root/radiance/ray/doc/man/man1/bsdf2rad.1
Revision: 1.1
Committed: Fri Aug 11 21:39:52 2017 UTC (7 years, 8 months ago) by greg
# User Rev Content
1 greg 1.1 .\" RCSid "$Id: objview.1,v 1.5 2014/04/16 20:48:07 greg Exp $"
2     .TH BSDF2RAD 1 8/11/2017 RADIANCE
3     .SH NAME
4     bsdf2rad - create a RADIANCE visualization of a BSDF representation
5     .SH SYNOPSIS
6     .B bsdf2rad
7     bsdf.xml
8     .br
9     or
10     .br
11     .B bsdf2rad
12     hemi1.sir
13     [
14     hemi2.sir ..
15     ]
16     .br
17     .SH DESCRIPTION
18     .I Bsdf2rad
19     takes a bidirectional scattering distribution function (BSDF)
20     and plots it as a RADIANCE scene file.
21     In the first form,
22     .I bsdf2rad
23     takes a single XML file representing a Klems or tensor tree, plotting
24     as many scattering hemispheres as are present in the file.
25     In the second form,
26     .I bsdf2rad
27     takes up to four scattering interpolation representation (SIR) files,
28     each depicting the BSDF from one side of one incident hemisphere,
29     and plots them together.
30     An XML BSDF description may be imported from outside RADIANCE, or
31     produced by
32     .I genBSDF(1),
33     .I bsdf2klems(1),
34     or
35     .I bsdf2ttree(1).
36     (A program that produces SIR files is
37     .I pabopto2bsdf(1).)\0
38     .PP
39     The output of
40     .I bsdf2rad
41     is a RADIANCE scene that contains a selection of 3-D plots showing
42     the given material's reflection and transmission scattering.
43     This description is normally sent to
44     .I oconv(1)
45     to create an octree for rendering using
46     .I rad(1),
47     .I rvu(1),
48     or
49     .I rpict(1).
50     .PP
51     To the right (+X) of the scene, the front incident hemisphere will be plotted.
52     To the left (-X) of the scene, the back incident hemisphere will be plotted.
53     Depending on the input, only one or the other hemisphere may be present.
54     In the case of an XML input, the hemispheres will be made of the specified
55     BSDF material, and the scene
56     will include a single (distant) light source shining straight
57     down from overhead (+Z direction).
58     .PP
59     Pink arrows will indicate the "through" (view) and "mirror"
60     (specular reflection) directions for each scatter plot.
61     The logarithmic scale of the BSDF plots themselves will be determined
62     automatically by the data and shown in a legend that lies between the
63     two hemisphere, or to the side if there is only one.
64     The incident direction may be read from the position of
65     each plot, where hemisphere grid lines are separated by
66     15 degree increments in the polar (theta, latitude) angle, and by
67     30 degree increments in the azimuthal (phi, longitude) angle.
68     The center (+Z) of each hemisphere corresponds to normal incidence,
69     and the right (+X) direction corresponds to a zero phi angle.
70     Positive phi is read counter-clockwise from above,
71     and a phi of 90 degrees (+Y) typically corresponds
72     to a material's "up" orientation.
73     .SH EXAMPLE
74     To view a BSDF XML representation:
75     .IP "" .2i
76     bsdf2rad cloth.xml | oconv - > cloth.oct
77     .br
78     rvu -vp 0 -50 50 -vd 0 50 -50 -vh 45 -vv 30 cloth.oct
79     .PP
80     To render an SIR description of a BRDF:
81     .IP "" .2i
82     bsdf2rad front_refl.sir back_refl.sir > refl.rad
83     oconv -f refl.rad | rpict -vf good.vf > refl_good.hdr
84     .SH AUTHOR
85     Greg Ward
86     .SH "SEE ALSO"
87     bsdf2klems(1), bsdf2ttree(1), genBSDF(1),
88     bsdfview(1), oconv(1), pabopto2bsdf(1), rad(1), rpict(1), rvu(1)
