 is either an ASCII color vector with as many RGB triplets
83 as there are rows in the View matrix, or a combined
84 .I Radiance
85 picture.
86 Which output is produced depends on the first argument.
87 A regular file name will be loaded and interpreted as a matrix to
88 generate a color results vector.
89 A file specification containing a '%d' format string will be
90 interpreted as a list of
91 .I Radiance
92 component pictures, which will be summed according to the computed
93 vector.
94 .PP
95 The
96 .I \-n
97 option may be used to compute multiple time steps in a
98 single invocation.
99 The sky input file must contain the number of
100 columns specified in each sky patch row, whether it is read
101 from the standard input or from a file.
102 The columns do not need to be given on the same
103 line, so long as the number of values totals 3*Nsteps*Npatches.
104 Input starts from the first patch at the first time step, then the
105 first patch at the second time step, and so on.
106 .PP
107 The
108 .I \-o
109 option may be used to specify a file or a set of output files
110 to use rather than the standard output.
111 If the given specification contains a '%d' format string, this
112 will be replaced by the time step index, starting from 1.
113 In this way, multiple output pictures may be produced,
114 or separate result vectors (one per time step).
115 .SH EXAMPLES
116 To compute workplane illuminances at 3:30pm on Feb 10th:
117 .IP "" .2i
118 gensky 2 10 15:30 | genskyvec | dctimestep workplaneDC.dmx > Ill_02-10-1530.dat
119 .PP
120 To compute an image at 10am on the equinox from a set of component images:
121 .IP "" .2i
122 gensky 3 21 10 | genskyvec | dctimestep dcomp%03d.hdr > view_03-21-10.hdr
123 .PP
124 To compute a set of illuminance contributions for Window 1 on
125 the Winter solstice at 2pm:
126 .IP "" .2i
127 gensky 12 21 14 | genskyvec | dctimestep IllPts.vmx Blinds20.xml Window1.dmx > Ill_12-21-14.dat
128 .PP
129 To compute Window2's contribution to an interior view at 12 noon on the Summer solstice:
130 .IP "" .2i
131 gensky 6 21 12 | genskyvec | dctimestep view%03d.hdr Blinds30.xml
132 Window2.dmx > view_6-21-12.hdr
133 .PP
134 To generate an hourly matrix of sensor value contributions from Skylight3
135 using a 3-phase calculation, where output columns are time steps:
136 .IP "" .2i
137 gendaymtx -of Tampa.wea | dctimestep -if -n 8760 WPpts.vmx
138 shade3.xml Skylight3.dmx > wp_win3.dat
139 .IP "" .2i
140 .PP
141 Generate a series of pictures corresponding to timesteps
142 in an annual simulation:
143 .IP "" .2i
144 gendaymtx NYCity.wea | dctimestep -n 8760 -o tstep%04d.hdr dcomp%03d.hdr
145 .SH AUTHOR
146 Greg Ward
147 .SH "SEE ALSO"
148 gendaymtx(1), genklemsamp(1), genskyvec(1),
149 mkillum(1), rcontrib(1), rtrace(1), vwrays(1)
