--- ray/doc/man/man1/arch2rad.1 2003/03/11 19:20:21 1.1 +++ ray/doc/man/man1/arch2rad.1 2007/09/04 17:36:40 1.3 @@ -1,4 +1,4 @@ -.\" RCSid "$Id" +.\" RCSid "$Id: arch2rad.1,v 1.3 2007/09/04 17:36:40 greg Exp $" .TH ARCH2RAD 1 11/15/93 RADIANCE .SH NAME arch2rad - convert Architrion text file to RADIANCE description @@ -152,12 +152,12 @@ reference id name "window overhangs" in layer number 3 .SH EXAMPLE To create a qualifier list for building.txt: .IP "" .2i -arch2rad -n building.txt > building.qual +arch2rad \-n building.txt > building.qual .PP To translate building.txt into a RADIANCE file using the mapping building.map: .IP "" .2i -arch2rad -m building.map building.txt > building.rad +arch2rad \-m building.map building.txt > building.rad .PP To create an octree directly from an Architrion file using the default mapping and materials:
