| 1 |
.TH DCGLARE
| 2 |
.SH NAME
| 3 |
dcglare - compute glare in annual simulation time-step(s) via matrix
| 4 |
multiplication
| 5 |
.SH SYNOPSIS
| 6 |
.B dcglare
| 7 |
| 8 |
.B "\-n nsteps"
| 9 |
| 10 |
.B "\-h"
| 11 |
| 12 |
.B "\-i{f|d}
| 13 |
| 14 |
.B "\-o{f|d}
| 15 |
| 16 |
.B "\-l
| 17 |
.I val
| 18 |
| 19 |
.B "\-b
| 20 |
.I val
| 21 |
| 22 |
.B "\-sf
| 23 |
.I file
| 24 |
| 25 |
.B "\-ss
| 26 |
.I h
| 27 |
.B "\-so
| 28 |
.I h
| 29 |
| 30 |
.B "\-vu
| 31 |
.I dx dy dz
| 32 |
| 33 |
.B "\-vd
| 34 |
.I dx dy dz
| 35 |
| 36 |
.B "\-vf
| 37 |
.I file
| 38 |
| 39 |
.B "\-vi{f|d}
| 40 |
| 41 |
.B DCdirect
| 42 |
.B DCtotal
| 43 |
| 44 |
.B skyf
| 45 |
| 46 |
.br
| 47 |
.B dcglare
| 48 |
| 49 |
.B "\-n nsteps"
| 50 |
| 51 |
.B "\-h"
| 52 |
| 53 |
.B "\-i{f|d}
| 54 |
| 55 |
.B "\-o{f|d}
| 56 |
| 57 |
.B "\-l
| 58 |
.I val
| 59 |
| 60 |
.B "\-b
| 61 |
.I val
| 62 |
| 63 |
.B "\-sf
| 64 |
.I file
| 65 |
| 66 |
.B "\-ss
| 67 |
.I h
| 68 |
.B "\-so
| 69 |
.I h
| 70 |
| 71 |
.B "\-vu
| 72 |
.I dx dy dz
| 73 |
| 74 |
.B "\-vd
| 75 |
.I dx dy dz
| 76 |
| 77 |
.B "\-vf
| 78 |
.I file
| 79 |
| 80 |
.B "\-vi{f|d}
| 81 |
| 82 |
.B DCdirect
| 83 |
.B Vspec
| 84 |
.B Tbsdf
| 85 |
.B Dmat.dat
| 86 |
| 87 |
.B skyf
| 88 |
| 89 |
.SH DESCRIPTION
| 90 |
.I Dcglare
| 91 |
generates daylight glare probability (DGP) predictions for multiple points in a
| 92 |
space under a variety of daylit conditions. Usually, it is used to produce
| 93 |
hourly DGP values for an entire year, or if the
| 94 |
.I \-l
| 95 |
option is provided, it calculates glare autonomy based on an annual occupancy
| 96 |
schedule.
| 97 |
.PP
| 98 |
As input,
| 99 |
.I dcglare
| 100 |
requires daylight coefficient matrices relating the illuminance at each view
| 101 |
point to the brightness of each sky patch. Two such matrices are required.
| 102 |
The first,
| 103 |
.I DCdirect
| 104 |
, consists of direct views to the sky only and is calculated by
| 105 |
.I rcontrib(1)
| 106 |
using a single ambient bounce. The second,
| 107 |
.I DCtotal
| 108 |
, includes the total direct and diffuse contribution of each sky patch.
| 109 |
The latter can be calculated directly by
| 110 |
.I rcontrib(1)
| 111 |
as in the two-phase method, or internally as in the three-phase method if given
| 112 |
view, BSDF, and daylight matrices. In this respect,
| 113 |
.I dcglare
| 114 |
is similar to
| 115 |
.I dctimestep(1)
| 116 |
except that it calculates DGP instead of irradiance.
| 117 |
The final input is the sky contribution matrix, usually computed by
| 118 |
.I gendaymtx(1)
| 119 |
, which may be passed on the standard input.
| 120 |
For efficiency, matrices stored in files can be represented as binary float data
| 121 |
if machine byte-order is not an issue.
| 122 |
.PP
| 123 |
In the imageless method for calculating DGP, each visible sky patch acts
| 124 |
as a glare source if it's brightness is above a threshold set by the
| 125 |
.I \-b
| 126 |
option. This option behaves similarly to the option in
| 127 |
.I evalglare(1)
| 128 |
as described below.
| 129 |
Imageless DGP calculation also requires that the view direction must be
| 130 |
specified for each view to orient it relative to the given sky patches.
| 131 |
If all views are oriented in the same direction,
| 132 |
.I \-vd
| 133 |
can be used to specify the view direction vector.
| 134 |
Alternatively, a view file can be specified by the
| 135 |
.I \-vf
| 136 |
option. The format for this file is the same as the input format expected by
| 137 |
.I rcontrib(1)
| 138 |
, and for simplicity, the same file can be provided as input to both programs.
| 139 |
The
| 140 |
.I \-vif
| 141 |
or
| 142 |
.I \-vid
| 143 |
option may be used to specify that view data is in float or double format,
| 144 |
respectively.
| 145 |
The up vector
| 146 |
.I \-vu
| 147 |
is used together with the direction vector to calculate the Guth index for each
| 148 |
sky patch relative to each view.
| 149 |
While each entry in the view file may have a unique view direction, a single up
| 150 |
vector is used for all views. The default up vector is in the positive
| 151 |
.I z
| 152 |
direction.
| 153 |
.PP
| 154 |
Glare autonomy refers to the fraction of occupied hours in which a view is free
| 155 |
of glare. When a glare limit is specified with the
| 156 |
.I \-l
| 157 |
option,
| 158 |
.I dcglare
| 159 |
will calculate the fraction of sky conditions from the sky matrix in which DGP
| 160 |
is less than this limit. In this case, individual DGP values are not recorded.
| 161 |
By default, all entries in the sky matrix are included in the glare autonomy
| 162 |
calculation, unless limitted by the
| 163 |
.I \-n
| 164 |
option.
| 165 |
However, you may exclude certain entries by creating an occupancy schedule.
| 166 |
This is useful if the sky matrix built with
| 167 |
.I gendaymtx(1)
| 168 |
contains all hours of a year, but the space will only be occupied at certain
| 169 |
times. You may specify an occupancy schedule file with the
| 170 |
.I \-sf
| 171 |
option. This file should be in comma-separated value format with the same number
| 172 |
of rows as in the sky matrix. The last entry of each line is read as a numeric
| 173 |
value that should be greater than zero for occupied times. Lines may be
| 174 |
commented with a '#' character.
| 175 |
This format is compatible with DIVA schedule files.
| 176 |
Alternatively, if the sky matrix contains 24 entries per day corresponding to
| 177 |
one per hour, uniform daily start and end hours for occupancy can be specified
| 178 |
with the
| 179 |
.I \-ss
| 180 |
and
| 181 |
.I \-se
| 182 |
options. No adjustment is made for daylight savings time.
| 183 |
.PP
| 184 |
In addition to these, you may specify options from
| 185 |
.I dctimestep(1)
| 186 |
with the exception of
| 187 |
.I \-o
| 188 |
because image rendering is not supported.
| 189 |
.TP 12n
| 190 |
.BI -l \ val
| 191 |
Set the limit for glare occurrence to
| 192 |
.I val
| 193 |
\&. When this option is provided, the program calculates glare autonomy,
| 194 |
where any DGP value at or above the limit
| 195 |
.I val
| 196 |
indicates the presence of glare. If the option is not provided, the program
| 197 |
calculates DGP under each sky condition in the sky matrix instead.
| 198 |
.TP
| 199 |
.BI -b \ val
| 200 |
Set the threshold factor to
| 201 |
.I val
| 202 |
\&. If
| 203 |
.I val
| 204 |
is larger than 100, it is used as constant threshold in cd/m2. If
| 205 |
.I val
| 206 |
is less or equal than 100, this factor multiplied by the average luminance in
| 207 |
each view will be used as threshold for detecting the glare sources (not
| 208 |
recommended). The default value is 2000 (fixed threshold method).
| 209 |
.TP
| 210 |
.BI -vf \ file
| 211 |
Get the list of views for DGP calculation from
| 212 |
.I file
| 213 |
\&. Each line in
| 214 |
.I file
| 215 |
contains six numeric values corresponding to the position and direction
| 216 |
of a view. Generally, this is the same file that is used as input to
| 217 |
.I rcontrib(1)
| 218 |
to create the daylight coefficient matrices
| 219 |
.TP
| 220 |
.BI -vd " xd yd zd"
| 221 |
Set the view forward vector (vertical direction) for DGP calculation to
| 222 |
.I xd yd zd
| 223 |
\&. This option is ignored when the
| 224 |
.I \-vf
| 225 |
option is provided.
| 226 |
.TP
| 227 |
.BI -vu " xd yd zd"
| 228 |
Set the view up vector (vertical direction) for DGP calculation to
| 229 |
.I xd yd zd
| 230 |
\&. The default up vector is the positive
| 231 |
.I z
| 232 |
direction.
| 233 |
.TP
| 234 |
.BI -vi t
| 235 |
Set the format of the view file to
| 236 |
.I t
| 237 |
\&. Available options are 'f' for single and 'd' for double precison IEEE float.
| 238 |
The default when no value is provided is to use ASCII.
| 239 |
.TP
| 240 |
.BI -sf \ file
| 241 |
Set the occupancy schedule file to
| 242 |
.I file
| 243 |
\&. In the event that the sky matrix includes unoccupied hours that should not
| 244 |
contribute to the glare autonomy calculation,
| 245 |
.I file
| 246 |
will be read to determine which entries from the sky file matrix will be
| 247 |
included in this calculation. Each line of
| 248 |
.I file
| 249 |
is expected to contain a numeric value at the end of a comma-delimited list,
| 250 |
with zero corresponding to unoccupied.
| 251 |
This argument is used only if
| 252 |
.I -l
| 253 |
is specified.
| 254 |
.TP
| 255 |
.BI -ss \ h
| 256 |
Set the occupancy start hour to
| 257 |
.I h
| 258 |
\&. This option is provided for expediency when no occupancy schedule file is
| 259 |
available. It is assumed that the sky matrix includes 24 entries per day,
| 260 |
corresponding to one per hour. This argument is used only if
| 261 |
.I -l
| 262 |
is specified.
| 263 |
.TP
| 264 |
.BI -se \ h
| 265 |
Set the occupancy end hour to
| 266 |
.I h
| 267 |
| 268 |
| 269 |
| 270 |
.I -l
| 271 |
is specified.
| 272 |
.SH EXAMPLES
| 273 |
To generate an hourly matrix of DGP where output columns are time steps and rows
| 274 |
correspond to views in the file views.vf:
| 275 |
.IP "" .2i
| 276 |
gendaymtx -of Tampa.wea > sky.smx
| 277 |
.IP "" .2i
| 278 |
rcontrib -e MF:1 -f reinhartb.cal -b rbin -bn Nrbins -m sky_mat -I+ -ab 1
| 279 |
-ad 50000 -lw .00002 -lr -10 -faf scene.oct < views.vf > dc1.mtx
| 280 |
.IP "" .2i
| 281 |
rcontrib -e MF:1 -f reinhartb.cal -b rbin -bn Nrbins -m sky_mat -I+ -ab 8
| 282 |
-ad 50000 -lw .00002 -lr -10 -faf scene.oct < views.vf > dc8.mtx
| 283 |
.IP "" .2i
| 284 |
dcglare -vf views.vf dc1.mtx dc8.mtx sky.smx > dgp.txt
| 285 |
.PP
| 286 |
To calculate glare autonomy based on a 40% DGP limit using the same matrices:
| 287 |
.IP "" .2i
| 288 |
dcglare -vf views.vf -sf 8to6withDST.60min.occ.csv -l .4 dc1.mtx dc8.mtx
| 289 |
sky.smx > ga.txt
| 290 |
.PP
| 291 |
To generate an hourly matrix of DGP values from Skylight3 using a 3-phase
| 292 |
calculation, where output columns are time steps:
| 293 |
.IP "" .2i
| 294 |
gendaymtx NYCity.wea | dcglare dc1.mtx WPpts.vmx shade3.xml Skylight3.dmx
| 295 |
> wp_win3.dat
| 296 |
.SH AUTHOR
| 297 |
Nathaniel Jones
| 298 |
.SH SEE ALSO
| 299 |
dctimestep(1), gendaymtx(1), rcontrib(1), evalglare(1)
