root/Development/ray/doc/man/man1/arch2rad.1
Revision: 1.3
Committed: Tue Sep 4 17:36:40 2007 UTC (18 years, 4 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, HEAD
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
# User Rev Content
1 greg 1.3 .\" RCSid "$Id: arch2rad.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 greg 1.1 .TH ARCH2RAD 1 11/15/93 RADIANCE
3     .SH NAME
4     arch2rad - convert Architrion text file to RADIANCE description
5     .SH SYNOPSIS
6     .B arch2rad
7     [
8     .B \-n
9     ][
10     .B "\-m mapfile"
11     ]
12     [
13     .B input
14     ]
15     .SH DESCRIPTION
16     .I Arch2rad
17     converts an Architrion text file to a RADIANCE scene description.
18     The material names for the surfaces will assigned based on the
19     default mapping or the mapping rules file given in the
20     .I \-m
21     option.
22     A mapping file contains a list of materials followed by the conditions
23     a surface must satisfy in order to have that material.
24     .PP
25     For example, if we wanted all surfaces for blocks with RefId "thingy" and
26     Color 152 to use the material "wood", and all other surfaces to use the
27     material "default", we would create the following mapping file:
28     .nf
29
30     default ;
31     wood (RefId "thingy") (Color 152) ;
32
33     .fi
34     All surfaces would satisfy the first set of conditions (which is empty),
35     but only the surfaces in blocks with RefId "thingy"
36     and Color 152 would satisfy the
37     second set of conditions.
38     .PP
39     Each rule can have up to one condition per qualifier, and different
40     translators use different qualifiers.
41     In
42     .I arch2rad,
43     the valid qualifiers are
44     .I "Layer, Color, Face"
45     and
46     .I RefId.
47     A condition is either a single value for a
48     specific attribute, or an integer range of values.
49     (Integer ranges are
50     specified in brackets and separated by a colon, eg. [\-15:27], and are
51     always inclusive.) A semicolon is used to indicate the end of a rule,
52     which can extend over several lines if necessary.
53     .PP
54     The semantics of the rule are such that "and" is the implied conjunction
55     between conditions.
56     Thus, it makes no sense to have more than one
57     condition in a rule for a given qualifier.
58     If the user wants the same
59     material to be used for surfaces that satisfy different conditions,
60     they simply add more rules.
61     For example, if the user also wanted
62     surfaces in blocks with
63     RefId "yohey" with Colors between 50 and 100 to use "wood",
64     they would add the following rule to the end of the example above:
65     .nf
66
67     wood (Color [50:100]) (RefId "yohey") ;
68
69     .fi
70     Note that the order of conditions in a rule is irrelevant.
71     However,
72     the order of rules is very important, since the last rule satisfied
73     determines which material a surface is assigned.
74     .PP
75     By convention, the identifier "void" is used to delete unwanted
76     surfaces.
77     A surfaces is also deleted if it fails to match any rule.
78     Void is used in a rule as any other material, but it has the
79     effect of excluding all matching surfaces from the translator output.
80     For example, the following mapping would delete all surfaces in the
81     Layer 2 except those with the color "beige", to which it would assign
82     the material "beige_cloth", and all other surfaces would be "tacky":
83     .nf
84
85     tacky ;
86     void (Layer 2) ;
87     beige_cloth (Layer 2) (Color "beige") ;
88
89     .fi
90     .PP
91     If neither the
92     .I \-m
93     nor the
94     .I \-n
95     options are not used,
96     .I arch2rad
97     uses the default mapping file "/usr/local/lib/ray/lib/arch.map".
98     This file simply assigns materials based on color, using the
99     identifiers "c0" through "c255".
100     Appropriate materials for these identifiers are contained
101     in "/usr/local/lib/ray/lib/arch.mat".
102     .PP
103     The
104     .I \-n
105     option may be used to produce a list of qualifiers from which to construct
106     a mapping for the given Architrion file.
107     If the
108     .I \-m
109     option is used also, only those blocks matched in the mapping file
110     will be added to the qualifier list.
111     .SH DETAILS
112     Architrion blocks are divided into about 6 polygons.
113     The reference, opposite and end faces must all be quadrilaterals (ie.
114     four-sided polygons),
115     though one or more faces may disappear in certain degenerate cases.
116     The bottom face will usually be a quadrilateral, though it may be
117     written out as two triangles if the face is non-planar or one triangle
118     if there is a degenerate side.
119     The top face is treated the same as the bottom face.
120     .PP
121     Openings are currently handled using the antimatter material type.
122     An antimatter material called "opening" is defined that "clips" all
123     faces for the current block, and patches the edges of the hole with
124     the material defined for the face "sill".
125     If no rule is given specifically for the sill face, then the most
126     specific material (ie. the material in the latest rule)
127     for this block is used.
128     An antimatter opening will not function properly if there is another
129     surface intersecting it, or rendering is attempted from within the
130     opening.
131     Overlapping openings or openings with shared boundaries will also fail.
132     There is currently no support of Architrion "frame" libraries.
133     .PP
134     Naming of the output faces is based on layer number, reference id
135     and output block number (sequential from 1 to the total number of
136     output blocks).
137     If there is no reference id name, the layer name is used (if available)
138     instead of the layer number.
139     If there is a reference id number but no name, that is added as
140     well.
141     Names are truncated to the first 12 characters, so the ends of long
142     names may be lost.
143     Also, spaces in names are replaced by underscores ('_').
144     Finally, the face id is added to the end of the block name for each
145     output polygon.
146     An example identifier for a polygon is:
147     .PP
148     l3.window_overh.3155.ref
149     .PP
150     This would be the reference face of output block number 3155,
151     reference id name "window overhangs" in layer number 3.
152     .SH EXAMPLE
153     To create a qualifier list for building.txt:
154     .IP "" .2i
155 greg 1.3 arch2rad \-n building.txt > building.qual
156 greg 1.1 .PP
157     To translate building.txt into a RADIANCE file using the mapping
158     building.map:
159     .IP "" .2i
160 greg 1.3 arch2rad \-m building.map building.txt > building.rad
161 greg 1.1 .PP
162     To create an octree directly from an Architrion file using the default
163     mapping and materials:
164     .IP "" .2i
165     oconv source.rad /usr/local/lib/ray/lib/arch.mat '\\!arch2rad building.txt' > building.oct
166     .SH FILES
167     /usr/local/lib/ray/lib/arch.map
168     /usr/local/lib/ray/lib/arch.mat
169     .SH AUTHOR
170     Greg Ward
171     .SH "SEE ALSO"
172     ies2rad(1), oconv(1), thf2rad(1), xform(1)
