root/radiance/ray/doc/man/man1/bsdfview.1
Revision: 1.6
Committed: Fri Jul 20 00:50:40 2018 UTC (6 years, 10 months ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 1.5: +8 -1 lines
Added "-r" option to bsdf2rad and bsdfview to fix plotting range
1 .\" RCSid "$Id: bsdfview.1,v 1.5 2017/10/18 19:30:48 greg Exp $"
2 .TH BSDFVIEW 1 8/11/2017 RADIANCE
3 .SH NAME
4 bsdfview - view a BSDF representation
5 .SH SYNOPSIS
6 .B bsdfview
7 [
8 .B "\-q {Hi|Med|Lo}"
9 ][
10 .B \-t
11 |
12 rad options
13 ][
14 .B "\-r min max"
15 ]
16 input ..
17 .br
18 .SH DESCRIPTION
19 .I Bsdfview
20 renders a BSDF description interactively.
21 This is a script that creates a
22 .I rad(1)
23 input file (RIF),
24 which builds an octree via
25 .I bsdf2rad(1),
26 then renders the scene interactively or calls the
27 .I trad(1)
28 graphical user interface if the
29 .I \-t
30 option is given.
31 .PP
32 The input is either a single XML file, such as might be produced by
33 .I genBSDF(1),
34 .I bsdf2klems(1),
35 or
36 .I bsdf2ttree(1),
37 or up to four scattering interpolation representation (SIR) files, as
38 might be produced by
39 pabopto2bsdf(1).
40 .PP
41 A
42 .I rad
43 input file will be produced, whose name matches the root of
44 the first input file but with any leading path removed (i.e., in
45 the current directory).
46 This RIF may be reused for subsequent viewing and rendering via
47 .I rad
48 without incurring the cost of another call to
49 .I bsdf2rad.
50 .PP
51 The quality preference may be set via the
52 .I \-q
53 option.
54 The number of processors to use may be specified with the
55 .I \-n
56 option.
57 .PP
58 The program creates a number of views accessible via the
59 .I rvu(1)
60 "L" command:
61 .TP 10n
62 .BR def
63 The default view, showing the back and front BRDFs.
64 .TP
65 .BR fr
66 A view of the front reflection hemisphere.
67 .TP
68 .BR br
69 A view of the back reflection hemisphere.
70 .TP
71 .BR ft
72 A fisheye view of the front transmission hemisphere (from underneath).
73 .TP
74 .BR bt
75 A fisheye view of the back transmission hemisphere.
76 .TP
77 .BR pr
78 A parallel view of both reflection hemispheres from directly overhead.
79 .TP
80 .BR pt
81 A parallel view of both transmission hemispheres from directly underneath.
82 .PP
83 Additionally, all the standard views that
84 .I rvu
85 defines will be available (e.g., "xZ", "zl", etc.).
86 .PP
87 Since a
88 .I rad
89 input file is created by the script, it may be used
90 in subsequent runs as long as the temporary files remain.
91 These are typically kept until the next reboot of the operating
92 system, so re-running
93 .I bsdfview
94 with the same arguments will not require re-running
95 .I bsdf2rad
96 or
97 .I oconv.
98 Thus, start-up will be much quicker, unless the temporary files have
99 been removed.
100 In this case, the script may exit with an error indicating that the
101 .I rad
102 input file needs to be removed.
103 .PP
104 This input file may also be re-used directly from the command line using
105 .I rad
106 or
107 .I trad(1).
108 This may be useful for generating RADIANCE pictures corresponding
109 to the above standard views.
110 If no interactive run is desired, start
111 .I bsdfview
112 with the
113 .I "-v 0"
114 option.
115 .PP
116 If an optional plotting range is given with the
117 .I \-r
118 option, this will override automatic settings from the BSDF input.
119 This may be useful for comparing different BSDF sources.
120 .SH AUTHOR
121 Greg Ward
122 .SH "SEE ALSO"
123 bsdf2klems(1), bsdf2rad(1), bsdf2ttree(1), genBSDF(1),
124 objview(1), oconv(1), pabopto2bsdf(1), rad(1), rvu(1), trad(1)
