root/radiance/ray/doc/man/man1/bsdf2ttree.1
Revision: 1.13
Committed: Wed May 21 20:42:48 2025 UTC (4 weeks, 4 days ago) by greg
perf(bsdf2ttree): Changed default -n from 256 down to 64 for faster calcs
1 .\" RCSid $Id: bsdf2ttree.1,v 1.12 2023/09/12 16:40:57 greg Exp $
2 .TH BSDF2TTREE 1 4/24/2013 RADIANCE
3 .SH NAME
4 bsdf2ttree - generate XML tensor tree description of a BSDF
5 .SH SYNOPSIS
6 .B bsdf2ttree
7 [
8 .B "\-pC"
9 ][
10 .B "{+|-}a"
11 ][
12 .B "\-g Nlog2"
13 ][
14 .B "\-t pctcull"
15 ][
16 .B "\-n nss"
17 ][
18 .B "\-s thresh"
19 ][
20 .B "\-l maxlobes"
21 ][
22 .B "bsdf.sir .."
23 ]
24 .br
25 or
26 .br
27 .B bsdf2ttree
28 .B "\-t{3|4}"
29 [
30 .B "\-pC"
31 ][
32 .B "{+|-}a"
33 ][
34 .B "\-g Nlog2"
35 ][
36 .B "\-t pctcull"
37 ][
38 .B "\-n nss"
39 ][
40 .B "\-s thresh"
41 ][
42 .B "{+|-}forward"
43 ][
44 .B "{+|-}backward"
45 ][
46 .B "\-e expr"
47 ][
48 .B "\-f file"
49 ]
50 .B bsdf_func
51 .SH DESCRIPTION
52 .I Bsdf2ttree
53 produces a tensor tree representation of a
54 bidirectional scattering distribution function (BSDF)
55 based on an intermediate representation (in the first form) or
56 a functional description (in the second form).
57 A complete XML description is written to the standard output,
58 which is normally redirected to a file.
59 .PP
60 The
61 .I \-p
62 option by itself turns off the progress bar, whose length may be set
63 by an immediately following integer argument.
64 (The default progress bar length is 79 characters.)\0
65 .PP
66 The
67 .I \+a
68 option turns on reciprocity averaging for isotropic scattering or anisotropic reflection.
69 Normally off (-a), this enforces each tensor-tree hemisphere to follow symmetry
70 implied by Helmholtz reciprocity, and is designed to reduce noise in measured data.
71 However, for some data, reciprocity averaging can make the output worse.
72 .PP
73 The maximum resolution of the tensor tree may be controlled by the
74 .I \-g
75 option, which defaults to a value of 6.
76 This corresponds to a peak resolution of 2^6 (64) in each dimension.
77 Due to memory and time constraints, it is not recommended to set
78 .I \-g
79 higher than 7, which corresponds to a 128x128x128x128 initial sampling,
80 or 268 million values.
81 .PP
82 The initial sampling is pared down by the percentage specified with the
83 .I \-t
84 option, which defaults to 90.
85 Setting this parameter to -1 turns culling off entirely, which may be
86 useful for comparisons.
87 .PP
88 The
89 .I \-n
90 option controls the number of super-samples to send in patches whose
91 difference to its neighbors exceeds some threshold.
92 The default number of super-samples is 64.
93 The difference threshold for super-sampling is controlled by the
94 .I \-s
95 option, and defaults to 0.35.
96 .PP
97 The first invocation form takes a intermediate scattering representation
98 as produced by
99 .I pabopto2bsdf(1)
100 or similar, and produces a tensor tree representation with as many
101 components as there are independent input distributions.
102 Each intermediate scattering file contains one of
103 the four components, and if the first component
104 is isotropic, all components must be isotropic.
105 A similar rule holds for anisotropic inputs.
106 The
107 .I \-l
108 option may be used to specify the maximum number of lobes in any
109 interpolated radial basis function.
110 The default value is 15000, which generally keeps the interpolation tractable.
111 Setting the value to 0 turns off this limit.
112 Parameter options may be altered between input files, in case a different
113 resolution or culling percentage is indicated for transmission versus
114 reflection for example.
115 .PP
116 In the second invocation form,
117 .I bsdf2ttree
118 takes a functional specification of a BSDF.
119 The named function should accept 6 parameters corresponding to the
120 normalized incident and exiting vectors, respectively.
121 By convention, these vectors point away from the surface, and a positive
122 Z-component corresponds to the front side.
123 The Y-component corresponds to the "up" orientation of the surface,
124 as specified in the eventual scene description that references the XML
125 output.
126 If the function only takes 3 parameters, then the variables "Dx", "Dy",
127 and "Dz" will be assigned to the reverse of the outgoing direction at
128 each evaluation.
129 (I.e., the vector will point into the surface and
130 Dz will be negative on the front side.)\0
131 This simplifies conversion of functional BSDF specifications using the
132 legacy material primitives "plasfunc", "metfunc", and "transfunc".
133 .PP
134 The function is defined by one or more
135 .I \-e
136 and
137 .I \-f
138 options, and should obey both Helmholtz reciprocity and
139 integrate to less than 1 over each projected incident hemisphere
140 for energy conservation.
141 The variable and function definitions in each
142 .I \-f source
143 file are read and compiled from the RADIANCE library where it is found.
144 If the
145 .I \-t3
146 option is specified, the defined function is assumed to be isotropic.
147 If the
148 .I \-t4
149 option is given, the function is assumed to be anisotropic.
150 .PP
151 Similar to the
152 .I genBSDF(1)
153 command,
154 the
155 .I \+backward
156 option (default) specifies that rays arriving from the front side of
157 the surface will be tested for reflection and transmission.
158 If both forward and backward (front and back) distributions are needed, the
159 .I \+forward
160 option may be given.
161 To turn off the backward components, use the
162 .I \-backward
163 option.
164 Computing both incident hemispheres takes about twice as long as one, but
165 is recommended when rays will be impinging from either side.
166 .SH EXAMPLE
167 To take two components of an intermediate BSDF representation and create
168 a high-resolution tensor tree with 85% culling on transmission and 95%
169 culling on reflection:
170 .IP "" .2i
171 bsdf2ttree -g 7 -t 85 transmitted.sir -t 95 reflected.sir > combined.xml
172 .PP
173 To create a low-res BSDF corresponding to a one-sided,
174 isotropic Phong distribution:
175 .IP "" .2i
176 bsdf2ttree -g 5 -t3 -e 'phong(ix,iy,iz,ox,oy,oz) = if(iz, .1+((iz+oz)/sqrt((ix+ox)^2+(iy+oy)^2+(iz+oz)^2))^50, 0)' phong > phong.xml
177 .SH ENVIRONMENT
178 RAYPATH the directories to check for auxiliary files.
179 .SH AUTHOR
180 Greg Ward
181 .SH "SEE ALSO"
182 bsdf2klems(1), icalc(1), genBSDF(1), pabopto2bsdf(1), pabopto2xyz(1),
183 pkgBSDF(1), rcontrib(1), rfluxmtx(1), wrapBSDF(1)
