root/radiance/ray/doc/man/man1/bsdf2ttree.1
Revision: 1.13
Committed: Wed May 21 20:42:48 2025 UTC (3 weeks, 2 days ago) by greg
perf(bsdf2ttree): Changed default -n from 256 down to 64 for faster calcs
# User Rev Content
1 greg 1.13 .\" RCSid $Id: bsdf2ttree.1,v 1.12 2023/09/12 16:40:57 greg Exp $
2 greg 1.1 .TH BSDF2TTREE 1 4/24/2013 RADIANCE
3     .SH NAME
4     bsdf2ttree - generate XML tensor tree description of a BSDF
5     .SH SYNOPSIS
6     .B bsdf2ttree
7     [
8 greg 1.4 .B "\-pC"
9     ][
10 greg 1.6 .B "{+|-}a"
11     ][
12 greg 1.1 .B "\-g Nlog2"
13     ][
14 greg 1.3 .B "\-t pctcull"
15     ][
16 greg 1.8 .B "\-n nss"
17     ][
18     .B "\-s thresh"
19     ][
20 greg 1.3 .B "\-l maxlobes"
21 greg 1.9 ][
22 greg 1.1 .B "bsdf.sir .."
23     ]
24     .br
25     or
26     .br
27     .B bsdf2ttree
28     .B "\-t{3|4}"
29     [
30 greg 1.4 .B "\-pC"
31     ][
32 greg 1.6 .B "{+|-}a"
33     ][
34 greg 1.1 .B "\-g Nlog2"
35     ][
36 greg 1.3 .B "\-t pctcull"
37 greg 1.1 ][
38 greg 1.8 .B "\-n nss"
39     ][
40     .B "\-s thresh"
41     ][
42 greg 1.1 .B "{+|-}forward"
43     ][
44     .B "{+|-}backward"
45     ][
46 greg 1.3 .B "\-e expr"
47 greg 1.1 ][
48 greg 1.3 .B "\-f file"
49 greg 1.1 ]
50     .B bsdf_func
51     .SH DESCRIPTION
52     .I Bsdf2ttree
53     produces a tensor tree representation of a
54     bidirectional scattering distribution function (BSDF)
55     based on an intermediate representation (in the first form) or
56     a functional description (in the second form).
57     A complete XML description is written to the standard output,
58     which is normally redirected to a file.
59     .PP
60 greg 1.4 The
61     .I \-p
62     option by itself turns off the progress bar, whose length may be set
63     by an immediately following integer argument.
64     (The default progress bar length is 79 characters.)\0
65     .PP
66 greg 1.6 The
67 greg 1.12 .I \+a
68     option turns on reciprocity averaging for isotropic scattering or anisotropic reflection.
69     Normally off (-a), this enforces each tensor-tree hemisphere to follow symmetry
70 greg 1.11 implied by Helmholtz reciprocity, and is designed to reduce noise in measured data.
71 greg 1.12 However, for some data, reciprocity averaging can make the output worse.
72 greg 1.6 .PP
73 greg 1.1 The maximum resolution of the tensor tree may be controlled by the
74     .I \-g
75     option, which defaults to a value of 6.
76     This corresponds to a peak resolution of 2^6 (64) in each dimension.
77     Due to memory and time constraints, it is not recommended to set
78     .I \-g
79     higher than 7, which corresponds to a 128x128x128x128 initial sampling,
80     or 268 million values.
81     .PP
82     The initial sampling is pared down by the percentage specified with the
83     .I \-t
84     option, which defaults to 90.
85     Setting this parameter to -1 turns culling off entirely, which may be
86     useful for comparisons.
87     .PP
88 greg 1.8 The
89     .I \-n
90     option controls the number of super-samples to send in patches whose
91     difference to its neighbors exceeds some threshold.
92 greg 1.13 The default number of super-samples is 64.
93 greg 1.8 The difference threshold for super-sampling is controlled by the
94     .I \-s
95     option, and defaults to 0.35.
96     .PP
97 greg 1.1 The first invocation form takes a intermediate scattering representation
98     as produced by
99     .I pabopto2bsdf(1)
100     or similar, and produces a tensor tree representation with as many
101     components as there are independent input distributions.
102     Each intermediate scattering file contains one of
103     the four components, and if the first component
104     is isotropic, all components must be isotropic.
105     A similar rule holds for anisotropic inputs.
106 greg 1.3 The
107     .I \-l
108     option may be used to specify the maximum number of lobes in any
109     interpolated radial basis function.
110     The default value is 15000, which generally keeps the interpolation tractable.
111     Setting the value to 0 turns off this limit.
112 greg 1.9 Parameter options may be altered between input files, in case a different
113     resolution or culling percentage is indicated for transmission versus
114     reflection for example.
115 greg 1.1 .PP
116     In the second invocation form,
117     .I bsdf2ttree
118     takes a functional specification of a BSDF.
119 greg 1.2 The named function should accept 6 parameters corresponding to the
120 greg 1.1 normalized incident and exiting vectors, respectively.
121     By convention, these vectors point away from the surface, and a positive
122     Z-component corresponds to the front side.
123     The Y-component corresponds to the "up" orientation of the surface,
124     as specified in the eventual scene description that references the XML
125     output.
126 greg 1.2 If the function only takes 3 parameters, then the variables "Dx", "Dy",
127     and "Dz" will be assigned to the reverse of the outgoing direction at
128     each evaluation.
129     (I.e., the vector will point into the surface and
130     Dz will be negative on the front side.)\0
131     This simplifies conversion of functional BSDF specifications using the
132     legacy material primitives "plasfunc", "metfunc", and "transfunc".
133 greg 1.1 .PP
134     The function is defined by one or more
135     .I \-e
136     and
137     .I \-f
138     options, and should obey both Helmholtz reciprocity and
139     integrate to less than 1 over each projected incident hemisphere
140     for energy conservation.
141 greg 1.7 The variable and function definitions in each
142     .I \-f source
143     file are read and compiled from the RADIANCE library where it is found.
144 greg 1.1 If the
145     .I \-t3
146     option is specified, the defined function is assumed to be isotropic.
147     If the
148     .I \-t4
149     option is given, the function is assumed to be anisotropic.
150     .PP
151     Similar to the
152     .I genBSDF(1)
153     command,
154     the
155     .I \+backward
156     option (default) specifies that rays arriving from the front side of
157     the surface will be tested for reflection and transmission.
158     If both forward and backward (front and back) distributions are needed, the
159     .I \+forward
160     option may be given.
161     To turn off the backward components, use the
162     .I \-backward
163     option.
164     Computing both incident hemispheres takes about twice as long as one, but
165     is recommended when rays will be impinging from either side.
166     .SH EXAMPLE
167     To take two components of an intermediate BSDF representation and create
168 greg 1.9 a high-resolution tensor tree with 85% culling on transmission and 95%
169     culling on reflection:
170 greg 1.1 .IP "" .2i
171 greg 1.9 bsdf2ttree -g 7 -t 85 transmitted.sir -t 95 reflected.sir > combined.xml
172 greg 1.1 .PP
173     To create a low-res BSDF corresponding to a one-sided,
174     isotropic Phong distribution:
175     .IP "" .2i
176     bsdf2ttree -g 5 -t3 -e 'phong(ix,iy,iz,ox,oy,oz) = if(iz, .1+((iz+oz)/sqrt((ix+ox)^2+(iy+oy)^2+(iz+oz)^2))^50, 0)' phong > phong.xml
177 greg 1.7 .SH ENVIRONMENT
178     RAYPATH the directories to check for auxiliary files.
179 greg 1.1 .SH AUTHOR
180     Greg Ward
181     .SH "SEE ALSO"
182 greg 1.10 bsdf2klems(1), icalc(1), genBSDF(1), pabopto2bsdf(1), pabopto2xyz(1),
183     pkgBSDF(1), rcontrib(1), rfluxmtx(1), wrapBSDF(1)
