root/Development/ray/doc/man/man1/arch2rad.1
Revision: 1.1
Committed: Tue Mar 11 19:20:21 2003 UTC (22 years, 6 months ago) by greg
Added documentation to repository
1 .\" RCSid "$Id"
2 .TH ARCH2RAD 1 11/15/93 RADIANCE
3 .SH NAME
4 arch2rad - convert Architrion text file to RADIANCE description
5 .SH SYNOPSIS
6 .B arch2rad
7 [
8 .B \-n
9 ][
10 .B "\-m mapfile"
11 ]
12 [
13 .B input
14 ]
15 .SH DESCRIPTION
16 .I Arch2rad
17 converts an Architrion text file to a RADIANCE scene description.
18 The material names for the surfaces will assigned based on the
19 default mapping or the mapping rules file given in the
20 .I \-m
21 option.
22 A mapping file contains a list of materials followed by the conditions
23 a surface must satisfy in order to have that material.
24 .PP
25 For example, if we wanted all surfaces for blocks with RefId "thingy" and
26 Color 152 to use the material "wood", and all other surfaces to use the
27 material "default", we would create the following mapping file:
28 .nf
29
30 default ;
31 wood (RefId "thingy") (Color 152) ;
32
33 .fi
34 All surfaces would satisfy the first set of conditions (which is empty),
35 but only the surfaces in blocks with RefId "thingy"
36 and Color 152 would satisfy the
37 second set of conditions.
38 .PP
39 Each rule can have up to one condition per qualifier, and different
40 translators use different qualifiers.
41 In
42 .I arch2rad,
43 the valid qualifiers are
44 .I "Layer, Color, Face"
45 and
46 .I RefId.
47 A condition is either a single value for a
48 specific attribute, or an integer range of values.
49 (Integer ranges are
50 specified in brackets and separated by a colon, eg. [\-15:27], and are
51 always inclusive.) A semicolon is used to indicate the end of a rule,
52 which can extend over several lines if necessary.
53 .PP
54 The semantics of the rule are such that "and" is the implied conjunction
55 between conditions.
56 Thus, it makes no sense to have more than one
57 condition in a rule for a given qualifier.
58 If the user wants the same
59 material to be used for surfaces that satisfy different conditions,
60 they simply add more rules.
61 For example, if the user also wanted
62 surfaces in blocks with
63 RefId "yohey" with Colors between 50 and 100 to use "wood",
64 they would add the following rule to the end of the example above:
65 .nf
66
67 wood (Color [50:100]) (RefId "yohey") ;
68
69 .fi
70 Note that the order of conditions in a rule is irrelevant.
71 However,
72 the order of rules is very important, since the last rule satisfied
73 determines which material a surface is assigned.
74 .PP
75 By convention, the identifier "void" is used to delete unwanted
76 surfaces.
77 A surfaces is also deleted if it fails to match any rule.
78 Void is used in a rule as any other material, but it has the
79 effect of excluding all matching surfaces from the translator output.
80 For example, the following mapping would delete all surfaces in the
81 Layer 2 except those with the color "beige", to which it would assign
82 the material "beige_cloth", and all other surfaces would be "tacky":
83 .nf
84
85 tacky ;
86 void (Layer 2) ;
87 beige_cloth (Layer 2) (Color "beige") ;
88
89 .fi
90 .PP
91 If neither the
92 .I \-m
93 nor the
94 .I \-n
95 options are not used,
96 .I arch2rad
97 uses the default mapping file "/usr/local/lib/ray/lib/arch.map".
98 This file simply assigns materials based on color, using the
99 identifiers "c0" through "c255".
100 Appropriate materials for these identifiers are contained
101 in "/usr/local/lib/ray/lib/arch.mat".
102 .PP
103 The
104 .I \-n
105 option may be used to produce a list of qualifiers from which to construct
106 a mapping for the given Architrion file.
107 If the
108 .I \-m
109 option is used also, only those blocks matched in the mapping file
110 will be added to the qualifier list.
111 .SH DETAILS
112 Architrion blocks are divided into about 6 polygons.
113 The reference, opposite and end faces must all be quadrilaterals (ie.
114 four-sided polygons),
115 though one or more faces may disappear in certain degenerate cases.
116 The bottom face will usually be a quadrilateral, though it may be
117 written out as two triangles if the face is non-planar or one triangle
118 if there is a degenerate side.
119 The top face is treated the same as the bottom face.
120 .PP
121 Openings are currently handled using the antimatter material type.
122 An antimatter material called "opening" is defined that "clips" all
123 faces for the current block, and patches the edges of the hole with
124 the material defined for the face "sill".
125 If no rule is given specifically for the sill face, then the most
126 specific material (ie. the material in the latest rule)
127 for this block is used.
128 An antimatter opening will not function properly if there is another
129 surface intersecting it, or rendering is attempted from within the
130 opening.
131 Overlapping openings or openings with shared boundaries will also fail.
132 There is currently no support of Architrion "frame" libraries.
133 .PP
134 Naming of the output faces is based on layer number, reference id
135 and output block number (sequential from 1 to the total number of
136 output blocks).
137 If there is no reference id name, the layer name is used (if available)
138 instead of the layer number.
139 If there is a reference id number but no name, that is added as
140 well.
141 Names are truncated to the first 12 characters, so the ends of long
142 names may be lost.
143 Also, spaces in names are replaced by underscores ('_').
144 Finally, the face id is added to the end of the block name for each
145 output polygon.
146 An example identifier for a polygon is:
147 .PP
148 l3.window_overh.3155.ref
149 .PP
150 This would be the reference face of output block number 3155,
151 reference id name "window overhangs" in layer number 3.
152 .SH EXAMPLE
153 To create a qualifier list for building.txt:
154 .IP "" .2i
155 arch2rad -n building.txt > building.qual
156 .PP
157 To translate building.txt into a RADIANCE file using the mapping
158 building.map:
159 .IP "" .2i
160 arch2rad -m building.map building.txt > building.rad
161 .PP
162 To create an octree directly from an Architrion file using the default
163 mapping and materials:
164 .IP "" .2i
165 oconv source.rad /usr/local/lib/ray/lib/arch.mat '\\!arch2rad building.txt' > building.oct
166 .SH FILES
167 /usr/local/lib/ray/lib/arch.map
168 /usr/local/lib/ray/lib/arch.mat
169 .SH AUTHOR
170 Greg Ward
171 .SH "SEE ALSO"
172 ies2rad(1), oconv(1), thf2rad(1), xform(1)
