root/radiance/ray/doc/man/man1/dctimestep.1
Revision: 1.4
Committed: Fri Jan 11 05:07:47 2013 UTC (12 years, 5 months ago) by greg
Changes since 1.3: +39 -8 lines
1 .\" RCSid $Id: dctimestep.1,v 1.3 2012/06/14 22:42:21 greg Exp $"
2 .TH DCTIMESTEP 1 12/09/09 RADIANCE
3 .SH NAME
4 dctimestep - compute annual simulation time-step(s) via matrix multiplication
5 .SH SYNOPSIS
6 .B dctimestep
7 [
8 .B "\-n nsteps"
9 ][
10 .B "\-o ospec"
11 ]
12 .B DCspec
13 [
14 .B skyf
15 ]
16 .br
17 .B dctimestep
18 [
19 .B "\-n nsteps"
20 ][
21 .B "\-o ospec"
22 ]
23 .B Vspec
24 .B Tbsdf.xml
25 .B Dmat.dat
26 [
27 .B skyf
28 ]
29 .SH DESCRIPTION
30 .I Dctimestep
31 has two invocation forms.
32 In the first form,
33 .I dctimestep
34 is given a daylight coefficient specification and an optional sky
35 vector or matrix, which may be read from the standard input if unspecified.
36 The daylight coefficients are multiplied against these sky values
37 and the results are written to the standard output.
38 This may be a list of color values or a combined Radiance image,
39 as explained below.
40 .PP
41 In the second form,
42 .I dctimestep
43 takes four input files, forming a matrix expression.
44 The first argument is the View matrix file that specifies how window output
45 directions are related to some set of measured values, such as an array of
46 illuminance points or images.
47 This matrix is usually computed by
48 .I rcontrib(1)
49 for a particular set of windows or skylight openings.
50 The second argument is the window transmission matrix, or BSDF, given as
51 a standard XML description.
52 The third argument is the Daylight matrix file that defines how sky patches
53 relate to input directions on the same opening.
54 This is usually computed using
55 .I genklemsamp(1)
56 with
57 .I rcontrib
58 in a separate run for each window or skylight orientation.
59 The final input is the sky contribution vector or matrix,
60 usually computed by
61 .I genskyvec(1),
62 which may be passed on the standard input.
63 This data must be in ASCII format, whereas the View and Daylight matrices
64 are more efficiently represented as binary float data if machine
65 byte-order is not an issue.
66 .PP
67 Sent to the standard output of
68 .I dctimestep
69 is either an ASCII color vector with as many RGB triplets
70 as there are rows in the View matrix, or a combined
71 .I Radiance
72 picture.
73 Which output is produced depends on the first argument.
74 A regular file name will be loaded and interpreted as a matrix to
75 generate a color results vector.
76 A file specification containing a '%d' format string will be
77 interpreted as a list of
78 .I Radiance
79 component pictures, which will be summed according to the computed
80 vector.
81 .PP
82 The
83 .I \-n
84 option may be used to compute multiple time steps in a
85 single invocation.
86 The sky input file must contain the number of
87 columns specified in each sky patch row, whether it is read
88 from the standard input or from an ASCII file.
89 The columns do not need to be given on the same
90 line, so long as the number of values totals 3*Nsteps*Npatches.
91 Input starts from the first patch at the first time step, then the
92 first patch at the second time step, and so on.
93 .PP
94 The
95 .I \-o
96 option may be used to specify a file or a set of output files
97 to use rather than the standard output.
98 If the given specification contains a '%d' format string, this
99 will be replaced by the time step index, starting from 1.
100 In this way, multiple output pictures may be produced,
101 or separate results vector (one per time step).
102 .SH EXAMPLES
103 To compute workplane illuminances at 3:30pm on Feb 10th:
104 .IP "" .2i
105 gensky 2 10 15:30 | genskyvec | dctimestep workplaneDC.dmx > Ill_02-10-1530.dat
106 .PP
107 To compute an image at 10am on the equinox from a set of component images:
108 .IP "" .2i
109 gensky 3 21 10 | genskyvec | dctimestep viewc%03d.hdr > view_03-21-10.hdr
110 .PP
111 To compute a set of illuminance contributions for Window 1 on
112 the Winter solstice at 2pm:
113 .IP "" .2i
114 gensky 12 21 14 | genskyvec | dctimestep IllPts.vmx Blinds20.xml Window1.dmx > Ill_12-21-14.dat
115 .PP
116 To compute Window2's contribution to an interior view at 12 noon on the Summer solstice:
117 .IP "" .2i
118 gensky 6 21 12 | genskyvec | dctimestep view%03d.hdr Blinds30.xml Window2.dmx > view_6-21-12.hdr
119 .SH AUTHOR
120 Greg Ward
121 .SH "SEE ALSO"
122 genklemsamp(1), genskyvec(1), mkillum(1), rcontrib(1), rtrace(1), vwrays(1)
