| 1 |
.\" RCSid $Id: bsdf2ttree.1,v 1.8 2020/05/18 20:08:57 greg Exp $
| 2 |
.TH BSDF2TTREE 1 4/24/2013 RADIANCE
| 3 |
.SH NAME
| 4 |
bsdf2ttree - generate XML tensor tree description of a BSDF
| 5 |
.SH SYNOPSIS
| 6 |
.B bsdf2ttree
| 7 |
| 8 |
.B "\-pC"
| 9 |
| 10 |
.B "{+|-}a"
| 11 |
| 12 |
.B "\-g Nlog2"
| 13 |
| 14 |
.B "\-t pctcull"
| 15 |
| 16 |
.B "\-n nss"
| 17 |
| 18 |
.B "\-s thresh"
| 19 |
| 20 |
.B "\-l maxlobes"
| 21 |
| 22 |
.B "bsdf.sir .."
| 23 |
| 24 |
.br
| 25 |
or
| 26 |
.br
| 27 |
.B bsdf2ttree
| 28 |
.B "\-t{3|4}"
| 29 |
| 30 |
.B "\-pC"
| 31 |
| 32 |
.B "{+|-}a"
| 33 |
| 34 |
.B "\-g Nlog2"
| 35 |
| 36 |
.B "\-t pctcull"
| 37 |
| 38 |
.B "\-n nss"
| 39 |
| 40 |
.B "\-s thresh"
| 41 |
| 42 |
.B "{+|-}forward"
| 43 |
| 44 |
.B "{+|-}backward"
| 45 |
| 46 |
.B "\-e expr"
| 47 |
| 48 |
.B "\-f file"
| 49 |
| 50 |
.B bsdf_func
| 51 |
.SH DESCRIPTION
| 52 |
.I Bsdf2ttree
| 53 |
produces a tensor tree representation of a
| 54 |
bidirectional scattering distribution function (BSDF)
| 55 |
based on an intermediate representation (in the first form) or
| 56 |
a functional description (in the second form).
| 57 |
A complete XML description is written to the standard output,
| 58 |
which is normally redirected to a file.
| 59 |
.PP
| 60 |
The
| 61 |
.I \-p
| 62 |
option by itself turns off the progress bar, whose length may be set
| 63 |
by an immediately following integer argument.
| 64 |
(The default progress bar length is 79 characters.)\0
| 65 |
.PP
| 66 |
The
| 67 |
.I \-a
| 68 |
option turns off reciprocity averaging for isotropic scattering or anisotropic reflection.
| 69 |
Normally on (+a), this ensures that the tensor BRDF obeys Helmholtz reciprocity.
| 70 |
However, in certain rare cases, reciprocity averaging can cause unwanted noise in the output.
| 71 |
.PP
| 72 |
The maximum resolution of the tensor tree may be controlled by the
| 73 |
.I \-g
| 74 |
option, which defaults to a value of 6.
| 75 |
This corresponds to a peak resolution of 2^6 (64) in each dimension.
| 76 |
Due to memory and time constraints, it is not recommended to set
| 77 |
.I \-g
| 78 |
higher than 7, which corresponds to a 128x128x128x128 initial sampling,
| 79 |
or 268 million values.
| 80 |
.PP
| 81 |
The initial sampling is pared down by the percentage specified with the
| 82 |
.I \-t
| 83 |
option, which defaults to 90.
| 84 |
Setting this parameter to -1 turns culling off entirely, which may be
| 85 |
useful for comparisons.
| 86 |
.PP
| 87 |
The
| 88 |
.I \-n
| 89 |
option controls the number of super-samples to send in patches whose
| 90 |
difference to its neighbors exceeds some threshold.
| 91 |
The default number of super-samples is 256.
| 92 |
The difference threshold for super-sampling is controlled by the
| 93 |
.I \-s
| 94 |
option, and defaults to 0.35.
| 95 |
.PP
| 96 |
The first invocation form takes a intermediate scattering representation
| 97 |
as produced by
| 98 |
.I pabopto2bsdf(1)
| 99 |
or similar, and produces a tensor tree representation with as many
| 100 |
components as there are independent input distributions.
| 101 |
Each intermediate scattering file contains one of
| 102 |
the four components, and if the first component
| 103 |
is isotropic, all components must be isotropic.
| 104 |
A similar rule holds for anisotropic inputs.
| 105 |
The
| 106 |
.I \-l
| 107 |
option may be used to specify the maximum number of lobes in any
| 108 |
interpolated radial basis function.
| 109 |
The default value is 15000, which generally keeps the interpolation tractable.
| 110 |
Setting the value to 0 turns off this limit.
| 111 |
Parameter options may be altered between input files, in case a different
| 112 |
resolution or culling percentage is indicated for transmission versus
| 113 |
reflection for example.
| 114 |
.PP
| 115 |
In the second invocation form,
| 116 |
.I bsdf2ttree
| 117 |
takes a functional specification of a BSDF.
| 118 |
The named function should accept 6 parameters corresponding to the
| 119 |
normalized incident and exiting vectors, respectively.
| 120 |
By convention, these vectors point away from the surface, and a positive
| 121 |
Z-component corresponds to the front side.
| 122 |
The Y-component corresponds to the "up" orientation of the surface,
| 123 |
as specified in the eventual scene description that references the XML
| 124 |
output.
| 125 |
If the function only takes 3 parameters, then the variables "Dx", "Dy",
| 126 |
and "Dz" will be assigned to the reverse of the outgoing direction at
| 127 |
each evaluation.
| 128 |
(I.e., the vector will point into the surface and
| 129 |
Dz will be negative on the front side.)\0
| 130 |
This simplifies conversion of functional BSDF specifications using the
| 131 |
legacy material primitives "plasfunc", "metfunc", and "transfunc".
| 132 |
.PP
| 133 |
The function is defined by one or more
| 134 |
.I \-e
| 135 |
and
| 136 |
.I \-f
| 137 |
options, and should obey both Helmholtz reciprocity and
| 138 |
integrate to less than 1 over each projected incident hemisphere
| 139 |
for energy conservation.
| 140 |
The variable and function definitions in each
| 141 |
.I \-f source
| 142 |
file are read and compiled from the RADIANCE library where it is found.
| 143 |
If the
| 144 |
.I \-t3
| 145 |
option is specified, the defined function is assumed to be isotropic.
| 146 |
If the
| 147 |
.I \-t4
| 148 |
option is given, the function is assumed to be anisotropic.
| 149 |
.PP
| 150 |
Similar to the
| 151 |
.I genBSDF(1)
| 152 |
command,
| 153 |
the
| 154 |
.I \+backward
| 155 |
option (default) specifies that rays arriving from the front side of
| 156 |
the surface will be tested for reflection and transmission.
| 157 |
If both forward and backward (front and back) distributions are needed, the
| 158 |
.I \+forward
| 159 |
option may be given.
| 160 |
To turn off the backward components, use the
| 161 |
.I \-backward
| 162 |
option.
| 163 |
Computing both incident hemispheres takes about twice as long as one, but
| 164 |
is recommended when rays will be impinging from either side.
| 165 |
.SH EXAMPLE
| 166 |
To take two components of an intermediate BSDF representation and create
| 167 |
a high-resolution tensor tree with 85% culling on transmission and 95%
| 168 |
culling on reflection:
| 169 |
.IP "" .2i
| 170 |
bsdf2ttree -g 7 -t 85 transmitted.sir -t 95 reflected.sir > combined.xml
| 171 |
.PP
| 172 |
To create a low-res BSDF corresponding to a one-sided,
| 173 |
isotropic Phong distribution:
| 174 |
.IP "" .2i
| 175 |
bsdf2ttree -g 5 -t3 -e 'phong(ix,iy,iz,ox,oy,oz) = if(iz, .1+((iz+oz)/sqrt((ix+ox)^2+(iy+oy)^2+(iz+oz)^2))^50, 0)' phong > phong.xml
| 176 |
.SH ENVIRONMENT
| 177 |
RAYPATH the directories to check for auxiliary files.
| 178 |
.SH AUTHOR
| 179 |
Greg Ward
| 180 |
.SH "SEE ALSO"
| 181 |
bsdf2klems(1), icalc(1), genBSDF(1), pkgBSDF(1), rcontrib(1),
| 182 |
rfluxmtx(1), wrapBSDF(1)
