root/Development/ray/doc/man/man1/bsdf2ttree.1
Revision: 1.7
Committed: Fri May 4 23:56:49 2018 UTC (7 years, 7 months ago) by greg
Changes since 1.6: +6 -1 lines
# User Rev Content
1 greg 1.7 .\" RCSid $Id: bsdf2ttree.1,v 1.6 2017/05/31 17:25:21 greg Exp $
2 greg 1.1 .TH BSDF2TTREE 1 4/24/2013 RADIANCE
3     .SH NAME
4     bsdf2ttree - generate XML tensor tree description of a BSDF
5     .SH SYNOPSIS
6     .B bsdf2ttree
7     [
8 greg 1.4 .B "\-pC"
9     ][
10 greg 1.6 .B "{+|-}a"
11     ][
12 greg 1.1 .B "\-g Nlog2"
13     ][
14 greg 1.3 .B "\-t pctcull"
15     ][
16     .B "\-l maxlobes"
17 greg 1.1 ]
18     [
19     .B "bsdf.sir .."
20     ]
21     .br
22     or
23     .br
24     .B bsdf2ttree
25     .B "\-t{3|4}"
26     [
27 greg 1.4 .B "\-pC"
28     ][
29 greg 1.6 .B "{+|-}a"
30     ][
31 greg 1.1 .B "\-g Nlog2"
32     ][
33 greg 1.3 .B "\-t pctcull"
34 greg 1.1 ][
35     .B "{+|-}forward"
36     ][
37     .B "{+|-}backward"
38     ][
39 greg 1.3 .B "\-e expr"
40 greg 1.1 ][
41 greg 1.3 .B "\-f file"
42 greg 1.1 ]
43     .B bsdf_func
44     .SH DESCRIPTION
45     .I Bsdf2ttree
46     produces a tensor tree representation of a
47     bidirectional scattering distribution function (BSDF)
48     based on an intermediate representation (in the first form) or
49     a functional description (in the second form).
50     A complete XML description is written to the standard output,
51     which is normally redirected to a file.
52     .PP
53 greg 1.4 The
54     .I \-p
55     option by itself turns off the progress bar, whose length may be set
56     by an immediately following integer argument.
57     (The default progress bar length is 79 characters.)\0
58     .PP
59 greg 1.6 The
60     .I \-a
61     option turns off reciprocity averaging for isotropic scattering or anisotropic reflection.
62     Normally on (+a), this ensures that the tensor BRDF obeys Helmholtz reciprocity.
63     However, in certain rare cases, reciprocity averaging can cause unwanted noise in the output.
64     .PP
65 greg 1.1 The maximum resolution of the tensor tree may be controlled by the
66     .I \-g
67     option, which defaults to a value of 6.
68     This corresponds to a peak resolution of 2^6 (64) in each dimension.
69     Due to memory and time constraints, it is not recommended to set
70     .I \-g
71     higher than 7, which corresponds to a 128x128x128x128 initial sampling,
72     or 268 million values.
73     .PP
74     The initial sampling is pared down by the percentage specified with the
75     .I \-t
76     option, which defaults to 90.
77     Setting this parameter to -1 turns culling off entirely, which may be
78     useful for comparisons.
79     .PP
80     The first invocation form takes a intermediate scattering representation
81     as produced by
82     .I pabopto2bsdf(1)
83     or similar, and produces a tensor tree representation with as many
84     components as there are independent input distributions.
85     Each intermediate scattering file contains one of
86     the four components, and if the first component
87     is isotropic, all components must be isotropic.
88     A similar rule holds for anisotropic inputs.
89 greg 1.3 The
90     .I \-l
91     option may be used to specify the maximum number of lobes in any
92     interpolated radial basis function.
93     The default value is 15000, which generally keeps the interpolation tractable.
94     Setting the value to 0 turns off this limit.
95 greg 1.1 .PP
96     In the second invocation form,
97     .I bsdf2ttree
98     takes a functional specification of a BSDF.
99 greg 1.2 The named function should accept 6 parameters corresponding to the
100 greg 1.1 normalized incident and exiting vectors, respectively.
101     By convention, these vectors point away from the surface, and a positive
102     Z-component corresponds to the front side.
103     The Y-component corresponds to the "up" orientation of the surface,
104     as specified in the eventual scene description that references the XML
105     output.
106 greg 1.2 If the function only takes 3 parameters, then the variables "Dx", "Dy",
107     and "Dz" will be assigned to the reverse of the outgoing direction at
108     each evaluation.
109     (I.e., the vector will point into the surface and
110     Dz will be negative on the front side.)\0
111     This simplifies conversion of functional BSDF specifications using the
112     legacy material primitives "plasfunc", "metfunc", and "transfunc".
113 greg 1.1 .PP
114     The function is defined by one or more
115     .I \-e
116     and
117     .I \-f
118     options, and should obey both Helmholtz reciprocity and
119     integrate to less than 1 over each projected incident hemisphere
120     for energy conservation.
121 greg 1.7 The variable and function definitions in each
122     .I \-f source
123     file are read and compiled from the RADIANCE library where it is found.
124 greg 1.1 If the
125     .I \-t3
126     option is specified, the defined function is assumed to be isotropic.
127     If the
128     .I \-t4
129     option is given, the function is assumed to be anisotropic.
130     .PP
131     Similar to the
132     .I genBSDF(1)
133     command,
134     the
135     .I \+backward
136     option (default) specifies that rays arriving from the front side of
137     the surface will be tested for reflection and transmission.
138     If both forward and backward (front and back) distributions are needed, the
139     .I \+forward
140     option may be given.
141     To turn off the backward components, use the
142     .I \-backward
143     option.
144     Computing both incident hemispheres takes about twice as long as one, but
145     is recommended when rays will be impinging from either side.
146     .SH EXAMPLE
147     To take two components of an intermediate BSDF representation and create
148     a high-resolution tensor tree with 85% culling:
149     .IP "" .2i
150     bsdf2ttree -g 7 -t 85 transmitted.sir reflected.sir > combined.xml
151     .PP
152     To create a low-res BSDF corresponding to a one-sided,
153     isotropic Phong distribution:
154     .IP "" .2i
155     bsdf2ttree -g 5 -t3 -e 'phong(ix,iy,iz,ox,oy,oz) = if(iz, .1+((iz+oz)/sqrt((ix+ox)^2+(iy+oy)^2+(iz+oz)^2))^50, 0)' phong > phong.xml
156 greg 1.7 .SH ENVIRONMENT
157     RAYPATH the directories to check for auxiliary files.
158 greg 1.1 .SH AUTHOR
159     Greg Ward
160     .SH "SEE ALSO"
161 greg 1.5 bsdf2klems(1), icalc(1), genBSDF(1), pkgBSDF(1), rcontrib(1),
162     rfluxmtx(1), wrapBSDF(1)
