root/radiance/ray/doc/man/man1/bsdf2ttree.1
Revision: 1.7
Committed: Fri May 4 23:56:49 2018 UTC (7 years ago) by greg
Changes since 1.6: +6 -1 lines
1 .\" RCSid $Id: bsdf2ttree.1,v 1.6 2017/05/31 17:25:21 greg Exp $
2 .TH BSDF2TTREE 1 4/24/2013 RADIANCE
3 .SH NAME
4 bsdf2ttree - generate XML tensor tree description of a BSDF
5 .SH SYNOPSIS
6 .B bsdf2ttree
7 [
8 .B "\-pC"
9 ][
10 .B "{+|-}a"
11 ][
12 .B "\-g Nlog2"
13 ][
14 .B "\-t pctcull"
15 ][
16 .B "\-l maxlobes"
17 ]
18 [
19 .B "bsdf.sir .."
20 ]
21 .br
22 or
23 .br
24 .B bsdf2ttree
25 .B "\-t{3|4}"
26 [
27 .B "\-pC"
28 ][
29 .B "{+|-}a"
30 ][
31 .B "\-g Nlog2"
32 ][
33 .B "\-t pctcull"
34 ][
35 .B "{+|-}forward"
36 ][
37 .B "{+|-}backward"
38 ][
39 .B "\-e expr"
40 ][
41 .B "\-f file"
42 ]
43 .B bsdf_func
44 .SH DESCRIPTION
45 .I Bsdf2ttree
46 produces a tensor tree representation of a
47 bidirectional scattering distribution function (BSDF)
48 based on an intermediate representation (in the first form) or
49 a functional description (in the second form).
50 A complete XML description is written to the standard output,
51 which is normally redirected to a file.
52 .PP
53 The
54 .I \-p
55 option by itself turns off the progress bar, whose length may be set
56 by an immediately following integer argument.
57 (The default progress bar length is 79 characters.)\0
58 .PP
59 The
60 .I \-a
61 option turns off reciprocity averaging for isotropic scattering or anisotropic reflection.
62 Normally on (+a), this ensures that the tensor BRDF obeys Helmholtz reciprocity.
63 However, in certain rare cases, reciprocity averaging can cause unwanted noise in the output.
64 .PP
65 The maximum resolution of the tensor tree may be controlled by the
66 .I \-g
67 option, which defaults to a value of 6.
68 This corresponds to a peak resolution of 2^6 (64) in each dimension.
69 Due to memory and time constraints, it is not recommended to set
70 .I \-g
71 higher than 7, which corresponds to a 128x128x128x128 initial sampling,
72 or 268 million values.
73 .PP
74 The initial sampling is pared down by the percentage specified with the
75 .I \-t
76 option, which defaults to 90.
77 Setting this parameter to -1 turns culling off entirely, which may be
78 useful for comparisons.
79 .PP
80 The first invocation form takes a intermediate scattering representation
81 as produced by
82 .I pabopto2bsdf(1)
83 or similar, and produces a tensor tree representation with as many
84 components as there are independent input distributions.
85 Each intermediate scattering file contains one of
86 the four components, and if the first component
87 is isotropic, all components must be isotropic.
88 A similar rule holds for anisotropic inputs.
89 The
90 .I \-l
91 option may be used to specify the maximum number of lobes in any
92 interpolated radial basis function.
93 The default value is 15000, which generally keeps the interpolation tractable.
94 Setting the value to 0 turns off this limit.
95 .PP
96 In the second invocation form,
97 .I bsdf2ttree
98 takes a functional specification of a BSDF.
99 The named function should accept 6 parameters corresponding to the
100 normalized incident and exiting vectors, respectively.
101 By convention, these vectors point away from the surface, and a positive
102 Z-component corresponds to the front side.
103 The Y-component corresponds to the "up" orientation of the surface,
104 as specified in the eventual scene description that references the XML
105 output.
106 If the function only takes 3 parameters, then the variables "Dx", "Dy",
107 and "Dz" will be assigned to the reverse of the outgoing direction at
108 each evaluation.
109 (I.e., the vector will point into the surface and
110 Dz will be negative on the front side.)\0
111 This simplifies conversion of functional BSDF specifications using the
112 legacy material primitives "plasfunc", "metfunc", and "transfunc".
113 .PP
114 The function is defined by one or more
115 .I \-e
116 and
117 .I \-f
118 options, and should obey both Helmholtz reciprocity and
119 integrate to less than 1 over each projected incident hemisphere
120 for energy conservation.
121 The variable and function definitions in each
122 .I \-f source
123 file are read and compiled from the RADIANCE library where it is found.
124 If the
125 .I \-t3
126 option is specified, the defined function is assumed to be isotropic.
127 If the
128 .I \-t4
129 option is given, the function is assumed to be anisotropic.
130 .PP
131 Similar to the
132 .I genBSDF(1)
133 command,
134 the
135 .I \+backward
136 option (default) specifies that rays arriving from the front side of
137 the surface will be tested for reflection and transmission.
138 If both forward and backward (front and back) distributions are needed, the
139 .I \+forward
140 option may be given.
141 To turn off the backward components, use the
142 .I \-backward
143 option.
144 Computing both incident hemispheres takes about twice as long as one, but
145 is recommended when rays will be impinging from either side.
146 .SH EXAMPLE
147 To take two components of an intermediate BSDF representation and create
148 a high-resolution tensor tree with 85% culling:
149 .IP "" .2i
150 bsdf2ttree -g 7 -t 85 transmitted.sir reflected.sir > combined.xml
151 .PP
152 To create a low-res BSDF corresponding to a one-sided,
153 isotropic Phong distribution:
154 .IP "" .2i
155 bsdf2ttree -g 5 -t3 -e 'phong(ix,iy,iz,ox,oy,oz) = if(iz, .1+((iz+oz)/sqrt((ix+ox)^2+(iy+oy)^2+(iz+oz)^2))^50, 0)' phong > phong.xml
156 .SH ENVIRONMENT
157 RAYPATH the directories to check for auxiliary files.
158 .SH AUTHOR
159 Greg Ward
160 .SH "SEE ALSO"
161 bsdf2klems(1), icalc(1), genBSDF(1), pkgBSDF(1), rcontrib(1),
162 rfluxmtx(1), wrapBSDF(1)
