1 |
.\" RCSid $Id: bsdf2ttree.1,v 1.12 2023/09/12 16:40:57 greg Exp $ |
2 |
.TH BSDF2TTREE 1 4/24/2013 RADIANCE |
3 |
.SH NAME |
4 |
bsdf2ttree - generate XML tensor tree description of a BSDF |
5 |
.SH SYNOPSIS |
6 |
.B bsdf2ttree |
7 |
8 |
.B "\-pC" |
9 |
10 |
.B "{+|-}a" |
11 |
12 |
.B "\-g Nlog2" |
13 |
14 |
.B "\-t pctcull" |
15 |
16 |
.B "\-n nss" |
17 |
18 |
.B "\-s thresh" |
19 |
20 |
.B "\-l maxlobes" |
21 |
22 |
.B "bsdf.sir .." |
23 |
24 |
.br |
25 |
or |
26 |
.br |
27 |
.B bsdf2ttree |
28 |
.B "\-t{3|4}" |
29 |
30 |
.B "\-pC" |
31 |
32 |
.B "{+|-}a" |
33 |
34 |
.B "\-g Nlog2" |
35 |
36 |
.B "\-t pctcull" |
37 |
38 |
.B "\-n nss" |
39 |
40 |
.B "\-s thresh" |
41 |
42 |
.B "{+|-}forward" |
43 |
44 |
.B "{+|-}backward" |
45 |
46 |
.B "\-e expr" |
47 |
48 |
.B "\-f file" |
49 |
50 |
.B bsdf_func |
51 |
.SH DESCRIPTION |
52 |
.I Bsdf2ttree |
53 |
produces a tensor tree representation of a |
54 |
bidirectional scattering distribution function (BSDF) |
55 |
based on an intermediate representation (in the first form) or |
56 |
a functional description (in the second form). |
57 |
A complete XML description is written to the standard output, |
58 |
which is normally redirected to a file. |
59 |
.PP |
60 |
The |
61 |
.I \-p |
62 |
option by itself turns off the progress bar, whose length may be set |
63 |
by an immediately following integer argument. |
64 |
(The default progress bar length is 79 characters.)\0 |
65 |
.PP |
66 |
The |
67 |
.I \+a |
68 |
option turns on reciprocity averaging for isotropic scattering or anisotropic reflection. |
69 |
Normally off (-a), this enforces each tensor-tree hemisphere to follow symmetry |
70 |
implied by Helmholtz reciprocity, and is designed to reduce noise in measured data. |
71 |
However, for some data, reciprocity averaging can make the output worse. |
72 |
.PP |
73 |
The maximum resolution of the tensor tree may be controlled by the |
74 |
.I \-g |
75 |
option, which defaults to a value of 6. |
76 |
This corresponds to a peak resolution of 2^6 (64) in each dimension. |
77 |
Due to memory and time constraints, it is not recommended to set |
78 |
.I \-g |
79 |
higher than 7, which corresponds to a 128x128x128x128 initial sampling, |
80 |
or 268 million values. |
81 |
.PP |
82 |
The initial sampling is pared down by the percentage specified with the |
83 |
.I \-t |
84 |
option, which defaults to 90. |
85 |
Setting this parameter to -1 turns culling off entirely, which may be |
86 |
useful for comparisons. |
87 |
.PP |
88 |
The |
89 |
.I \-n |
90 |
option controls the number of super-samples to send in patches whose |
91 |
difference to its neighbors exceeds some threshold. |
92 |
The default number of super-samples is 64. |
93 |
The difference threshold for super-sampling is controlled by the |
94 |
.I \-s |
95 |
option, and defaults to 0.35. |
96 |
.PP |
97 |
The first invocation form takes a intermediate scattering representation |
98 |
as produced by |
99 |
.I pabopto2bsdf(1) |
100 |
or similar, and produces a tensor tree representation with as many |
101 |
components as there are independent input distributions. |
102 |
Each intermediate scattering file contains one of |
103 |
the four components, and if the first component |
104 |
is isotropic, all components must be isotropic. |
105 |
A similar rule holds for anisotropic inputs. |
106 |
The |
107 |
.I \-l |
108 |
option may be used to specify the maximum number of lobes in any |
109 |
interpolated radial basis function. |
110 |
The default value is 15000, which generally keeps the interpolation tractable. |
111 |
Setting the value to 0 turns off this limit. |
112 |
Parameter options may be altered between input files, in case a different |
113 |
resolution or culling percentage is indicated for transmission versus |
114 |
reflection for example. |
115 |
.PP |
116 |
In the second invocation form, |
117 |
.I bsdf2ttree |
118 |
takes a functional specification of a BSDF. |
119 |
The named function should accept 6 parameters corresponding to the |
120 |
normalized incident and exiting vectors, respectively. |
121 |
By convention, these vectors point away from the surface, and a positive |
122 |
Z-component corresponds to the front side. |
123 |
The Y-component corresponds to the "up" orientation of the surface, |
124 |
as specified in the eventual scene description that references the XML |
125 |
output. |
126 |
If the function only takes 3 parameters, then the variables "Dx", "Dy", |
127 |
and "Dz" will be assigned to the reverse of the outgoing direction at |
128 |
each evaluation. |
129 |
(I.e., the vector will point into the surface and |
130 |
Dz will be negative on the front side.)\0 |
131 |
This simplifies conversion of functional BSDF specifications using the |
132 |
legacy material primitives "plasfunc", "metfunc", and "transfunc". |
133 |
.PP |
134 |
The function is defined by one or more |
135 |
.I \-e |
136 |
and |
137 |
.I \-f |
138 |
options, and should obey both Helmholtz reciprocity and |
139 |
integrate to less than 1 over each projected incident hemisphere |
140 |
for energy conservation. |
141 |
The variable and function definitions in each |
142 |
.I \-f source |
143 |
file are read and compiled from the RADIANCE library where it is found. |
144 |
If the |
145 |
.I \-t3 |
146 |
option is specified, the defined function is assumed to be isotropic. |
147 |
If the |
148 |
.I \-t4 |
149 |
option is given, the function is assumed to be anisotropic. |
150 |
.PP |
151 |
Similar to the |
152 |
.I genBSDF(1) |
153 |
command, |
154 |
the |
155 |
.I \+backward |
156 |
option (default) specifies that rays arriving from the front side of |
157 |
the surface will be tested for reflection and transmission. |
158 |
If both forward and backward (front and back) distributions are needed, the |
159 |
.I \+forward |
160 |
option may be given. |
161 |
To turn off the backward components, use the |
162 |
.I \-backward |
163 |
option. |
164 |
Computing both incident hemispheres takes about twice as long as one, but |
165 |
is recommended when rays will be impinging from either side. |
166 |
.SH EXAMPLE |
167 |
To take two components of an intermediate BSDF representation and create |
168 |
a high-resolution tensor tree with 85% culling on transmission and 95% |
169 |
culling on reflection: |
170 |
.IP "" .2i |
171 |
bsdf2ttree -g 7 -t 85 transmitted.sir -t 95 reflected.sir > combined.xml |
172 |
.PP |
173 |
To create a low-res BSDF corresponding to a one-sided, |
174 |
isotropic Phong distribution: |
175 |
.IP "" .2i |
176 |
bsdf2ttree -g 5 -t3 -e 'phong(ix,iy,iz,ox,oy,oz) = if(iz, .1+((iz+oz)/sqrt((ix+ox)^2+(iy+oy)^2+(iz+oz)^2))^50, 0)' phong > phong.xml |
177 |
.SH ENVIRONMENT |
178 |
RAYPATH the directories to check for auxiliary files. |
179 |
.SH AUTHOR |
180 |
Greg Ward |
181 |
.SH "SEE ALSO" |
182 |
bsdf2klems(1), icalc(1), genBSDF(1), pabopto2bsdf(1), pabopto2xyz(1), |
183 |
pkgBSDF(1), rcontrib(1), rfluxmtx(1), wrapBSDF(1) |
