root/radiance/ray/doc/man/man1/bgraph.1
Revision: 1.2
Committed: Tue Dec 9 15:59:06 2003 UTC (20 years, 5 months ago) by greg
Fixed RCSid specification
1 .\" RCSid "$Id$"
2 .TH BGRAPH 1 6/24/98 RADIANCE
3 .SH NAME
4 bgraph - do a set of batch graphs to a metafile
5 .SH SYNOPSIS
6 .B bgraph
7 [
8 .B \-type ..
9 ][
10 .B +variable value ..
11 ][
12 .B file ..
13 ]
14 .SH DESCRIPTION
15 .I Bgraph
16 reads each graph
17 .I file
18 in sequence and converts it to a plot suitable
19 for use by a metafile driver program.
20 If no files are given, the standard input is read.
21 .PP
22 The graph type can be defined with a
23 .I \-type
24 option.
25 Types are simply include files which set default values for
26 certain variables.
27 The actual include file name is the type concatanated with ".plt".
28 Typical types are "scatter", "line", and "curve".
29 A scatter graph shows only points.
30 A line graph shows only lines connecting points.
31 A curve graph shows both points and connecting lines.
32 .PP
33 Variables can be set explicitly with
34 .I +variable value
35 options.
36 The following standard graph variables are supported:
37 .TP 10n
38 .BR fthick
39 The frame thickness, valued from 0 to 4.
40 A value of 0 turns the frame off.
41 .TP
42 .BR grid
43 The grid: 1 is on, 0 is off.
44 .TP
45 .BR include
46 The include file name.
47 Graph input is taken from the file.
48 If the file is not found in the current directory, it is
49 searched for in a set of standard locations.
50 .TP
51 .BR legend
52 The legend title.
53 .TP
54 .BR othick
55 The origin axis thickness, valued from 0 to 4.
56 A value of 0 turns the origin off.
57 .TP
58 .BR period
59 The period for a polar plot.
60 For a plot in degrees, use 360.
61 For radians, use 6.283.
62 A value of 0 (the default) indicates a Cartesian plot.
63 .TP
64 .BR subtitle
65 The graph subtitle.
66 .TP
67 .BR symfile
68 The point symbol metafile.
69 .TP
70 .BR tstyle
71 The frame tick mark style.
72 The default value is 1, which is outward tick marks.
73 A value of 2 is inward ticks, 3 is cross ticks.
74 A value of 0 disables frame tick marks.
75 .TP
76 .BR title
77 The graph title.
78 .TP
79 .BR xlabel
80 The x axis label.
81 .TP
82 .BR xmap
83 The x axis mapping function.
84 An x axis mapping xmap(x)=log(x) produces a log x axis.
85 .TP
86 .BR xmax
87 The x axis maximum.
88 .TP
89 .BR xmin
90 The x axis minimum.
91 .TP
92 .BR xstep
93 The x axis step.
94 .TP
95 .BR ylabel
96 The y axis label.
97 .TP
98 .BR ymap
99 The y axis mapping function.
100 An y axis mapping ymap(y)=log(y) produces a log y axis.
101 .TP
102 .BR ymax
103 The y axis maximum.
104 .TP
105 .BR ymin
106 The y axis minimum.
107 .TP
108 .BR ystep
109 The y axis step.
110 .PP
111 In addition to the standard graph variables, each curve
112 has a set of variables.
113 The variables for curve 'A' all begin with the letter 'A';
114 the variables for curve 'B' all begin with the letter 'B',
115 and so on.
116 Up to 8 curves are supported on a single graph, 'A'
117 through 'H'.
118 The variables for curve 'A' are:
119 .TP 10n
120 .BR A
121 The function for curve 'A'.
122 If
123 .I Adata
124 is undefined,
125 .I xmin,
126 .I xmax
127 and
128 .I Anpoints
129 are used to determine which x values to plot.
130 If
131 .I Adata
132 is defined and
133 .I A
134 is a function of a single variable (ie. A(x)),
135 data values are interpreted as x values to be plotted.
136 If
137 .I Adata
138 is defined and
139 .I A
140 is a function of two variables (ie. A(x,y)),
141 data values are interpreted as (x,y) pairs and
142 .I A
143 becomes a mapping function for the data.
144 .TP
145 .BR Acolor
146 The color for curve A.
147 The values 1-4 map to black, red, green, and blue respectively.
148 A value of 0 turns curve A off.
149 .TP
150 .BR Adata
151 The point data for curve 'A'.
152 If
153 .I Adata
154 is set to the name of a file,
155 data is read and interpreted from that file.
156 If
157 .I Adata
158 is set to a command (beginning with an exclamation, '!'),
159 the output of the command is read as data.
160 Otherwise, data is read from the current file.
161 Data values are separated by white space and/or commas.
162 A semicolon or end of file indicates the end of data.
163 .TP
164 .BR Alabel
165 The label for curve 'A'.
166 The curve label is printed in the legend when a curve is defined.
167 .TP
168 .BR Alintype
169 The line type for curve 'A', valued from 0 to 4.
170 A value of 0 turns line drawing off.
171 A value of 1 is solid, 2 is dashed, 3 is dotted, and 4 is dot-dashed.
172 .TP
173 .BR Anpoints
174 The number of symbol points for curve 'A'.
175 If
176 .I Adata
177 is defined, all points will be connected with the selected
178 curve line, but only
179 .I Anpoints
180 points will be indicated with a symbol.
181 This prevents messy graphs when large number of points are defined.
182 If
183 .I A
184 is defined and
185 .I Adata
186 is not,
187 .I Anpoints
188 is used along with
189 .I xmin
190 and
191 .I xmax
192 to determine which x values to plot.
193 .TP
194 .BR Asymsize
195 The symbol radius for curve 'A'.
196 The default size is 100.
197 A value of 0 turns symbols off.
198 .TP
199 .BR Asymtype
200 This is the name of a segment in
201 .I symfile
202 which defines the graphics symbol for curve 'A'.
203 .TP
204 .BR Athick
205 The line thickness for curve 'A', valued from 0 to 4.
206 A thickness of 0 turns line drawing off.
207 .SH "GRAPH FILE FORMAT"
208 A graph file contains definitions for graph and curve
209 variables.
210 These definitions fall one per line in the following formats:
211 .nf
212
213 vreal = expression # real variable
214 vfunction(x) = expression(x) # function
215 vstring = "string" # string variable
216 vdata = filename # data file
217 vdata = "!command" # data generator
218 variable = continued \\
219 line # newline escaped
220 vdata = # data
221 v1 v2 v3 v4 ... ;
222
223 .fi
224 Comments are preceded by a '#', and continue to the end
225 of the line.
226 Except for comments, the newline can be escaped with a backslash.
227 Note that in the special case where data is contained in
228 the graph file, a definition will continue over more than
229 one line.
230 Data values can be separated by commas or white space, and
231 reading continues until a semicolon is reached.
232 No comments are allowed in the data section of a file.
233 .PP
234 An expression is an algebraic formula containing numbers,
235 variables, functions, and the standard operators
236 {+,-,*,/,^,(,)} (see calc(1)).
237 Besides the variables described in the last section,
238 definitions of intermediate real variables and functions
239 are allowed for convenience.
240 They may be used in expressions of graph and curve variables.
241 .SH EXAMPLE
242 A file to graph the sine function is:
243 .nf
244
245 title = "Sine Function from 0 to Pi"
246 PI = 3.141592653589793
247 A(x) = sin(x)
248 xmin = 0
249 xmax = PI
250 Anpoints = 100
251
252 .fi
253 Or, to graph selected points:
254 .nf
255
256 title = "Sine Function at 0, .2, .6, and .8"
257 A(x) = sin(x)
258 Adata =
259 0 , .2
260 .6 , .8
261 ;
262
263 .fi
264 The commands to plot these files might be:
265 .nf
266
267 bgraph -line sine1.plt | impress | ipr
268
269 bgraph -curve +ymin -1 +ymax 1 sine2.plt | t4014
270
271 .fi
272 .SH FILES
273 /usr/local/lib/meta/*.mta
274 /usr/local/lib/meta/*.plt
275 *.plt
276 .SH AUTHOR
277 Greg Ward
278 .SH BUGS
279 There is no mechanism provided for undefining a variable.
280 An axis mapping function which is not invertible (monotonically
281 increasing or decreasing) confuses the program terribly.
282 .SH "SEE ALSO"
283 calc(1), dgraph(1), gcomp(1), igraph(1), impress(1),
284 metafile(5), mx80(1), mt160l(1), t4014(1), x11meta(1)
