1 |
greg |
1.5 |
.\" RCSid "$Id: bgraph.1,v 1.4 2005/10/27 00:20:08 greg Exp $" |
2 |
greg |
1.1 |
.TH BGRAPH 1 6/24/98 RADIANCE |
3 |
.SH NAME |
4 |
bgraph - do a set of batch graphs to a metafile |
5 |
.SH SYNOPSIS |
6 |
.B bgraph |
7 |
8 |
.B \-type .. |
9 |
10 |
.B +variable value .. |
11 |
12 |
.B file .. |
13 |
14 |
.SH DESCRIPTION |
15 |
.I Bgraph |
16 |
reads each graph |
17 |
.I file |
18 |
in sequence and converts it to a plot suitable |
19 |
for use by a metafile driver program. |
20 |
If no files are given, the standard input is read. |
21 |
.PP |
22 |
The graph type can be defined with a |
23 |
.I \-type |
24 |
option. |
25 |
Types are simply include files which set default values for |
26 |
certain variables. |
27 |
The actual include file name is the type concatanated with ".plt". |
28 |
Typical types are "scatter", "line", and "curve". |
29 |
A scatter graph shows only points. |
30 |
A line graph shows only lines connecting points. |
31 |
A curve graph shows both points and connecting lines. |
32 |
.PP |
33 |
Variables can be set explicitly with |
34 |
.I +variable value |
35 |
options. |
36 |
The following standard graph variables are supported: |
37 |
.TP 10n |
38 |
.BR fthick |
39 |
The frame thickness, valued from 0 to 4. |
40 |
A value of 0 turns the frame off. |
41 |
.TP |
42 |
.BR grid |
43 |
The grid: 1 is on, 0 is off. |
44 |
.TP |
45 |
.BR include |
46 |
The include file name. |
47 |
Graph input is taken from the file. |
48 |
If the file is not found in the current directory, it is |
49 |
searched for in a set of standard locations. |
50 |
.TP |
51 |
.BR legend |
52 |
The legend title. |
53 |
.TP |
54 |
.BR othick |
55 |
The origin axis thickness, valued from 0 to 4. |
56 |
A value of 0 turns the origin off. |
57 |
.TP |
58 |
.BR period |
59 |
The period for a polar plot. |
60 |
For a plot in degrees, use 360. |
61 |
For radians, use 6.283. |
62 |
A value of 0 (the default) indicates a Cartesian plot. |
63 |
.TP |
64 |
.BR subtitle |
65 |
The graph subtitle. |
66 |
.TP |
67 |
.BR symfile |
68 |
The point symbol metafile. |
69 |
.TP |
70 |
.BR tstyle |
71 |
The frame tick mark style. |
72 |
The default value is 1, which is outward tick marks. |
73 |
A value of 2 is inward ticks, 3 is cross ticks. |
74 |
A value of 0 disables frame tick marks. |
75 |
.TP |
76 |
.BR title |
77 |
The graph title. |
78 |
.TP |
79 |
.BR xlabel |
80 |
The x axis label. |
81 |
.TP |
82 |
.BR xmap |
83 |
The x axis mapping function. |
84 |
An x axis mapping xmap(x)=log(x) produces a log x axis. |
85 |
.TP |
86 |
.BR xmax |
87 |
The x axis maximum. |
88 |
.TP |
89 |
.BR xmin |
90 |
The x axis minimum. |
91 |
.TP |
92 |
.BR xstep |
93 |
The x axis step. |
94 |
.TP |
95 |
.BR ylabel |
96 |
The y axis label. |
97 |
.TP |
98 |
.BR ymap |
99 |
The y axis mapping function. |
100 |
An y axis mapping ymap(y)=log(y) produces a log y axis. |
101 |
.TP |
102 |
.BR ymax |
103 |
The y axis maximum. |
104 |
.TP |
105 |
.BR ymin |
106 |
The y axis minimum. |
107 |
.TP |
108 |
.BR ystep |
109 |
The y axis step. |
110 |
.PP |
111 |
In addition to the standard graph variables, each curve |
112 |
has a set of variables. |
113 |
The variables for curve 'A' all begin with the letter 'A'; |
114 |
the variables for curve 'B' all begin with the letter 'B', |
115 |
and so on. |
116 |
Up to 8 curves are supported on a single graph, 'A' |
117 |
through 'H'. |
118 |
The variables for curve 'A' are: |
119 |
.TP 10n |
120 |
.BR A |
121 |
The function for curve 'A'. |
122 |
If |
123 |
.I Adata |
124 |
is undefined, |
125 |
.I xmin, |
126 |
.I xmax |
127 |
and |
128 |
.I Anpoints |
129 |
are used to determine which x values to plot. |
130 |
If |
131 |
.I Adata |
132 |
is defined and |
133 |
.I A |
134 |
is a function of a single variable (ie. A(x)), |
135 |
data values are interpreted as x values to be plotted. |
136 |
If |
137 |
.I Adata |
138 |
is defined and |
139 |
.I A |
140 |
is a function of two variables (ie. A(x,y)), |
141 |
data values are interpreted as (x,y) pairs and |
142 |
.I A |
143 |
becomes a mapping function for the data. |
144 |
.TP |
145 |
.BR Acolor |
146 |
The color for curve A. |
147 |
The values 1-4 map to black, red, green, and blue respectively. |
148 |
A value of 0 turns curve A off. |
149 |
.TP |
150 |
.BR Adata |
151 |
The point data for curve 'A'. |
152 |
If |
153 |
.I Adata |
154 |
is set to the name of a file, |
155 |
data is read and interpreted from that file. |
156 |
If |
157 |
.I Adata |
158 |
is set to a command (beginning with an exclamation, '!'), |
159 |
the output of the command is read as data. |
160 |
Otherwise, data is read from the current file. |
161 |
Data values are separated by white space and/or commas. |
162 |
A semicolon or end of file indicates the end of data. |
163 |
.TP |
164 |
.BR Alabel |
165 |
The label for curve 'A'. |
166 |
The curve label is printed in the legend when a curve is defined. |
167 |
.TP |
168 |
.BR Alintype |
169 |
The line type for curve 'A', valued from 0 to 4. |
170 |
A value of 0 turns line drawing off. |
171 |
A value of 1 is solid, 2 is dashed, 3 is dotted, and 4 is dot-dashed. |
172 |
.TP |
173 |
.BR Anpoints |
174 |
The number of symbol points for curve 'A'. |
175 |
If |
176 |
.I Adata |
177 |
is defined, all points will be connected with the selected |
178 |
curve line, but only |
179 |
.I Anpoints |
180 |
points will be indicated with a symbol. |
181 |
This prevents messy graphs when large number of points are defined. |
182 |
If |
183 |
.I A |
184 |
is defined and |
185 |
.I Adata |
186 |
is not, |
187 |
.I Anpoints |
188 |
is used along with |
189 |
.I xmin |
190 |
and |
191 |
.I xmax |
192 |
193 |
.TP |
194 |
.BR Asymsize |
195 |
The symbol radius for curve 'A'. |
196 |
The default size is 100. |
197 |
A value of 0 turns symbols off. |
198 |
.TP |
199 |
.BR Asymtype |
200 |
This is the name of a segment in |
201 |
.I symfile |
202 |
which defines the graphics symbol for curve 'A'. |
203 |
.TP |
204 |
.BR Athick |
205 |
The line thickness for curve 'A', valued from 0 to 4. |
206 |
A thickness of 0 turns line drawing off. |
207 |
.SH "GRAPH FILE FORMAT" |
208 |
A graph file contains definitions for graph and curve |
209 |
variables. |
210 |
These definitions fall one per line in the following formats: |
211 |
.nf |
212 |
213 |
vreal = expression # real variable |
214 |
vfunction(x) = expression(x) # function |
215 |
vstring = "string" # string variable |
216 |
vdata = filename # data file |
217 |
vdata = "!command" # data generator |
218 |
variable = continued \\ |
219 |
line # newline escaped |
220 |
vdata = # data |
221 |
v1 v2 v3 v4 ... ; |
222 |
223 |
.fi |
224 |
Comments are preceded by a '#', and continue to the end |
225 |
of the line. |
226 |
Except for comments, the newline can be escaped with a backslash. |
227 |
Note that in the special case where data is contained in |
228 |
the graph file, a definition will continue over more than |
229 |
one line. |
230 |
Data values can be separated by commas or white space, and |
231 |
reading continues until a semicolon is reached. |
232 |
No comments are allowed in the data section of a file. |
233 |
.PP |
234 |
An expression is an algebraic formula containing numbers, |
235 |
variables, functions, and the standard operators |
236 |
greg |
1.3 |
{+,-,*,/,^,(,)} (see icalc(1)). |
237 |
greg |
1.1 |
Besides the variables described in the last section, |
238 |
definitions of intermediate real variables and functions |
239 |
are allowed for convenience. |
240 |
They may be used in expressions of graph and curve variables. |
241 |
.SH EXAMPLE |
242 |
A file to graph the sine function is: |
243 |
.nf |
244 |
245 |
title = "Sine Function from 0 to Pi" |
246 |
PI = 3.141592653589793 |
247 |
A(x) = sin(x) |
248 |
xmin = 0 |
249 |
xmax = PI |
250 |
Anpoints = 100 |
251 |
252 |
.fi |
253 |
Or, to graph selected points: |
254 |
.nf |
255 |
256 |
title = "Sine Function at 0, .2, .6, and .8" |
257 |
A(x) = sin(x) |
258 |
Adata = |
259 |
0 , .2 |
260 |
.6 , .8 |
261 |
262 |
263 |
.fi |
264 |
The commands to plot these files might be: |
265 |
.nf |
266 |
267 |
greg |
1.5 |
bgraph \-line sine1.plt | psmeta | lpr |
268 |
greg |
1.1 |
269 |
greg |
1.5 |
bgraph \-curve +ymin \-1 +ymax 1 sine2.plt | x11meta |
270 |
greg |
1.1 |
271 |
.fi |
272 |
.SH FILES |
273 |
/usr/local/lib/meta/*.mta |
274 |
/usr/local/lib/meta/*.plt |
275 |
*.plt |
276 |
.SH AUTHOR |
277 |
Greg Ward |
278 |
.SH BUGS |
279 |
There is no mechanism provided for undefining a variable. |
280 |
An axis mapping function which is not invertible (monotonically |
281 |
increasing or decreasing) confuses the program terribly. |
282 |
.SH "SEE ALSO" |
283 |
greg |
1.4 |
dgraph(1), gcomp(1), icalc(1), igraph(1), |
284 |
metafile(5), x11meta(1) |
