root/radiance/ray/doc/man/man1/bsdf2rad.1
Revision: 1.5
Committed: Mon Sep 11 18:44:42 2023 UTC (20 months, 1 week ago) by greg
CVS Tags: rad5R4, HEAD
docs(bsdf2rad): word missing
# User Rev Content
1 greg 1.5 .\" RCSid "$Id: bsdf2rad.1,v 1.4 2021/02/25 04:48:19 greg Exp $"
2 greg 1.1 .TH BSDF2RAD 1 8/11/2017 RADIANCE
3     .SH NAME
4     bsdf2rad - create a RADIANCE visualization of a BSDF representation
5     .SH SYNOPSIS
6     .B bsdf2rad
7 greg 1.2 [
8     .B "\-r min max"
9     ]
10 greg 1.1 bsdf.xml
11     .br
12     or
13     .br
14     .B bsdf2rad
15 greg 1.2 [
16     .B "\-r min max"
17     ]
18 greg 1.1 hemi1.sir
19     [
20     hemi2.sir ..
21     ]
22     .br
23     .SH DESCRIPTION
24     .I Bsdf2rad
25     takes a bidirectional scattering distribution function (BSDF)
26     and plots it as a RADIANCE scene file.
27     In the first form,
28     .I bsdf2rad
29 greg 1.5 takes a single XML file representing a Klems or tensor tree BSDF, plotting
30 greg 1.1 as many scattering hemispheres as are present in the file.
31     In the second form,
32     .I bsdf2rad
33     takes up to four scattering interpolation representation (SIR) files,
34     each depicting the BSDF from one side of one incident hemisphere,
35     and plots them together.
36     An XML BSDF description may be imported from outside RADIANCE, or
37     produced by
38     .I genBSDF(1),
39     .I bsdf2klems(1),
40     or
41     .I bsdf2ttree(1).
42     (A program that produces SIR files is
43     .I pabopto2bsdf(1).)\0
44     .PP
45     The output of
46     .I bsdf2rad
47     is a RADIANCE scene that contains a selection of 3-D plots showing
48     the given material's reflection and transmission scattering.
49     This description is normally sent to
50     .I oconv(1)
51     to create an octree for rendering using
52     .I rad(1),
53     .I rvu(1),
54     or
55     .I rpict(1).
56     .PP
57     To the right (+X) of the scene, the front incident hemisphere will be plotted.
58     To the left (-X) of the scene, the back incident hemisphere will be plotted.
59     Depending on the input, only one or the other hemisphere may be present.
60     In the case of an XML input, the hemispheres will be made of the specified
61     BSDF material, and the scene
62     will include a single (distant) light source shining straight
63     down from overhead (+Z direction).
64     .PP
65     Pink arrows will indicate the "through" (view) and "mirror"
66     (specular reflection) directions for each scatter plot.
67     The logarithmic scale of the BSDF plots themselves will be determined
68     automatically by the data and shown in a legend that lies between the
69     two hemisphere, or to the side if there is only one.
70     The incident direction may be read from the position of
71     each plot, where hemisphere grid lines are separated by
72     15 degree increments in the polar (theta, latitude) angle, and by
73     30 degree increments in the azimuthal (phi, longitude) angle.
74     The center (+Z) of each hemisphere corresponds to normal incidence,
75     and the right (+X) direction corresponds to a zero phi angle.
76     Positive phi is read counter-clockwise from above,
77     and a phi of 90 degrees (+Y) typically corresponds
78     to a material's "up" orientation.
79 greg 1.2 .PP
80     If an optional plotting range is given with the
81     .I \-r
82     option, this will override automatic settings from the BSDF input.
83     This may be useful for comparing different BSDF sources.
84 greg 1.1 .SH EXAMPLE
85     To view a BSDF XML representation:
86     .IP "" .2i
87     bsdf2rad cloth.xml | oconv - > cloth.oct
88     .br
89     rvu -vp 0 -50 50 -vd 0 50 -50 -vh 45 -vv 30 cloth.oct
90     .PP
91     To render an SIR description of a BRDF:
92     .IP "" .2i
93     bsdf2rad front_refl.sir back_refl.sir > refl.rad
94 greg 1.3 .br
95 greg 1.1 oconv -f refl.rad | rpict -vf good.vf > refl_good.hdr
96     .SH AUTHOR
97     Greg Ward
98     .SH "SEE ALSO"
99     bsdf2klems(1), bsdf2ttree(1), genBSDF(1),
100 greg 1.4 bsdfview(1), oconv(1), pabopto2bsdf(1), pabopto2xyz(1), rad(1), rpict(1), rvu(1)
