root/Development/ray/doc/man/man1/bsdf2klems.1
Revision: 1.5
Committed: Fri Feb 20 18:26:08 2015 UTC (10 years, 10 months ago) by greg
CVS Tags: rad5R1, rad5R0
# User Rev Content
1 greg 1.5 .\" RCSid $Id: bsdf2klems.1,v 1.4 2014/03/12 21:15:31 greg Exp $
2 greg 1.1 .TH BSDF2KLEMS 1 4/24/2013 RADIANCE
3     .SH NAME
4     bsdf2klems - generate XML Klems matrix description of a BSDF
5     .SH SYNOPSIS
6     .B bsdf2klems
7     [
8     .B "\-n spp"
9     ][
10     .B "\-h|\-q"
11 greg 1.3 ][
12 greg 1.4 .B "\-pC"
13     ][
14 greg 1.3 .B "\-l maxlobes"
15 greg 1.1 ]
16     [
17     .B "bsdf.sir .."
18     ]
19     .br
20     or
21     .br
22     .B bsdf2klems
23     [
24     .B "\-n spp"
25     ][
26     .B "\-h|\-q"
27 greg 1.4 ][
28     .B "\-pC"
29 greg 1.1 ]
30     .B bsdf_in.xml
31     .br
32     or
33     .br
34     .B bsdf2klems
35     [
36     .B "\-n spp"
37     ][
38     .B "\-h|\-q"
39     ][
40 greg 1.4 .B "\-pC"
41     ][
42 greg 1.1 .B "{+|-}forward"
43     ][
44     .B "{+|-}backward"
45     ][
46 greg 1.3 .B "\-e expr"
47 greg 1.1 ][
48 greg 1.3 .B "\-f file"
49 greg 1.1 ]
50     .B bsdf_func
51     .SH DESCRIPTION
52     .I Bsdf2klems
53     produces a Klems matrix representation of a
54     bidirectional scattering distribution function (BSDF)
55     based on an intermediate representation (in the first form),
56     an input XML representation (in the second form),
57     or a functional description (in the third form).
58     A complete XML description is written to the standard output,
59     which is normally redirected to a file.
60     .PP
61     The Klems matrix representation divides the input and output
62     hemisphere into a default 145 patches.
63     The
64     .I \-h
65     option may be used to reduce this number to 73 patches per hemisphere.
66     The
67     .I \-q
68     option may be used to reduce this number to 41 patches.
69     Neither option is recommended unless the distribution is known to
70     be approximately diffuse.
71 greg 1.4 .PP
72     The
73     .I \-p
74     option by itself turns off the progress bar, whose length may be set
75     by an immediately following integer argument.
76     (The default progress bar length is 79 characters.)\0
77     .PP
78 greg 1.3 The
79     .I \-l
80     option may be used to specify the maximum number of lobes in any
81     interpolated radial basis function.
82     The default value is 15000, which generally keeps the interpolation tractable.
83     Setting the value to 0 turns off this limit.
84 greg 1.1 .PP
85     Normally, multiple samples are taken from random points on each input
86     and output patch to improve accuracy.
87     The number of samples to take for each input-output patch pair may
88     be controlled using the
89     .I \-n
90     option, which defaults to 256.
91     .PP
92     The first invocation form takes a intermediate scattering representation
93     as produced by
94     .I pabopto2bsdf(1)
95     or similar, and produces a Klems representation with as many
96     components as there are independent input distributions.
97     Each intermediate scattering file contains one of
98     the four components, and if the first component
99     is isotropic, all components must be isotropic.
100     A similar rule holds for anisotropic inputs.
101     Only the center of each incident patches is sampled, due to
102     the time required to interpolate incident positions.
103     .PP
104     In the second invocation form, an input XML representation
105     is resampled to produce the desired Klems matrix representation.
106     This is primarily used to convert a tensor tree representation
107     into a matrix for annual daylighting simulations.
108     Any components in the input are reproduced on output, and inline
109     geometric descriptions are passed unchanged.
110     .PP
111     In the third invocation form,
112     .I bsdf2klems
113     takes a functional specification of a BSDF.
114 greg 1.2 The named function should accept 6 parameters corresponding to the
115 greg 1.1 normalized incident and exiting vectors, respectively.
116     By convention, these vectors point away from the surface, and a positive
117     Z-component corresponds to the front side.
118     The Y-component corresponds to the "up" orientation of the surface,
119     as specified in the eventual scene description that references the XML
120     output.
121 greg 1.2 If the function only takes 3 parameters, then the variables "Dx", "Dy",
122     and "Dz" will be assigned to the reverse of the outgoing direction at
123     each evaluation.
124     (I.e., the vector will point into the surface and
125     Dz will be negative on the front side.)\0
126     This simplifies conversion of functional BSDF specifications using the
127     legacy material primitives "plasfunc", "metfunc", and "transfunc".
128 greg 1.1 .PP
129     The function is defined by one or more
130     .I \-e
131     and
132     .I \-f
133     options, and should obey both Helmholtz reciprocity and
134     integrate to less than 1 over each projected incident hemisphere
135     for energy conservation.
136     .PP
137     Similar to the
138     .I genBSDF(1)
139     command,
140     the
141     .I \+backward
142     option (default) specifies that rays arriving from the front side of
143     the surface will be tested for reflection and transmission.
144     If both forward and backward (front and back) distributions are needed, the
145     .I \+forward
146     option may be given.
147     To turn off the backward components, use the
148     .I \-backward
149     option.
150     Computing both incident hemispheres takes about twice as long as one, but
151     is recommended when rays will be impinging from either side.
152     .SH EXAMPLE
153     To take two components of an intermediate BSDF representation and create
154     a full Klems matrix representation:
155     .IP "" .2i
156     bsdf2klems transmitted.sir reflected.sir > combined.xml
157     .PP
158     To reduce a tensor tree representation into a half-Klems matrix representation:
159     .IP "" .2i
160     bsdf2klems -h ttree.xml > klems_half.xml
161     .PP
162     To create a low-res BSDF corresponding to a one-sided,
163     isotropic Phong distribution:
164     .IP "" .2i
165     bsdf2klems -e 'phong(ix,iy,iz,ox,oy,oz) = if(iz, .1+((iz+oz)/sqrt((ix+ox)^2+(iy+oy)^2+(iz+oz)^2))^50, 0)' phong > phong.xml
166     .SH AUTHOR
167     Greg Ward
168     .SH "SEE ALSO"
169     bsdf2ttree(1), dctimestep(1), icalc(1), gendaymtx(1), genklemsamp(1),
170 greg 1.5 genskyvec(1), mkillum(1), genBSDF(1), pkgBSDF(1), rcontrib(1), rfluxmtx(1),
171     rmtxop(1), wrapBSDF(1)
