root/radiance/ray/doc/man/man1/dctimestep.1
Revision: 1.9
Committed: Fri May 30 00:00:54 2014 UTC (11 years, 1 month ago) by greg
CVS Tags: rad4R2, rad4R2P1
Changes since 1.8: +11 -5 lines
# User Rev Content
1 greg 1.9 .\" RCSid $Id: dctimestep.1,v 1.8 2014/02/08 01:28:05 greg Exp $"
2 greg 1.1 .TH DCTIMESTEP 1 12/09/09 RADIANCE
3     .SH NAME
4 greg 1.4 dctimestep - compute annual simulation time-step(s) via matrix multiplication
5 greg 1.1 .SH SYNOPSIS
6     .B dctimestep
7 greg 1.4 [
8     .B "\-n nsteps"
9     ][
10     .B "\-o ospec"
11 greg 1.5 ][
12 greg 1.9 .B "\-i{f|d|h}
13 greg 1.8 ][
14     .B "\-o{f|d}
15 greg 1.4 ]
16 greg 1.2 .B DCspec
17     [
18 greg 1.4 .B skyf
19 greg 1.2 ]
20     .br
21     .B dctimestep
22 greg 1.4 [
23     .B "\-n nsteps"
24     ][
25     .B "\-o ospec"
26 greg 1.5 ][
27 greg 1.9 .B "\-i{f|d|h}
28 greg 1.8 ][
29     .B "\-o{f|d}
30 greg 1.4 ]
31 greg 1.1 .B Vspec
32     .B Tbsdf.xml
33     .B Dmat.dat
34     [
35 greg 1.4 .B skyf
36 greg 1.1 ]
37     .SH DESCRIPTION
38     .I Dctimestep
39 greg 1.2 has two invocation forms.
40     In the first form,
41     .I dctimestep
42     is given a daylight coefficient specification and an optional sky
43 greg 1.4 vector or matrix, which may be read from the standard input if unspecified.
44     The daylight coefficients are multiplied against these sky values
45     and the results are written to the standard output.
46 greg 1.2 This may be a list of color values or a combined Radiance image,
47     as explained below.
48     .PP
49     In the second form,
50     .I dctimestep
51 greg 1.1 takes four input files, forming a matrix expression.
52     The first argument is the View matrix file that specifies how window output
53     directions are related to some set of measured values, such as an array of
54     illuminance points or images.
55     This matrix is usually computed by
56 greg 1.3 .I rcontrib(1)
57 greg 1.1 for a particular set of windows or skylight openings.
58     The second argument is the window transmission matrix, or BSDF, given as
59     a standard XML description.
60     The third argument is the Daylight matrix file that defines how sky patches
61     relate to input directions on the same opening.
62     This is usually computed using
63     .I genklemsamp(1)
64     with
65 greg 1.3 .I rcontrib
66 greg 1.1 in a separate run for each window or skylight orientation.
67 greg 1.6 The last file is the sky contribution vector or matrix,
68     typically computed by
69     .I genskyvec(1)
70     or
71     .I gendaymtx(1),
72     and may be passed on the standard input.
73     This data is assumed by default to be in ASCII format, whereas the
74     formats of the View and Daylight matrices
75     are detected automatically if given as binary data.
76 greg 1.5 The
77     .I \-if
78     or
79     .I \-id
80     option may be used to specify that sky data is in float or double
81 greg 1.6 format, respectively, which is more efficient for large matrices.
82 greg 1.9 The
83     .I \-ih
84     option says to check the header to determine the data type.
85     (Note that binary double data may not be read from stdin without a header.)\0
86 greg 1.1 .PP
87 greg 1.9 The standard output of
88 greg 1.1 .I dctimestep
89 greg 1.8 is either a color vector with as many RGB triplets
90 greg 1.1 as there are rows in the View matrix, or a combined
91     .I Radiance
92     picture.
93 greg 1.2 Which output is produced depends on the first argument.
94 greg 1.1 A regular file name will be loaded and interpreted as a matrix to
95     generate a color results vector.
96     A file specification containing a '%d' format string will be
97     interpreted as a list of
98     .I Radiance
99     component pictures, which will be summed according to the computed
100     vector.
101 greg 1.4 .PP
102     The
103     .I \-n
104     option may be used to compute multiple time steps in a
105     single invocation.
106     The sky input file must contain the number of
107     columns specified in each sky patch row, whether it is read
108 greg 1.6 from the standard input or from a file.
109 greg 1.4 The columns do not need to be given on the same
110     line, so long as the number of values totals 3*Nsteps*Npatches.
111     Input starts from the first patch at the first time step, then the
112     first patch at the second time step, and so on.
113 greg 1.9 If the input matrix has a header, then you may use
114     .I \-n 0
115     to get the number of columns from the header rather than specifying it.
116 greg 1.4 .PP
117     The
118     .I \-o
119     option may be used to specify a file or a set of output files
120     to use rather than the standard output.
121     If the given specification contains a '%d' format string, this
122     will be replaced by the time step index, starting from 1.
123     In this way, multiple output pictures may be produced,
124 greg 1.6 or separate result vectors (one per time step).
125 greg 1.8 If the standard output is used or the
126     .I \-o
127     option specifies a single output file, then an information header
128     will precede the output.
129     This can be removed if desired using the
130     .I getinfo\(1\)
131     command with a single hyphen ('-') argument.
132     .PP
133     The
134     .I \-of
135     or
136     .I \-od
137     option may be used to specify IEEE float or double binary output
138     data, respectively.
139     This enables
140     .I dctimestep
141     to be used as a pure matrix multiplier, as the output file with
142     header specifying the format is suitable for subsequent calls.
143 greg 1.1 .SH EXAMPLES
144 greg 1.2 To compute workplane illuminances at 3:30pm on Feb 10th:
145     .IP "" .2i
146     gensky 2 10 15:30 | genskyvec | dctimestep workplaneDC.dmx > Ill_02-10-1530.dat
147     .PP
148     To compute an image at 10am on the equinox from a set of component images:
149     .IP "" .2i
150 greg 1.6 gensky 3 21 10 | genskyvec | dctimestep dcomp%03d.hdr > view_03-21-10.hdr
151 greg 1.2 .PP
152 greg 1.1 To compute a set of illuminance contributions for Window 1 on
153     the Winter solstice at 2pm:
154     .IP "" .2i
155     gensky 12 21 14 | genskyvec | dctimestep IllPts.vmx Blinds20.xml Window1.dmx > Ill_12-21-14.dat
156     .PP
157     To compute Window2's contribution to an interior view at 12 noon on the Summer solstice:
158     .IP "" .2i
159 greg 1.6 gensky 6 21 12 | genskyvec | dctimestep view%03d.hdr Blinds30.xml
160     Window2.dmx > view_6-21-12.hdr
161     .PP
162     To generate an hourly matrix of sensor value contributions from Skylight3
163     using a 3-phase calculation, where output columns are time steps:
164     .IP "" .2i
165     gendaymtx -of Tampa.wea | dctimestep -if -n 8760 WPpts.vmx
166     shade3.xml Skylight3.dmx > wp_win3.dat
167     .IP "" .2i
168     .PP
169     Generate a series of pictures corresponding to timesteps
170     in an annual simulation:
171     .IP "" .2i
172     gendaymtx NYCity.wea | dctimestep -n 8760 -o tstep%04d.hdr dcomp%03d.hdr
173 greg 1.8 .PP
174     To multiply two color matrices (second matrix is IEEE-float with
175     145 RGB columns) into a IEEE-double result (also 145 RGB columns):
176     .IP "" .2i
177     getinfo - < Inp2.fmx | dctimestep -n 145 -if -od Inp1.fmx > Inp1xInp2.dmx
178 greg 1.1 .SH AUTHOR
179     Greg Ward
180     .SH "SEE ALSO"
181 greg 1.8 gendaymtx(1), genklemsamp(1), genskyvec(1), getinfo(1),
182 greg 1.7 mkillum(1), rcollate(1), rcontrib(1), rtrace(1), vwrays(1)
