root/radiance/ray/doc/man/man1/bsdf2klems.1
Revision: 1.1
Committed: Thu Apr 25 00:43:20 2013 UTC (12 years, 2 months ago) by greg
Created man pages for bsdf2klems and bsdf2ttree
1 .\" RCSid $Id$
2 .TH BSDF2KLEMS 1 4/24/2013 RADIANCE
3 .SH NAME
4 bsdf2klems - generate XML Klems matrix description of a BSDF
5 .SH SYNOPSIS
6 .B bsdf2klems
7 [
8 .B "\-n spp"
9 ][
10 .B "\-h|\-q"
11 ]
12 [
13 .B "bsdf.sir .."
14 ]
15 .br
16 or
17 .br
18 .B bsdf2klems
19 [
20 .B "\-n spp"
21 ][
22 .B "\-h|\-q"
23 ]
24 .B bsdf_in.xml
25 .br
26 or
27 .br
28 .B bsdf2klems
29 [
30 .B "\-n spp"
31 ][
32 .B "\-h|\-q"
33 ][
34 .B "{+|-}forward"
35 ][
36 .B "{+|-}backward"
37 ][
38 .B "\-e expr
39 ][
40 .B "\-f file
41 ]
42 .B bsdf_func
43 .SH DESCRIPTION
44 .I Bsdf2klems
45 produces a Klems matrix representation of a
46 bidirectional scattering distribution function (BSDF)
47 based on an intermediate representation (in the first form),
48 an input XML representation (in the second form),
49 or a functional description (in the third form).
50 A complete XML description is written to the standard output,
51 which is normally redirected to a file.
52 .PP
53 The Klems matrix representation divides the input and output
54 hemisphere into a default 145 patches.
55 The
56 .I \-h
57 option may be used to reduce this number to 73 patches per hemisphere.
58 The
59 .I \-q
60 option may be used to reduce this number to 41 patches.
61 Neither option is recommended unless the distribution is known to
62 be approximately diffuse.
63 .PP
64 Normally, multiple samples are taken from random points on each input
65 and output patch to improve accuracy.
66 The number of samples to take for each input-output patch pair may
67 be controlled using the
68 .I \-n
69 option, which defaults to 256.
70 .PP
71 The first invocation form takes a intermediate scattering representation
72 as produced by
73 .I pabopto2bsdf(1)
74 or similar, and produces a Klems representation with as many
75 components as there are independent input distributions.
76 Each intermediate scattering file contains one of
77 the four components, and if the first component
78 is isotropic, all components must be isotropic.
79 A similar rule holds for anisotropic inputs.
80 Only the center of each incident patches is sampled, due to
81 the time required to interpolate incident positions.
82 .PP
83 In the second invocation form, an input XML representation
84 is resampled to produce the desired Klems matrix representation.
85 This is primarily used to convert a tensor tree representation
86 into a matrix for annual daylighting simulations.
87 Any components in the input are reproduced on output, and inline
88 geometric descriptions are passed unchanged.
89 .PP
90 In the third invocation form,
91 .I bsdf2klems
92 takes a functional specification of a BSDF.
93 The named function must accept 6 parameters corresponding to the
94 normalized incident and exiting vectors, respectively.
95 By convention, these vectors point away from the surface, and a positive
96 Z-component corresponds to the front side.
97 The Y-component corresponds to the "up" orientation of the surface,
98 as specified in the eventual scene description that references the XML
99 output.
100 .PP
101 The function is defined by one or more
102 .I \-e
103 and
104 .I \-f
105 options, and should obey both Helmholtz reciprocity and
106 integrate to less than 1 over each projected incident hemisphere
107 for energy conservation.
108 .PP
109 Similar to the
110 .I genBSDF(1)
111 command,
112 the
113 .I \+backward
114 option (default) specifies that rays arriving from the front side of
115 the surface will be tested for reflection and transmission.
116 If both forward and backward (front and back) distributions are needed, the
117 .I \+forward
118 option may be given.
119 To turn off the backward components, use the
120 .I \-backward
121 option.
122 Computing both incident hemispheres takes about twice as long as one, but
123 is recommended when rays will be impinging from either side.
124 .SH EXAMPLE
125 To take two components of an intermediate BSDF representation and create
126 a full Klems matrix representation:
127 .IP "" .2i
128 bsdf2klems transmitted.sir reflected.sir > combined.xml
129 .PP
130 To reduce a tensor tree representation into a half-Klems matrix representation:
131 .IP "" .2i
132 bsdf2klems -h ttree.xml > klems_half.xml
133 .PP
134 To create a low-res BSDF corresponding to a one-sided,
135 isotropic Phong distribution:
136 .IP "" .2i
137 bsdf2klems -e 'phong(ix,iy,iz,ox,oy,oz) = if(iz, .1+((iz+oz)/sqrt((ix+ox)^2+(iy+oy)^2+(iz+oz)^2))^50, 0)' phong > phong.xml
138 .SH AUTHOR
139 Greg Ward
140 .SH "SEE ALSO"
141 bsdf2ttree(1), dctimestep(1), icalc(1), gendaymtx(1), genklemsamp(1),
142 genskyvec(1), mkillum(1), genBSDF(1), pkgBSDF(1), rcontrib(1), rtrace(1)
